Expansion Joint Caulk - General Discussion - Contractor Talk
Old 08-11-2012, 03:31 PM   #1
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
Have a customer who wants to caulk up the expansion joints around his swimming pool. Last time I did this was around tile and we taped the tile edges and used a laticrete caulk to match the grout. This is washed gravel so taping off isnt and option. I was thinking of using a self leveling caulk to fill just below the surface but I am only finding grey caulk locally and online I get brands I haven't heard of. Thoughts?
SuperiorHIP is offline
Old 08-11-2012, 03:36 PM   #2
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Expansion Joint Caulk
http://www.dap.com/product_details.a...90&SubcatID=27
This one can be painted.
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
SuperiorHIP (08-11-2012)
Old 08-11-2012, 04:47 PM   #3
They have that one at lowes and the paint store but its grey. I need a tannish color to blend with the washed gravel.
Old 08-11-2012, 04:57 PM   #4
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 704
Do you have a supplier of sonneborn products? They have self leveling urethane sealants in many colors...
overanalyze is offline
Old 08-11-2012, 04:58 PM   #5
Gonna die a glass guy
ccappaul's Avatar
Trade: Skylights and Glazing
Rewards Points: 250
Smalley & company ......? Online
Had to look.
Smalleyandcompany.com
ccappaul is offline
The Following User Says Thank You to ccappaul For This Useful Post:
Old 08-11-2012, 05:28 PM   #6
Old Meets New's Avatar
Trade: General construction and remodeling and antique re
You can maby try a unsanded tile caulk which comes in a larger variety of colors but usually shrinks more than regular caulks the sanded dosent shrink as much to me. Since you can't tape of try applying carefully and use a grout sponge lightly applying pressure and not to wet to remove access caulk.
Old Meets New is offline
The Following User Says Thank You to Old Meets New For This Useful Post:
Old 08-11-2012, 05:52 PM   #7
Crystal Ball Malfunction
jps614's Avatar
Trade: Construction / Remodel / Home Improvement
Rewards Points: 150
Sikaflex has a self - leveling sealant in a sandstone color. They sell it at home cheapo around here, Im sure you could find it somewhere.
jps614 is offline
The Following 3 Users Say Thank You to jps614 For This Useful Post:
smalpierre (08-12-2012), SuperiorHIP (08-11-2012)
Old 08-11-2012, 06:14 PM   #8
PoolRepairsOnly's Avatar
Trade: Swimming Pools
Rewards Points: 83
Deck-O-Seal is available at pool supply houses. It's a two part self-leveling liquid goo designed for this. It is available in tan. For added durability you can sprinkle sand on top after you've gone around the pool with it.
PoolRepairsOnly is offline
The Following 2 Users Say Thank You to PoolRepairsOnly For This Useful Post:
Old 08-11-2012, 06:59 PM   #9
I searched home depot already but looked in the paint area. Looking online I see they have it here and now that I think about it I think its over by the sonnotubes. Thank you.
Thanks for the help guys.
Old 08-12-2012, 12:06 PM   #10
jps614's Avatar
Rewards Points: 150
Yea, in my stores it is near the concrete finishing stuff.
jps614 is offline
Old 08-12-2012, 12:46 PM   #11
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Yes it is near concrete finishing trowels, installed it at my rental front sidewalk, it forgets to stop being sticky an dirt clings to it, I would go check it , put it in about 4 years ago, but was foreclosed on,
Getting the exact height is tricky, might look funny
Maori has a new caulk with silicone added to it, I'm sure dirt will cling to this also,
Grouting with barwalt system where a special sponge on handle leaves a fuller grout joint, regular grout sponges pull too much of the joint out.
MIKE ANTONETTI is offline
Old 08-12-2012, 02:49 PM   #12
CHRenewal's Avatar
Trade: Residential Design/Build Remodeler & Home Builder
Rewards Points: 75
Only use Deck-O-Seal. It is made for this application. You can get the tan and add silica to the top. Its the BEST! for this application.
CHRenewal is offline
Old 08-15-2012, 07:37 AM   #13
stp57's Avatar
Trade: carpenter/ handyman
Rewards Points: 1,000
Watch the low spots. That self leveling stuff will pool up on you if you are not careful & it is very difficult to clean up overspill. Use backer rod for large gaps.
Steve
stp57 is offline
joint cracked twice in a week r4r&r Drywall 9 06-29-2012 09:08 PM
Re-inforced Concrete slab, help with layout of rebar and expansion joint.. Little Excavation & Site Work 6 04-01-2012 10:05 AM
Tub-Tile joint, grout or caulk?? Aframe Tiling 11 06-27-2011 01:55 PM
expansion joint jpeff General Discussion 6 12-08-2009 11:22 PM
Adding in an expansion joint DeanV Drywall 8 01-01-2009 12:25 PM
