Drain Tile Placement Debate - General Discussion - Contractor Talk
Old 06-08-2009, 10:20 AM   #1
Thinker3932's Avatar
I am a younger guy so perhaps there is some history here that I don't appreciate. I have a drainage contractor who says he always puts the drain tile on top the foundation slab where it meets the wall, so that it rests in that "L" that is formed.
Everything I understand about current codes says the drain should be flush with the slab (the top of the pipe must not be higher than the top of the slab.)
Did they used to place the tile on the slab in the past or where did this contractor learn that on top of the slab was the right place to put it?
This is not new construction (1946), so the foundation is masonry block.
Thinker3932 is offline
Old 06-08-2009, 10:42 AM   #2
Rewards Points: 2,000
Re: Drain Tile Placement Debate
Nomenclature.
When we pour the slab
(interior floor) to the top
of the first course of block,
placing the 4" tile on top
of the footing would put
the top of the tile
roughly at the bottom of the slab.
Or, 4" below finished floor level.
neolitic is offline
Old 06-08-2009, 11:26 AM   #3
General Contractor
greg24k's Avatar
Rewards Points: 8,480
4" bellow the top of the footing. Covered with 4" min of clean stone and fabric (I usually cover drainage with stone to the top of the concrete floor)
You should go with this to DIY chartroom, this site is for professional contractors only.
greg24k is offline
Old 06-08-2009, 12:44 PM   #4
OK, I see my disconnect. Thanks for clarifying where I was off-base.
Tags
drain , drainage , french , tile , waterproofing
Tile over Tile fireguy Flooring 5 09-16-2012 05:25 AM
Waterproofing with drain tile on top of footing KrollProperties General Discussion 2 01-22-2009 10:29 PM
Drain Tile monticellohomes Construction 7 09-16-2008 08:13 PM
Tile Debate - Shower floor 1st or shower wall? Logan's Tiling 21 08-03-2008 01:27 PM
Monolithic Slab foundation drain tile placement J Hague Construction 32 02-08-2008 11:12 PM
