Epoxyed Sink To Corian Counter. - General Discussion - Contractor Talk
Old 09-24-2018, 11:38 PM   #1
Unger.const's Avatar
Rewards Points: 3,014
So how do you cut though the epoxy on a bathroom sink to countertop (undermount)? Plus they over did it with the epoxy. I took my oscillation saw. And went through a couple blades and still didn't cut the epoxy out. Need to replace the sink.
No clips. Or silicone. All epoxy. It's at my brothers place . If it were anyone else I would even mess with it.
I've already googled it alot. Several people asking how to cut through it but no answers that I saw. Any suggestions on how to remove sink?.
Unger.const is offline
Old 09-25-2018, 12:38 AM   #2
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: Epoxyed Sink To Corian Counter.
SmallTownGuy is offline
Old 09-25-2018, 12:44 AM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 388
wtf....call kowboy....
griz is offline
The Following 5 Users Say Thank You to griz For This Useful Post:
pinwheel (09-30-2018), Seven-Delta-FortyOne (09-25-2018), SmallTownGuy (09-25-2018), Unger.const (09-25-2018), Xtrememtnbiker (09-26-2018)
Old 09-25-2018, 12:48 AM   #4
Mordekyle's Avatar
Rewards Points: 5,486
Heat the sink with a propane torch till the epoxy melts??
(No clue, Just throwing one out there.)
Mordekyle is offline
Old 09-25-2018, 05:37 AM   #5
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 8,486
I put a sink removal bit on a router: https://www.amanatool.com/57166-carb...th-of-cut.html
It's pretty dusty.
The guy in the above video is an idiot. All non-solid surface sinks must be mechanically fastened. No Liquid Nails as it will bleed through some stones, just silicone to act as a gasket while a HUSH does the work: https://www.braxton-bragg.com/index....bc/0,8459,9145
Check out the third post down here, please: https://forum.stonefabricatorsallian...lation#p235362
Kowboy is offline
The Following 2 Users Say Thank You to Kowboy For This Useful Post:
sparehair (09-25-2018), Texas Wax (09-25-2018)
Old 09-25-2018, 11:39 AM   #6
Originally Posted by SmallTownGuy View Post
I think that was just silicon. Didn't see epoxy on the flange when he dropped it down .
I wish this was just silicone. It has twice the epoxy it needs.
Old 09-25-2018, 11:40 AM   #7
Think the corian will do ok with me and a torch? It's only bright white now.......lol
The Following User Says Thank You to Unger.const For This Useful Post:
Old 09-25-2018, 12:36 PM   #8
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,757
Yikes. In pieces? Put down lots of cardboard for protection, then hammer, chisel, grinder with vacuum shroud.....There's a chance it could crack, though.
MarkJames is offline
Old 09-25-2018, 02:16 PM   #9
Mordekyle's Avatar
Not a clue...
Old 09-25-2018, 02:25 PM   #10
My fear is cracking the counter.
Old 09-25-2018, 02:37 PM   #11
Texas Wax's Avatar
Rewards Points: 1,938
China bowl - Wouldn't risk trying to break the sink up. Really stuck with using a grinding wheel to cut sink free just belwo the epoxy. And then grind or belt sand the epoxy off.
I'd take the top free and do the removal outside, if possible.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 09-25-2018, 02:45 PM   #12
XJCraver's Avatar
Trade: Building Official
Rewards Points: 2
How big a concern is dust? I haven't swung a hammer in a while and I've never done this and I'm not sure it'd work, but - could you cut all the way around the bowl just below the counter with a grinder and cut-off wheel to remove everything but the rim, and then use a grinding wheel to take the rim off once it's gone? Unless there's an epoxy-dissolver of some sort, that'd probably be what I tried.
Or use the bit Kowboy posted, but I'd probably try it with tools I had first if it was a one-off thing.
XJCraver is offline
Old 09-25-2018, 02:46 PM   #13
XJCraver's Avatar
Rewards Points: 2
Faster typing than me
XJCraver is offline
The Following User Says Thank You to XJCraver For This Useful Post:
Texas Wax (09-30-2018)
Old 09-30-2018, 01:38 PM   #14
Kowboy
Kowboy's Avatar
Trade: Countertops
If that is a porcelain bowl, I'd pull the top and chip off as much of the polyester (it's not epoxy) as possible. Tape some tripled up paper towels to the joint, saturate them with acetone, cover them with clear plastic wrap to prevent evaporation, and tape the plastic wrap. You should be able to get the polyester to fail.
You could simply buy another sink with a footprint larger than the existing. Cut through the top with a jigsaw, secure the new bowl in place, run a bowl finishing bit around the raw edge, sand and refinish the top.
Kowboy is offline
The Following User Says Thank You to Kowboy For This Useful Post:
corian counter for pass through A. Finelli Carpentry 7 10-10-2014 08:26 AM
Corian sink for granite top EricBrancard Kitchens & Baths 6 07-16-2013 07:21 AM
A Visitor from Paint / a plumbing question / bathtub backs up from sink JTemple Plumbing 24 02-12-2013 07:33 AM
Removal of an under counter sink rservices General Discussion 19 03-20-2012 07:58 PM
Urgent: help on under mount sink on tile counter top unhique Kitchens & Baths 17 10-23-2010 10:04 AM
