Exterior Painting With Scissor Lift - General Discussion - Contractor Talk
Old 02-19-2019, 03:44 AM   #1
Scott Ma's Avatar
Trade: painting
Rewards Points: 4
Hello all
I am a painter in Oxford MI. I am seriously considering purchasing
a scissor lift. I realize I will be limited because of landscaping and other
obstructions however I would think the time it would save me in areas
that are accessible would make it a worthwhile investment. Anybody
have any thoughts on the matter? I realize a boom would be preferable
but storage is an issue. Thank you in advance.
Scott McKenzie
Scott Ma is offline
Old 02-19-2019, 07:53 AM   #2
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,892
Re: Exterior Painting With Scissor Lift
Smaller Scissor lift is pretty much useless for anything that isnt on perfectly smooth flat ground even if it has the rugged tires
Donít know if that would affect your decision or not depending on the type of work you do and where itís at
A normal scissor lift even on blacktop that is not level is a hairy experience when you get a couple feet off the ground
Windycity is offline
The Following 2 Users Say Thank You to Windycity For This Useful Post:
dayexco (02-19-2019), TimNJ (02-19-2019)
Old 02-19-2019, 09:32 AM   #3
Scott Ma's Avatar
Trade: painting
Rewards Points: 4
Thanks for the reply. I will have to look into a trailer able
boom lift. Any thoughts on that?
Scott Ma is offline
Old 02-19-2019, 09:45 AM   #4
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,372
Rent and include the price of rental in your quote. Let the rental house, own, maintain, deliver and pick up your lift(s). Renting also allows you to pick and choose a lift best suited to the job.
Fishindude is offline
The Following 2 Users Say Thank You to Fishindude For This Useful Post:
finisher65 (02-20-2019), Mordekyle (02-19-2019)
Old 02-19-2019, 10:08 AM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2
What you really need is a Z boom that has outriggers for leveling. No sure of the make though, but I guy I know that does tree trimming has one nice small unit would go up like 60'
Randy Bush is online now
Old 02-19-2019, 01:17 PM   #6
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,350
I would say go to your rental yard and rent a few different models and see how they work for you before diving into it.
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
Old 02-19-2019, 05:27 PM   #7
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 3,058
I use a lot of lifts of various styles based on our needs for a particular job. I always rent them and pass a long any operating costs and a small mark up for having my employees certified to operate such lifts which covers the training costs.
There are only a couple of factors that would make me consider owning one, if a lift is never available when i need one, or if i was using them constantly. With good planning availability is rarely an issue.
The downside i see owning a lift is i would never have the style i need, repair costs and any liability for certification and of course insurance coverage. If i had to own one lift it probably not be a scissor a lift, but that depends on the type of work you will use it primarily for.
Ohio painter is offline
Old 02-19-2019, 05:43 PM   #8
hdavis's Avatar
Rewards Points: 4,314
I couldn't use one at all. Nothing is level enough.
hdavis is online now
Old 02-19-2019, 05:56 PM   #9
Donohue Const's Avatar
Rewards Points: 1,726
I'm not a painter, but it seems to me a scissor loft would be almost useless on 95% of the jobs
a trailer style or self propelled boom loft would be best
how often can you really drive right up to the place you painting and have almost level geound?
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is online now
Old 02-20-2019, 02:20 AM   #10
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & wel
Rewards Points: 5,482
if you buy one you will be cursed with never needing it. i always had tons of jobs i could have taken and made good money until i bought one. now i hardly use it.
theres pros and cons to a scissor, stick, or z boom so you need to buy all 3.
Exterior painting with scissor lift-genie-1.jpg   Exterior painting with scissor lift-genie-2.jpg
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 02-21-2019, 06:31 PM   #11
Michael, I am curious, what does it take to move one of those lifts to and from the jobsite? certainly another consideration for the OP.
Old 02-21-2019, 07:02 PM   #12
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
That's the story of my life right there....10th time renting "that's enough I'm buying one!". Famous last words...
Inner10 is offline
Ohio painter (02-22-2019)
Old 02-23-2019, 08:57 AM   #13
builditguy's Avatar
Rewards Points: 2,162
Everything here is right.
I've had all kinds. I don't have any now. Repair bills all the time. A small one for interior is good, in an unfinished space. Won't do anything if not on a hard surface.
JLG (type) straight boom is great, but they weigh alot. They also don't drive on the trailer themselves. Have to be winched up. The new 4x4 ones are probably better. I didn't have that luxury. You drive one of these in someone's yard, plan on deep ruts and probably getting stuck.
Towable lift, works good, for what it is. Takes a fair amount of room to get it backed into where you want it.
Always get a rotating basket. Well worth it. Some towables have a manual rotating basket. It works fine. I actually like it, because it's one less thing to break down.
If I were to buy another one, which is a possibility. (I can't do ladders very well anymore.)
I would get a small drivable one, with outriggers. The advantage I see is they are much lighter. They can be, because you need outriggers. You can drive it to move it. I suspect it will be less wear and tear on a customers yard.
Of course if you do new construction, it won't matter. Remodeling, it will make a difference.
builditguy is offline
Old 02-25-2019, 08:34 PM   #14
Ruts in the yard is a good point, we rented a 45' Knuckle boom 4 WD and man that thing was heavy, we destroyed a yard with it. Towable lifts are much lighter, another factor in the decision making process.
Old 02-25-2019, 08:45 PM   #15
Randy Bush's Avatar
Rewards Points: 2
I buy cull 2x12s to run mine on if there is grass.
The Following User Says Thank You to Randy Bush For This Useful Post:
Ohio painter (02-26-2019)
Old 02-28-2019, 12:23 AM   #16
EVIL GENIUS
This one weighs 9900lbs and I haul it on an 18ft equipment trailer and its not fun to load or unload. It really needs a hydraulic drop deck trailer.
Originally Posted by builditguy View Post
E
I too would get one with outriggers. The one I have in the pictures was perfect for that job because it doesn't use outriggers it was much faster. Me and dad wired that building that was 75 wide 210 long with an attached horse barn and my dad never got off the ground one time. The downside to an outrigger machine is you have to lower the machine and raise the outriggers to move. This one I could stay up and just move down the building pulling wire or running conduit.
U.S. Coast Guard
