Eliminate Useless Unexperienced Employee Applicants - General Discussion - Contractor Talk
Old 04-09-2015, 08:50 PM   #1
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Certified Building Contractor
Rewards Points: 1,426
So we are growing, thats a plus! Now comes the time to expand our man power. We currently have two in the office/shop and five in the field. I would like to add three more to make two 4 men crews. We can pound out some work, IF we employee the right people. I've posted in craigslist before, what a joke. We have now posted in local papers and local online searches. They are turning up some good results. So we are doing the hire 25 and fire 20 to weed out the bad. I recently had an applicant say he had framing experience and had worked in the construction field for about 3 to 5 years. This kid couldn't even read a tape. What a waste of my time. Why would you apply for an "experienced framer wanted" position with no skills. I had to let him go. I was thinking about making a questionnaire for applicants to fill out. Something around 15 questions to eliminate the ones that are exaggerating their experience. Ive come up with about 5 questions so far. I need some more. Feel free to chime in.
1) How would you describe a hip block?
2) What is plumb and level?
3) What does 3,4,5 mean to you?
4)What is a jack/cripple?
5) What is a header?
I figure if they can't answer these then their work experience is bogus. What else can I add? I'm blank as a fart.... My crew leader wanted to put in the add "building your parents a deck doesn't consist of experience." I wanted to say "hanging pictures is not framing experience"... Ha.
Builders Inc. is offline
Old 04-09-2015, 08:55 PM   #2
Easyfier of Complexitries
digiconsoo's Avatar
Trade: Framing Components
Rewards Points: 1,552
Re: Eliminate Useless Unexperienced Employee Applicants
How many sixteenths in an inch?
Originally Posted by hdavis View Post
It's probably better you write about something where you aren't functionally ignorant, you're just embarrassing yourself.
Originally Posted by tipitop View Post
Trump is lucky he didn't mess with me.
http://www.digiconsoo.com
digiconsoo is offline
The Following User Says Thank You to digiconsoo For This Useful Post:
Builders Inc. (04-09-2015)
Old 04-09-2015, 08:56 PM   #3
There we go! Keep er coming...
Old 04-09-2015, 09:02 PM   #4
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 856
Do you have a license, will you show up on time, can you leave your drama at home for 9 hours?
overanalyze is offline
Old 04-09-2015, 09:02 PM   #5
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
What's a lookout?
What's a girder?
What is R.O?
What does O.C. mean?
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
The Following 2 Users Say Thank You to m1911 For This Useful Post:
Builders Inc. (04-09-2015), NJGC (04-09-2015)
Old 04-09-2015, 09:13 PM   #6
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,884
What kind of hammer do you have and why?
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following 3 Users Say Thank You to heavy_d For This Useful Post:
Builders Inc. (04-09-2015), Jaws (04-10-2015), NJGC (04-09-2015)
Old 04-09-2015, 09:19 PM   #7
Donohue Const's Avatar
Rewards Points: 1,550
Do you have a drivers license and a car?
I have had some say no!
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
The Following 2 Users Say Thank You to Donohue Const For This Useful Post:
Builders Inc. (04-09-2015), MHElectric (05-07-2015)
Old 04-09-2015, 09:20 PM   #8
digiconsoo's Avatar
How much dirt is there in a hole 3 feet deep, 6 ft long and 4 ft wide?
Old 04-09-2015, 09:22 PM   #9
m1911's Avatar
Do you know how to properly and safely operate an m2344 board stretcher?
That'll get rid of the BS'ers...
m1911 is offline
Old 04-09-2015, 09:23 PM   #10
m1911's Avatar
At least they were honest...
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
Donohue Const (04-09-2015)
Old 04-09-2015, 09:27 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 3,054
What are the nominal dimensions of a 2x6?
What is the length of a stud for a 9' wall?
Excluding built up corners & partitions, how many studs are in a wall that is 10' long?
What does the term 5/12 mean?
What is PT lumber used for?
What are batter boards used for?
How would you determine if a 12' tall was is plumb?
