Cutting 6" Dia. Hole For Wall Cap - General Discussion - Contractor Talk
Old 05-19-2018, 01:41 PM   #1
seagull's Avatar
Trade: renovation
Rewards Points: 26
I'm installing the range hood ventilation before the kitchen gets closed up this week, do you guys recommend buying a 6 1/4" hole saw for cutting the opening for ducting to the outside wall, or would you just use a jigsaw from the outside?
I've seen wall caps mounted directly to the siding, then sealed with caulk. I don't trust sealants that much, so I plan on mounting the wall cap on a PVC trim block cut into the siding, sealing around the perforation, back caulking the flanges, then spray foaming from the inside.
How do you guys go about these?
If you need more info,
- rigid ducting (~5' run) in ceiling joists then vented through the rim joist
- wood clapboard siding
seagull is offline
Old 05-19-2018, 01:54 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 752
Re: Cutting 6" Dia. Hole For Wall Cap
i use a jig saw.
that 6" hole saw is an arm breaker....
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
seagull (05-19-2018), Seven-Delta-FortyOne (05-19-2018), TimNJ (05-19-2018), Tinstaafl (05-19-2018)
Old 05-19-2018, 01:56 PM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,040
Make sure you use Z-metal head-flashing above that trim piece.
Old 05-19-2018, 02:03 PM   #4
seagull's Avatar
Trade: renovation
Rewards Points: 26
thanks fellas
seagull is offline
Old 05-19-2018, 02:27 PM   #5
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,326
Originally Posted by griz View Post
......that 6" hole saw is an arm breaker....
That's why you brace the drill against something solid.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 05-19-2018, 03:07 PM   #6
Pangdev's Avatar
Trade: general contractor
Rewards Points: 194
ways to go about. One way I like is to cut a enar perfect hole traced out. Once cut, you can insert the vent / pipe. There is a product called "Solar Seal". It is an excellent sealant for roofing and siding. This is a clear sealant. I seal the perimeter of the opening and the perimeter of the vent flange as well.
Pangdev is offline
Old 05-19-2018, 04:42 PM   #7
seagull's Avatar
Trade: renovation
Rewards Points: 26
Pangdev, are you suggesting I butt the vent flange to the clapboard siding and seal around the perimeter?
seagull is offline
Old 05-20-2018, 05:19 AM   #8
Box Builder
Morning Wood's Avatar
Rewards Points: 10,298
I install the vent block before the siding so it can be flashed properly and side around it. Then cut the penetration in the sheathing when the time comes to do the duct. And for one that big, is use a jig saw. Unless you have a good clutched drill a hole saw that big can hurt you.
Morning Wood is online now
Bought a new Ridgid tile saw...any reviews here? IHI Tiling 45 11-24-2012 01:03 PM
hole saw and right angle drill issues PARENOS Plumbing 26 07-26-2011 05:28 PM
3" hole in a poured concrete foundation christophersprk Masonry 8 02-09-2010 08:06 PM
apprentice having trouble cutting accurately likeke34 Carpentry 193 12-21-2009 01:29 AM
Need a hole saw for 6" can lts. NewL Electrical 23 12-29-2005 10:29 PM
