Eliminate Useless Unexperienced Employee Applicants - Page 3 - General Discussion - Contractor Talk
Old 04-10-2015, 09:13 PM   #41
mski's Avatar
Trade: home improvements
Rewards Points: 502
Re: Eliminate Useless Unexperienced Employee Applicants
Originally Posted by Builders Inc. View Post
Must have tool bags hand tools and fall restraint harness/system?
OSHA requires you as an employer to provide personal fall protection and you are also responsible to have your employees trained in proper use of personal fall protection.
mski is offline
Old 04-10-2015, 11:00 PM   #42
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,546
Originally Posted by m1911 View Post
What's a lookout?
What's a girder?
What is R.O?
What does O.C. mean?
Orange County!
Calidecks is offline
Old 04-10-2015, 11:03 PM   #43
GC/carpenter
Calidecks's Avatar
Originally Posted by griz View Post
What are the nominal dimensions of a 2x6?
What is the length of a stud for a 9' wall?
Excluding built up corners & partitions, how many studs are in a wall that is 10' long?
What does the term 5/12 mean?
What is PT lumber used for?
What are batter boards used for?
How would you determine if a 12' tall was is plumb?
What does plumb & line mean?
Explain how you would "line" a wall?
What is a plumb cut on a rafter?
Describe a hip roof?
What is a GFCI?
Given a set of plans, what does the scale 1/4" / ft mean?
What is the purpose of a header?
What is the importance of a shear wall?
What is the best way to alter a roof truss if it is too long?
Do you know what OSHA is?
What is the best way to pin up a guard on a skil saw?
On a wall that is 16" oc what is the distance from the end to the edge of the first stud?
Why is it important to keep a job site neat?
What does the term "rip" mean in cutting lumber?
Why do you think it is important to be at work,on time, every day?
On a stick framed roof what is a collar tie?
What is a TJI/Glulam/LVL?
What is the difference between OSB and plywood?
What does the term blind nail mean?
If you were told to "crown" the joists what would you do?
There's more but you get the idea.....
I'm going to send this list to a framing foreman buddy.
Old 04-11-2015, 06:26 AM   #44
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 335
Not sure why you guys are trying to reduce your potential employees down to zero.I require a car, a pulse, and at least a smidgen of ambition.Everything else I can teach you. For the most part, I would rather hire a teachable guy over a know it all.
Easy Gibson
Warren is online now
The Following 3 Users Say Thank You to Warren For This Useful Post:
1985gt (04-13-2015), apkole (04-11-2015), rustyjames (04-11-2015)
Old 04-11-2015, 07:22 AM   #45
Easyfier of Complexitries
digiconsoo's Avatar
Trade: Framing Components
Rewards Points: 1,552
You make a valid point.
So what questions would you ask to see if they have enough ambition and are teachable enough to be profitable for you?
The interview questions above, for the most part, have solid answers. You can say yes, he has this knowledge and experience, or no, he doesn't based on the answers.
What do you ask to judge ambition and teachability?
Originally Posted by hdavis View Post
It's probably better you write about something where you aren't functionally ignorant, you're just embarrassing yourself.
Originally Posted by tipitop View Post
Trump is lucky he didn't mess with me.
http://www.digiconsoo.com
digiconsoo is offline
Old 04-11-2015, 07:29 AM   #46
Geometrist
Warren's Avatar
Rewards Points: 335
I just talk to them like a person. After the initial questions about transportation and experience, I ask about where they live, other places they have worked, etc. Just get them talking. You can tell a lot about a person by the words they choose, what they talk about, etc.
I admit, I am not great at hiring either. I am pretty picky. My last two attempts at hiring someone ended up with nothing. I have a friend who has a couple of employees, and I will take a couple guys for a week or two if we get really busy. Running a CL ad will get me about 8 or 10 responses over a two week period. Half of those don't get called back after I review their resume, or read their email responses. The other half disqualify themselves somewhere in our conversation.
Easy Gibson
Old 04-11-2015, 08:59 AM   #47
carpenter uk's Avatar
Trade: carpentry
Rewards Points: 655
Why dont you run it like a game show and start with 25, whittle them down as the day goes on with various challenges
You could even get a film crew in, it would make for a good show
carpenter uk is offline
The Following User Says Thank You to carpenter uk For This Useful Post:
Kowboy (04-11-2015)
Old 04-11-2015, 09:18 AM   #48
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
I don't know about framers, per se, but best hires are those coming off other jobs for one reason or another (the good, acceptable reasons). So it's a timing thing, as much as anything else. I had a guy help me on a couple projects who was a framer and had worked on all sorts of multi-unit stuff, large homes, etc.
Thinking back on it, there were a couple quick indicators of his quality & ambition:
he wanted to start early every day...the earlier the better.
he had his van full of the right tools
on a job where we needed to do some work on roof vents, it was no big deal to him. He pulled out his safety gear and climbed right up.
Any job I presented, he knew how to do and just started in...no thinking how to do it (and I can detect b.s a mile away)
The reason he was available is that he was working for a GC and the current projects dried up a little bit. The GC wanted him to be an independent contractor, which was fine for him, as it freed him up for projects as they came along. Something like that.
MarkJames is offline
Old 04-11-2015, 09:19 AM   #49
fourcornerhome's Avatar
Trade: home improvement contractor
Rewards Points: 1,626
I'm out. Been doing this for almost 40 years and I've never heard of a "hip block".
fourcornerhome is offline
The Following 2 Users Say Thank You to fourcornerhome For This Useful Post:
MarkJames (04-11-2015), slowsol (04-11-2015)
Old 04-11-2015, 11:07 AM   #50
Unger.const's Avatar
Rewards Points: 2,926
Hire for attitude. .....train for skill.
The other way around is a pain.
Unger.const is offline
New Employee Procedure? islandbuilder Business 0 04-27-2010 10:06 AM
Employee Damage yarruM General Discussion 2 04-02-2010 06:02 PM
Qualified Employee... How much? PlumbingPro's General Discussion 2 02-05-2010 07:50 PM
Hiring a New Employee (First Time) CookeCarpentry Business 9 05-09-2009 07:58 AM
Illinois Employee Classification Act, New Get Tough Policies Ed the Roofer Business 0 02-13-2008 04:05 PM
