Fireplace Not Hot Enough - General Discussion - Contractor Talk
Old 02-09-2012, 08:44 PM   #1
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Maybe this is more of a DIY question but how do I get more heat out of my fireplace?
Fireplaces in most older homes that are made of brick with an iron fire box seem to put out much more heat than mine.
My fireplace is one of those double walled steel boxes with the faux brick backing. It looks just like one of those gas fireplaces but without the fixture attached. Given that this fireplace is a much cheaper model (I guess the previous owner was being a cheapskate) which stands the reason why it's not as good as my grandmother's fireplace.
So my question- Is there anything that I can do to increase the heat output?
tedanderson is offline
Old 02-09-2012, 08:45 PM   #2
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
Re: Fireplace Not Hot Enough
Build a bigger fire?
NKLHD
knucklehead is offline
The Following 3 Users Say Thank You to knucklehead For This Useful Post:
griz (02-09-2012), J F (02-09-2012), shanekw1 (02-09-2012)
Old 02-09-2012, 10:52 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,357
LOX.
Tinstaafl is offline
Old 02-09-2012, 11:01 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 2,352
Look at a contraption like this:
http://www.fireplaceguys.com/catalog...93ui4rte31luj7
griz is online now
tedanderson (02-10-2012)
Old 02-09-2012, 11:32 PM   #5
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 2,888
Bigger fire with dry, well seasoned hardwoods.
Put fans in the intake vents of heatalator.
Add a fireback.
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
The Following User Says Thank You to Diamond D. For This Useful Post:
Old 02-09-2012, 11:35 PM   #6
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 530
What about an insert?
cdkyle is offline
Old 02-10-2012, 08:16 AM   #7
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 400
Fireplaces aren't really much for heat output as it is.
How tall is it?
I think solid masonry fireplaces just capture and distribute more heat through the mantle.
NYCB is offline
Old 02-10-2012, 08:57 AM   #8
The hearth is 18 inches off of the floor and the top of the opening sits at 48 inches.
When I burn oak and maple I can feel the heat but it just doesn't radiate the same way that the solid brick ones do. And before I gut it out and have a "real" one built I was hoping that someone here knew something that I didn't.
Old 02-10-2012, 09:32 AM   #9
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
not sure exactly what you dealing with but it sounds similar to what i have, just smaller.
what kind of damper is in it? mine is a slot with a spring loaded door and a lever in the box.......5" x 34" so when it used to be fully open ALL HEAT went up it. it was originaly an open or shut thing but a coat hanger and a few holes drilled and i could vary it.
how far back in the box is the fire? closer to front the better
You can buy a decent blower motor and construct a manifold that goes under the fire up the back and out again for $100 if you can weld. I saw plans for one that incorperated an attic thermostat and was automatic...... My grandad was a farmer and built his own in the 80s it made a huge difference and even saved wood.
I gave up on my firplace, wood is expensive here, $300+ a cord or a 200 mile drive to get your own and that ends up costing more with ventfree gas my entire heating bill for winter runsabout $200
Red Adobe is offline
Old 02-10-2012, 12:21 PM   #10
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
Wow,that is expensive.
I got a chord and a half this fall for $180.
OTOH, I have a duel fuel(hybrid) system in my house. If i'ts above 40 it runs on electric,but 40 and below and the gas kicks in. They just came yesterday to refill and 98 gallons is gonna run me about $400.
Needless to say I'm going to have to start throwing the wood in again. It's just been such a warm winter that i haven't got in the habit of doing it.
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 02-10-2012, 04:26 PM   #11
NYCB's Avatar
Rewards Points: 400
I'm a stove guy myself. I run it wide open for about an hour in the morning then damper it way down to get a good pile of coals burning slow all day.
I can do wood or coal too, so for those long trips away from the house, just fill the box with coal and it will be fine for 24 hours.
NYCB is offline
achieving a paintable fireplace surround with cement board ajmackenzie Painting & Finish Work 17 01-23-2012 03:30 PM
Basement & Mainlevel Fireplace - Pre-fab Vs. Masonry? KC S Architecture & Design 1 04-04-2011 02:03 PM
Heating new Family Room w/ gas fireplace? Slowtrawl HVAC 56 06-20-2010 05:50 AM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