What does plumb & line mean?
Explain how you would "line" a wall?
What is a plumb cut on a rafter?
Describe a hip roof?
What is a GFCI?
Given a set of plans, what does the scale 1/4" / ft mean?
What is the purpose of a header?
What is the importance of a shear wall?
What is the best way to alter a roof truss if it is too long?
Do you know what OSHA is?
What is the best way to pin up a guard on a skil saw?
On a wall that is 16" oc what is the distance from the end to the edge of the first stud?
Why is it important to keep a job site neat?
What does the term "rip" mean in cutting lumber?
Why do you think it is important to be at work,on time, every day?
On a stick framed roof what is a collar tie?
What is a TJI/Glulam/LVL?
What is the difference between OSB and plywood?
What does the term blind nail mean?
If you were told to "crown" the joists what would you do?
There's more but you get the idea.....
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
Builders Inc. (04-09-2015), Creter (04-11-2015), Donohue Const (04-09-2015), NJGC (04-09-2015)
Old 04-09-2015, 09:29 PM   #12
summithomeinc's Avatar
Trade: Painter/Handyman
Rewards Points: 2,422
In my ads I say must wear whites. Don't know how that translates to framing but it weeds out 98% of the guys with zero experience.
What does a carpenter have to have that costs enough to make a bull****ter not apply? I'd put that in my ad for help wanted.
I need more tools.
summithomeinc is offline
The Following User Says Thank You to summithomeinc For This Useful Post:
Old 04-09-2015, 09:29 PM   #13
Thats a BIG one!!!! Gezz I cant stand that crap. Like we need more stress? It's like the military, just shut up and color....
Old 04-09-2015, 09:30 PM   #14
digiconsoo's Avatar
The Following 2 Users Say Thank You to digiconsoo For This Useful Post:
MarkJames (04-09-2015), RiverBG (04-09-2015)
Old 04-09-2015, 09:33 PM   #15
m1911's Avatar
What is a GFCI?
I don't think I got the job...
m1911 is offline
Xtrememtnbiker (04-10-2015)
Old 04-09-2015, 09:34 PM   #16
Must have tool bags hand tools and fall restraint harness/system?
Old 04-09-2015, 09:39 PM   #17
What is a GFCI?
Yes sir! I was thinking batter boards too, what OSB stood for, do you know what a birds mouth is... Might have to make this a two pager...
Old 04-09-2015, 09:41 PM   #18
Alldayrj's Avatar
Trade: Mason
Rewards Points: 284
None if the hole is dug correctly
Alldayrj is offline
The Following 13 Users Say Thank You to Alldayrj For This Useful Post:
Agility (04-10-2015), asevereid (04-09-2015), Builders Inc. (04-09-2015), Creter (04-11-2015), digiconsoo (04-09-2015), griz (04-09-2015), Jaws (04-10-2015), kixnbux (04-11-2015), Metro M & L (04-09-2015), NJGC (04-09-2015), oktex56 (04-11-2015), TimberlineMD (04-10-2015), Xtrememtnbiker (04-10-2015)
Old 04-09-2015, 09:43 PM   #19
If that is normal for your crew I would put that. can see that easily being several hundred dollars. Nothing to a guy that does it for a living. Alot to a guy trying to fake it.
I need more tools.
Old 04-09-2015, 09:45 PM   #20
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,551
The scary thing is that I knew all but a couple of these, but I still would not call myself a framer. You need to figure out how to weed me out.
MarkJames is offline
Chopsaw Chick (04-10-2015)
New Employee Procedure? islandbuilder Business 0 04-27-2010 10:06 AM
Employee Damage yarruM General Discussion 2 04-02-2010 06:02 PM
Qualified Employee... How much? PlumbingPro's General Discussion 2 02-05-2010 07:50 PM
Hiring a New Employee (First Time) CookeCarpentry Business 9 05-09-2009 07:58 AM
Illinois Employee Classification Act, New Get Tough Policies Ed the Roofer Business 0 02-13-2008 04:05 PM
