Firewall Question - General Discussion - Contractor Talk
Firewall Question
Old 02-22-2013, 11:15 AM   #1
flach2222's Avatar
Rewards Points: 16
Unhappy
Firewall Question
Hello,
Does anyone know the code for 5/8 firecode sheetrock between a store room (with access from outside through a garage door, but not even close to big enough for a car to be pulled in, about 10 feet deep) and a bathroom? The building inspector says I need a layer of 5/8 on both sides of the wall between the real garage. (Not 2 layers on the same side) This would be a big problem if I have to do the same thing between this bathroom & storeroom. I am converting an attached garage into a master suite, and I can't reach the building inspector.
Thanks,
flach2222 is offline
Old 02-22-2013, 04:12 PM   #2
Ret1095's Avatar
Re: Firewall Question
Is it in a house bussiness or apartment?
And what state are you in?
Ret1095 is offline
Old 02-22-2013, 05:46 PM   #3
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,354
2 layers on the same side will do the same thing (I'm assuming you don't want to hang rock in the bathroom). If he want's the airspace between layers install 1 layer and tape, then hat channel and another layer.
-Dennis
WarriorWithWood is offline
Old 02-22-2013, 06:28 PM   #4
Henn Drywall's Avatar
Trade: Drywall
Rewards Points: 25
You should be able to use shaftwall, and a layer of half inch.
Henn Drywall is offline
Old 02-22-2013, 08:15 PM   #5
flach2222's Avatar
Rewards Points: 16
Thank you everyone, I finally got a hold of the inspector, and he said I only needed firecode drywall on one side. I like the high hat idea for the next time that comes up!
He said I couldn't double up one side. By the way, I am in NH and am not new to the forum, I just opened a new account because I forgot my user name & password!
Although I have been remodeling for 30 plus years, I find this forum very helpful & recommend it to a lot of people!
[email protected]
Old 02-22-2013, 08:17 PM   #6
flach2222's Avatar
Rewards Points: 16
P.S. Are you talking about elevator shaft drywall? We call it hernia board!
That is also a good alternative! Tom
Old 02-22-2013, 11:25 PM   #7
Tech Geek
I had to do a 2 hr. rating once and we only had access to one side (ceiling). We had to do 2 layers 5/8" (staggered joints), then hat channel, then 2 more layers 5/8".
-Dennis
Old 02-23-2013, 10:36 PM   #8
flach2222's Avatar
Rewards Points: 16
Ouch! I hope it was T & M
Old 02-24-2013, 12:21 AM   #9
skillman's Avatar
Rewards Points: 1,968
Did samething in pre-school on a job years back . Ceiling where crazy fire proof plus rottin cotton in joist bays .
skillman is offline
Old 02-25-2013, 03:55 PM   #10
GCTony's Avatar
Rewards Points: 384
Two layers on one side MAY not give you the same fire resistence rating as one layer on each side. It's all about UL testing. Studs size and type, insulation, stud spacing all are factors. The inspector should have specified what rating is required and not specify an air space. What an inspector wants and what is required are often two very different things. If one looks at the USG selector, it doesn't take an air space to get to one or even two hours.
http://www.usg.com/rc/system-catalog...g-en-SA100.pdf
GCTony is offline
Old 02-25-2013, 04:00 PM   #11
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,808
Wow man, you were working in the trades when you were in preschool?
I started at about 14 years. You get me beat by a long shot.
Andy.
ScipioAfricanus is online now
Old 02-25-2013, 04:24 PM   #12
fugsly's Avatar
Trade: general
Rewards Points: 71
If i remember correctly ithe irc does specifically spell out this system, and sadly the code even in the 2012 book is still half inch gwb with a solid core door of no less than inch and 3/8.
Yes soild wood is legal, self closers are just added in 2012.
Now reality is getting your ahj to agree with anything less than 5/8 type x .......
fugsly is offline
Old 02-25-2013, 05:32 PM   #13
GCTony's Avatar
Rewards Points: 384
Ya gotta train your inspectors. The inspectors that know us know we ALWAYS ask for a code reference or "I don't understand, show me in the book" It's getting to the point that most times we don't even have to ask anymore, they automatically put the code referance on the inspection ticket.
GCTony is offline
Old 02-25-2013, 07:25 PM   #14
flach2222's Avatar
Rewards Points: 16
I like that, " I don't understand, show me the code book!"
I will definately use that!
Old 02-26-2013, 12:53 AM   #15
skillman's Avatar
Andy.
Started to young in this great field of construction. . I worked to much instead of partying during school years .
skillman is offline
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 55 01-20-2017 11:48 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
