Electric Motor. - General Discussion - Contractor Talk
Electric Motor.
Old 08-19-2019, 05:31 PM   #1
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,990
Electric Motor.
Why won’t my “old as dirt” motor start on my table saw.
It try’s to go but just won’t spin.
It is easily turned by hand , so it isn’t seized.
B.D.R. is offline
Old 08-19-2019, 05:32 PM   #2
B.D.R.'s Avatar
Re: Electric Motor.
It’s my Dado blade setup.
B.D.R. is offline
Old 08-19-2019, 05:38 PM   #3
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: Electric Motor.
See that lump on the side of the motor?
It's called a "start capacitor"
It's the likely culprit.
SmallTownGuy is offline
The Following 5 Users Say Thank You to SmallTownGuy For This Useful Post:
B.D.R. (08-20-2019), griz (08-19-2019), hdavis (08-19-2019), pinwheel (08-19-2019), Seven-Delta-FortyOne (08-20-2019)
Old 08-19-2019, 05:58 PM   #4
hdavis's Avatar
Rewards Points: 1,804
Re: Electric Motor.
Originally Posted by smalltownguy View Post
see that lump on the side of the motor?
it's the likely culprit.
x2.
hdavis is online now
B.D.R. (08-20-2019)
Old 08-19-2019, 06:08 PM   #5
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 146
Re: Electric Motor.
Will it start when spun by as ya turn on the switch? Start capacitor would also be my first look.
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
B.D.R. (08-20-2019)
Old 08-20-2019, 09:54 AM   #6
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,735
Re: Electric Motor.
Remove the housing that holds the capacitor, take it to an industrial electric supply house, have them match the #'s and reinstall.
Same happened to my MK 101 tile saw---$26 in parts, good as new.
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
B.D.R. (08-20-2019)
Old 08-20-2019, 01:15 PM   #7
B.D.R.'s Avatar
Re: Electric Motor.
So a well placed techno smack with a large hammer is not the appropriate fix.
Thanks guys.
B.D.R. is offline
Old 08-20-2019, 02:15 PM   #8
Railman's Avatar
Trade: Railing
Rewards Points: 1,053
Re: Electric Motor.
Prior to removing capacitor, be sure to short it out to kill the zap it normally stores. Do this while motor is not plugged in.
You may not find a perfect match in voltage & micro-farads, but as long as the new one has close to the same voltage rating, & ball park mfd's , it should work ok.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
B.D.R. (08-20-2019)
Old 08-20-2019, 02:28 PM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 1,032
Re: Electric Motor.
Thanks guys.
that's funny....
exactly how i got my jeep going this morning.
bad pcm (computer sorta). buddy told me to smack it good with the handle of a big screwdriver.
worked like a charm...
griz is online now
B.D.R. (08-20-2019)
