Fire Rating Of Drop Ceiling - General Discussion - Contractor Talk
Old 04-29-2009, 07:26 AM   #1
shesaremonclus's Avatar
Trade: Home Repair
Rewards Points: 75
The city's building office is requiring my client to inform them of the fire rating of the drop she has installed in order to get a CofO for a church that is in this particullar space. The ceiling has been installed for quite some time even before she owned the property, they are requiring a one hour rating ceiling. The only markings are on the back side and say USG and W. Im thinking that the W might stand for something. Does anyone have any imput as to how I can determine the rating of the ceiling.
shesaremonclus is offline
Old 04-29-2009, 07:37 AM   #2
Dave from Macatawa
macatawacab's Avatar
Trade: GC, cabinet maker and remodeler
Rewards Points: 250
Re: Fire Rating Of Drop Ceiling
Google "one hour ceiling assemblies". Google USG and search for one hour asseblies. The standard is two layers of 5/8" type C or X depending on what your local person will accept.
If your existing ceiling had a rating there would be a UL # stamped on it.
I don't know if there is such a thing as a one hour suspended ceiling assembly. It would require all components like the wire it hangs from to be rated. Best bet is to search and find an assembly that works. It will spell out what is needed
IMO you are in for a new ceiling.
macatawacab is offline
Old 04-29-2009, 09:21 AM   #3
buildpinnacle's Avatar
Trade: Public Insurance Adjuster
Go to a large supplier in your area with one of the tiles. ISC around here. They will know immediately what tile it is and be able to give you the specs. I don't want to come across as a [email protected]$k, but I can see this is one of your first posts. If you really didn't think of what I have suggested then I am sorry, but if you're just trying to get a quick answer without having to do the obvious recon, it comes across to me as being lazy and that's not what this forum is designed for. Not throwing darts at you, just a heads up.
Pinnacle Limited - Public Insurance Adjusters
http://pinnaclelimited.com
http://harrycane.com - An Amusement Park for Weather Freaks
buildpinnacle is offline
Old 04-29-2009, 07:00 PM   #4
General Contractor
greg24k's Avatar
Rewards Points: 8,088
USG is the largest manufacturer of building materials. Go on this webpage and get the rating for the drop ceiling you have.
http://www.usg.com/index.jsp
Good luck
greg24k is online now
Old 04-29-2009, 07:19 PM   #5
scuba's Avatar
Trade: residential remodeling
Rewards Points: 75
Then, after the homework, go buy USG's fire rated panels. They are slightly more expensive than typical, but the only way you're going to get the rating you need (and the least expensive). Or, depending on your building dept. you can go super el cheapo and cut rated drywall sheets to fit
scuba is offline
Old 04-29-2009, 08:14 PM   #6
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,429
Check this out.-----------> USG Suspended Ceilings (fire rated)
-Paul
TextureMaster.com
Checkout my YouTube Channel with 53,000 Subscribers and over 9,500,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
Old 04-29-2009, 10:39 PM   #7
easymoney's Avatar
Trade: General
Rewards Points: 250
I agree with Maca ... Macawabat... Macawaddatata ... I agree with MAC, your in for a new ceiling!
easymoney is offline
Old 04-29-2009, 11:31 PM   #8
theman's Avatar
Rewards Points: 75
N.Y. State 2003 code
706.3.5 Separation of occupancies. The fire barrier separating mixed
occupancies, or a single occupancy into different fire areas, shall have
a fire-resistance rating of not less than that indicated in 302.3.3
based on the occupancies being separated.
706.4 Continuity. Fire barriers shall extend from the top of the
floor/ceiling assembly below to the underside of the floor or roof slab or
deck above and shall be securely attached thereto. These walls shall be
continuous through concealed spaces such as the space above a suspended
ceiling. The supporting construction shall be protected to afford the
required fire-resistance rating of the fire barrier supported except for 1-
hour fire-resistance-rated incidental use area separations as required by
Table 302.1.1 in buildings of Types IIB, IIIB and VB construction.
Hollow vertical spaces within the fire barrier wall shall be firestopped at
every floor level.
theman is offline
Old 04-30-2009, 07:02 AM   #9
maurisgreen's Avatar
Trade: -
Hey guys thanks for this interesting post. This can solve my problem.
Quality Builing Material | Best Concrete Paves
maurisgreen is offline
Help! Drop Ceiling? NEW2DAGAME CT. Commercial Construction 4 04-02-2009 04:58 AM
Fire Rating Mezzanine mckellarman Commercial Construction 3 02-05-2009 01:56 AM
One hour fire rating for a truss AlLockrem Drywall 2 09-18-2008 09:31 PM
Hardi fire rating K_Tile Windows, Siding and Doors 6 09-09-2008 04:26 PM
Fire rating lathe and plaster ceiling adianz Construction 4 04-14-2007 06:02 AM
