-   General Discussion (https://www.contractortalk.com/f11/)
-   -   Epoxyed sink to corian counter. (https://www.contractortalk.com/f11/epoxyed-sink-corian-counter-411609/)
Unger.const 09-24-2018 11:38 PM
So how do you cut though the epoxy on a bathroom sink to countertop (undermount)? Plus they over did it with the epoxy. I took my oscillation saw. And went through a couple blades and still didn't cut the epoxy out. Need to replace the sink.
No clips. Or silicone. All epoxy. It's at my brothers place . If it were anyone else I would even mess with it.
I've already googled it alot. Several people asking how to cut through it but no answers that I saw. Any suggestions on how to remove sink?.https://uploads.tapatalk-cdn.com/201...b101fb93e5.jpg
SmallTownGuy 09-25-2018 12:38 AM
griz 09-25-2018 12:44 AM
wtf....call kowboy....:whistling:laughing:
Mordekyle 09-25-2018 12:48 AM
Heat the sink with a propane torch till the epoxy melts??
(No clue, Just throwing one out there.)
Kowboy 09-25-2018 05:37 AM
I put a sink removal bit on a router: https://www.amanatool.com/57166-carb...th-of-cut.html
It's pretty dusty.
The guy in the above video is an idiot. All non-solid surface sinks must be mechanically fastened. No Liquid Nails as it will bleed through some stones, just silicone to act as a gasket while a HUSH does the work: https://www.braxton-bragg.com/index....bc/0,8459,9145
Check out the third post down here, please: https://forum.stonefabricatorsallian...lation#p235362
Unger.const 09-25-2018 11:39 AM
Originally Posted by SmallTownGuy (Post 7369977)
I think that was just silicon. Didn't see epoxy on the flange when he dropped it down .
I wish this was just silicone. It has twice the epoxy it needs.
Unger.const 09-25-2018 11:40 AM
Think the corian will do ok with me and a torch? It's only bright white now.......lol
MarkJames 09-25-2018 12:36 PM
Yikes. In pieces? Put down lots of cardboard for protection, then hammer, chisel, grinder with vacuum shroud.....There's a chance it could crack, though.
Mordekyle 09-25-2018 02:16 PM
Not a clue...
Unger.const 09-25-2018 02:25 PM
My fear is cracking the counter.
Texas Wax 09-25-2018 02:37 PM
China bowl - Wouldn't risk trying to break the sink up. Really stuck with using a grinding wheel to cut sink free just belwo the epoxy. And then grind or belt sand the epoxy off.
I'd take the top free and do the removal outside, if possible.
XJCraver 09-25-2018 02:45 PM
How big a concern is dust? I haven't swung a hammer in a while and I've never done this and I'm not sure it'd work, but - could you cut all the way around the bowl just below the counter with a grinder and cut-off wheel to remove everything but the rim, and then use a grinding wheel to take the rim off once it's gone? Unless there's an epoxy-dissolver of some sort, that'd probably be what I tried.
Or use the bit Kowboy posted, but I'd probably try it with tools I had first if it was a one-off thing.
XJCraver 09-25-2018 02:46 PM
Faster typing than me :thumbsup:
Kowboy 09-30-2018 01:38 PM
If that is a porcelain bowl, I'd pull the top and chip off as much of the polyester (it's not epoxy) as possible. Tape some tripled up paper towels to the joint, saturate them with acetone, cover them with clear plastic wrap to prevent evaporation, and tape the plastic wrap. You should be able to get the polyester to fail.
You could simply buy another sink with a footprint larger than the existing. Cut through the top with a jigsaw, secure the new bowl in place, run a bowl finishing bit around the raw edge, sand and refinish the top.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
