Dealing With A Double Sliding Glass Door... - General Discussion - Contractor Talk
Old 03-16-2013, 10:23 AM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,750
A customer of mine has what has turned out to be a sliding door that has seen it's better days and is leaking causing ceiling damage below. It was an inexpensive one used for a pre-fab home. I'm replacing it with an Andersen.
I just got in a single replacement door for another job (the door warped and was covered under Andersen's warranty) and it weighs in at 98 lbs.
The slider will go on a 3rd story balcony exit. Naturally, the staircases leading up the different levels are not able to handle the dimensions of the whole thing assembled.
My question...do these doors typically come fairly well packed/braced so if the sliders are taken out the frame will not rack? With a helper, we can get the individual doors up and raise the frame up with ropes.
Any ideas?
Thanks.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 03-16-2013, 11:30 AM   #2
icer85's Avatar
Re: Dealing With A Double Sliding Glass Door...
Make an exterior frame around the jambs out of 2x, do your cross braceing so it won't fall out either direction, That should also give you something solid to attach to.
Or
We've installed ones that are not assembled yet, just 4 pieces and you glue and screw them together.
Enjoy
icer85 is offline
The Following User Says Thank You to icer85 For This Useful Post:
Robie (03-16-2013)
Old 03-16-2013, 12:14 PM   #3
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 436
We take them out all the time. Years ago, we would muscle up on every window and door unit. Nowadays, we remove a lot of sashes and door panels. Just be sure to square everything up once the whole unit is reassembled.
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Robie (03-16-2013)
Old 03-16-2013, 12:26 PM   #4
rrk's Avatar
Rewards Points: 5,338
Andersen slider frames are assembled on site aren't they?
rrk is online now
Old 03-16-2013, 01:54 PM   #5
Steve57's Avatar
Trade: general contractor
Rewards Points: 105
Yes. You could order them assembled too. The frame is in one box. Door panels are in two other boxes. Screen in another box.
Steve57 is offline
The Following User Says Thank You to Steve57 For This Useful Post:
Robie (03-16-2013)
Old 03-16-2013, 01:56 PM   #6
Robie's Avatar
Didn't know that. I'll check with the distributor Monday.
Thanks.
Robie is online now
Wood flooring meets metal for sliding glass doors lotusdelux Flooring 18 11-11-2015 10:43 PM
sliding door tune-up superseal Windows, Siding and Doors 17 08-10-2012 10:07 PM
Severe condensation above sliding glass door warrenc Construction 18 03-08-2010 12:00 PM
high end glass door for store front wayne3434 Windows, Siding and Doors 5 11-10-2009 02:13 PM
