First Time Deck Building (any Deck Experts Here?) - General Discussion - Contractor Talk
Old 06-10-2019, 10:17 AM   #1
micro123's Avatar
Trade: Framing
Rewards Points: 50
Just took on my first deck building job (so go easy on me haha).
Just a few questions:
1) We hit some big roots and rocks (when digging post holes) which threw our line off a little. How important is it that the holes are perfectly in-line? There is only 4 total posts (2 beams and 2 posts each beam). Some of the holes (centers) are 2-3 inches off the line.
2) Must the beams be perfectly square to each other (parralel)?
3) 2 of the 4 sonotubes got damaged. One - the top was damaged (guy ran over it with the dingo). The other, the auger hit the side of the sonotube when underground and pushed it in. Should these 2 be pulled out and replaced?
Here are a few images to get a visual: https://imgur.com/a/3556yrX
I want to do things RIGHT, so if I need to re-do them, I will.
Please advise.
micro123 is offline
Old 06-10-2019, 11:22 AM   #2
test
cedarboarder's Avatar
Trade: General
Rewards Points: 815
Re: First Time Deck Building (any Deck Experts Here?)
this job isn't getting of on the right foot.
You need to check your building codes and get some drawings and permits if you don't have any.
You build decks for a living?
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
The Following User Says Thank You to cedarboarder For This Useful Post:
hdavis (06-10-2019)
Old 06-10-2019, 01:14 PM   #3
hdavis's Avatar
Rewards Points: 1,868
I don't offset for roots or rocks, I either dig where they are supposed to be, or modify the design. I haven't had to modify a design yet, but that means I dig a bigger hole to get a rock out.
Post hole digger
Digging bar
Battery powered Sawzall with 12" blade
Shovel
That takes care of anything short of blasting.
Replace those sonotubes. I cut them to height, then pour and finish the concrete.
There is not a lot of slop available putting a 6" post on a 12" footing. They are structural, and they need to be right.
hdavis is online now
fjn (06-10-2019)
Old 06-10-2019, 02:13 PM   #4
Stunt Carpenter's Avatar
Rewards Points: 2,882
Why are you digging hole right beside the tubes?
https://builddaley.com/
Stunt Carpenter is offline
The Following 2 Users Say Thank You to Stunt Carpenter For This Useful Post:
cedarboarder (06-30-2019), tgeb (06-10-2019)
Old 06-10-2019, 02:27 PM   #5
hdavis's Avatar
Get the frame off, and the rest if it becomes a big pain in the butt.
I imagine you've heard that before....
Old 06-10-2019, 02:29 PM   #6
hdavis's Avatar
Whimsy?
Old 06-10-2019, 02:35 PM   #7
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,772
Guess you all scared him Off
Sent from my E6810 using Tapatalk
CityDecks is offline
The Following User Says Thank You to CityDecks For This Useful Post:
Calidecks (06-11-2019)
Old 06-10-2019, 02:43 PM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 1,244
Put a footing right next to a root, what happens when the root grows?
Rio is online now
Old 06-10-2019, 03:24 PM   #9
micro123's Avatar
Trade: Framing
Rewards Points: 50
I know the codes and already have a permit.
Codes don't tell you whether you can be an inch off of a string line, or if a sonotube can take a beating. Unfortunately.
Heck, i've worked in some rural towns where the permit office is a guys house.
Very first sentence
"Just took on my first deck building job (so go easy on me haha)."
micro123 is offline
Old 06-10-2019, 03:25 PM   #10
micro123's Avatar
Trade: Framing
Rewards Points: 50
Post hole digger
Digging bar
Shovel
Thank you for this.
You're the only person who actually answered the questions.
I'm going to re-do it.
micro123 is offline
The Following 4 Users Say Thank You to micro123 For This Useful Post:
hdavis (06-10-2019), Jaws (06-10-2019), KAP (06-10-2019), SmallTownGuy (06-11-2019)
Old 06-10-2019, 03:27 PM   #11
micro123's Avatar
Trade: Framing
Rewards Points: 50
Pergola footing.
micro123 is offline
Old 06-10-2019, 04:55 PM   #12
hdavis's Avatar
That's what the Sawzall is for, cut it right out.
Old 06-10-2019, 05:16 PM   #13
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 478
None that are any good.
Right, Mike?
Andy.
ScipioAfricanus is offline
The Following 7 Users Say Thank You to ScipioAfricanus For This Useful Post:
avenge (06-10-2019), Calidecks (06-11-2019), greg24k (06-11-2019), hdavis (06-10-2019), Jaws (06-10-2019), Robie (06-10-2019), tgeb (06-10-2019)
Old 06-10-2019, 05:30 PM   #14
micro123's Avatar
Trade: Framing
Rewards Points: 50
Right, Mike?
Andy.
Or none at least that want to provide some advice
micro123 is offline
The Following User Says Thank You to micro123 For This Useful Post:
Old 06-10-2019, 06:00 PM   #15
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,010
As a framer, would you be satisfied with foundation walls that are 2-3" off? I would certainly hope not, and that's why the guys will razz you a bit. You shouldn't have needed to ask.
Tinstaafl is offline
Old 06-10-2019, 06:07 PM   #16
micro123's Avatar
Trade: Framing
Rewards Points: 50
That's true.
People kept telling me not to worry about it, but it kept bugging me.
micro123 is offline
Old 06-10-2019, 06:13 PM   #17
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Close only counts in horse shoes and hand grenades
Irishslave is offline
Old 06-10-2019, 06:18 PM   #18
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,694
You posted your question at 11:17 AM on a Monday.
Most are probably busy working and don't get "settled in" until the evening.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 06-10-2019, 07:48 PM   #19
Fire up the BBQ
griz's Avatar
Rewards Points: 2,344
and nuclear weapons...
griz is online now
Old 06-10-2019, 08:09 PM   #20
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Techno metal posts.
EricBrancard is offline
