Discovered Some Mold - General Discussion - Contractor Talk
Thread Tools
Old Yesterday, 04:15 PM
jmontgom's Avatar
Rewards Points: 239
I have a property that I purchased to fix up and rent. Over the winter when things were slow I worked there a-lot. I did not see any moisture in the basement from September to May, when everything was exposed. The board and plaster were completed and I have not been there much cause of other work.
I am noticing a little moisture at the bottom of front basement wall, of a walk out basement. There is also small amount of mold. I am thinking the problem must be from all the humidity we are having and the fact there is no air moving in house.
I am running a dehumidifier and fans trying to get the moisture to go away. I a going to talk to HVAC company about finishing install so I can get the AC going. Once it is dry I was going to clean the areas on the face of plaster to remove that mold. What are my options for mold I can see on the back side of blue board? Can I cut a few small sections of blue board out and fog the dead space between wall and foundation? Any suggestions to save me from having to remove all the sheetrock?
Thanks
jmontgom is offline
Old Yesterday, 05:07 PM
fjn's Avatar
Trade: mason
Rewards Points: 10,600
Re: Discovered Some Mold
Thanks
Drywall or blue board and plaster are paper encapsulated gypsum. They do not behave very good in damp environments A better choice down there would be the yellow board,it has a fiberglass coating that does not promote mold growth.
fjn is online now
Old Yesterday, 05:10 PM
GC/carpenter
Calidecks's Avatar
Rewards Points: 17,706
Thanks
If it were humidity wouldn't it be other places besides the bottom of the wall?
Mike.
_______________
Calidecks is offline
Old Yesterday, 06:47 PM
jmontgom's Avatar
Rewards Points: 239
I just notice dampness on floor right along front wall. Minimal mold scattered everywhere on basement walls. Nothing on first floor.
We had a very wet fall last year and I did not see any moisture leaking in through foundation or floor. The basement has all new framing, closed cell spray foam around entire perimeter, blue board and plaster. I dont know if I should of had AC on or dehumidifier on once humidity went up. I hope this isnít one of those expensive lessons.
jmontgom is offline
The Following User Says Thank You to jmontgom For This Useful Post:
Calidecks (Yesterday)
Old Yesterday, 09:52 PM
hdavis's Avatar
Rewards Points: 2,620
The first thing to know about basements us they stay cooler than outside for quite some time. High humidity outside, and it will be condensing conditions in the basement.
You can fog it. If there is a smell, it won't go away. You can also seal the walls with Shieldz. I automatically do both.
hdavis is online now
Old Yesterday, 09:55 PM
hdavis's Avatar
Run a dehumidifier next time.
Thread Tools
Rate This Thread
