Fence - General Discussion - Contractor Talk
Fence
Old 05-27-2015, 06:16 PM   #1
manofsteel's Avatar
Trade: electronic controls
Rewards Points: 2
Fence
had a guy look at putting up a 8ft high privacy wall that will be 8 inch blocks. The wall is free standing and will be 100 ft long. He told me I would need footings 12 inches deep and 24 inces wide.
Some other sub contractors I talked to said that 12 inches wide and 12 inches deep would be all that would be needed
any thoughts
manofsteel is offline
The Following User Says Thank You to manofsteel For This Useful Post:
TxElectrician (05-30-2015)
Old 05-27-2015, 06:22 PM   #2
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Fence
any thoughts
I done my wall with 8" blocks and done a 8" base with type 57. It's only a total of 5ft high but the wall it holding up fine. 12" base should be deep deep enough and wide enough but I would say 24" would be nicer as when I done mine when o got to a corner I wanted to move the first course back a bit but couldn't as I only done 12" wide.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-27-2015, 07:46 PM   #3
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 196
Re: Fence
any thoughts
I think all that would depend on your location and the soil conditions.
If you have expansive soils but are considered high bearing soils then maybe a deeper than wide footing is in order.
If you have medium or low bearing soils then a wider footing might be the ticket.
Sandy soil with not much chance of frost heave then 12 x 12 might do it.
If it is on the moon then no footing is required and just go one block down.
Andy.
ScipioAfricanus is offline
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
Eaglei (05-30-2015)
Old 05-27-2015, 10:15 PM   #4
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Re: Fence
and seeing what other similar types of jobs they have done in that area.
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 05-29-2015, 09:46 PM   #5
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
Re: Fence
its all about frostlines and expected loads, next thing is legality of the 8ft, as far as i know most place have a 6ft rule.
Red Adobe is offline
Old 05-30-2015, 08:24 AM   #6
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Rewards Points: 104
Re: Fence
Tall unsupported wall....I would not gamble with saving a few bucks on the footing. Do you have a frost consideration? I would be looking at deeper. Are there going to be any expansion joints in the wall?
Kevin
www.BadcoDoors.com
Pearce Services is online now
Old 05-30-2015, 08:50 AM   #7
Dan_Watson's Avatar
Rewards Points: 2,748
Re: Fence
Where are you located? I want to keep an eye on the local news for when this thing falls over...
That's a lot of surface area for the wind to catch.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
Kowboy (05-30-2015)
Old 05-30-2015, 09:38 AM   #8
CO762's Avatar
Re: Fence
He could be wanting to put a fence on his property and not have the expense of renting or the energy of manually digging holes and/or just assemble it and be done. Windbreak fences are just plopped down too, but they're temporary, so that's why they do it. And they're also braced on each side the whole length--which wouldn't look good in this guys yard.
CO762 is offline
Old 05-30-2015, 10:55 AM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 710
Re: Fence
I just did one about 30' long & 6' high.
Footing is 3' wide x 2' deep, w/ a #5 cage.
#5 verticals @32" oc & #4 horizontal in every other course.
Then it was grouted solid.
8' tall will likely require a difficult to obtain variance.
Why is there seem to be such an aversion to hiring appropriate engineers for projects. Especially ones a tad out of the ordinary like this.
An engineer takes in to account soil conditions, and various other factors such as seismic, wind, snow loads etc etc.....as appropriate to the job and conditions.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Dan_Watson (05-30-2015), Eaglei (05-30-2015)
Old 05-30-2015, 02:25 PM   #10
CO762's Avatar
Re: Fence
speaking of variances, my bet is there's also a setback rule and/or someone doesn't want to go down where utilities can be located. If you plop down a huge priv-acy fence on top of the dirt, can do right to the lot line. The only concern then is which side of it will it fall on when it falls.
CO762 is offline
Old 05-30-2015, 10:17 PM   #11
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 544
Re: Fence
Just curious... why do some ho threads get closed and other don't?
TxElectrician is offline
Old 05-30-2015, 10:40 PM   #12
PCI
PCI's Avatar
Trade: contractor
Rewards Points: 848
Re: Fence
The reason for no engineer is that it is "just a fence" . Even though it's a butt load of money, I don't want to spend any more!
PCI is offline
Old 05-30-2015, 10:45 PM   #13
Fire up the BBQ
griz's Avatar
Rewards Points: 710
Re: Fence
Good point....
griz is offline
Old 05-30-2015, 10:46 PM   #14
Fire up the BBQ
griz's Avatar
Rewards Points: 710
Re: Fence
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
griz is offline
Arched-panel Grouped Baluster Fence basswood Decks & Fencing 40 10-02-2012 06:03 AM
cedar fence and small historic deck swartzj81 Decks & Fencing 2 09-02-2012 03:01 PM
Construction detail Q?, re: a RW fence w/ Horizontal boards / slats Will Johnson Decks & Fencing 16 07-08-2012 10:33 AM
Fence stain Rslstructures Construction 3 06-22-2012 11:13 PM
DW744 Fence Adjustments TBFGhost Tools & Equipment 3 05-30-2012 03:21 PM
