Crawl Space Ventilation - General Discussion - Contractor Talk
Old 01-25-2019, 10:22 PM   #1
RBDJR's Avatar
Trade: CONCRETE
Rewards Points: 4
I have a client who has had her house raised due to flooding issues. The contractor filled in around the slab to prevent water and vermin from gaining access. Now we have moisture vapor coming up into the house. What does the building code say about ventilating crawl spaces.
RBDJR is offline
Old 01-25-2019, 11:35 PM   #2
Mordekyle's Avatar
Rewards Points: 4,268
Re: Crawl Space Ventilation
Kind of an either/or.
Either ventilated with a vent for every 150 sq ft. or totally encapsulated from the soil with a heavy poly barrier with sealed seams.
Mordekyle is online now
Old 01-25-2019, 11:36 PM   #3
Mordekyle's Avatar
Of course this varies somewhat with region.
Old 01-25-2019, 11:56 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 535
I'm confused. Your trade is "concrete"? Does that mean you're the contractor who filled in around the slab? How else would the client be your client?
As a contractor, particularly in concrete, shouldn't you already be somewhat familiar with the relevant codes?
Tinstaafl is online now
Old 01-26-2019, 01:27 AM   #5
Designer/Contractor
Rio's Avatar
Rewards Points: 684
Mechanical ventilation, while not optimal, is permissible also, at least out here, need to follow the code.
Rio is online now
Old 01-26-2019, 07:32 AM   #6
RBDJR's Avatar
Trade: CONCRETE
Rewards Points: 4
My question is "what are the code requirements for ventilation under house in a situation like this". The 150 sq.-ft. advice is on track. This is not a structural issue. Raising houses is a little out of the ordinary but I think this would be common in a pier and beam or house set on blocks, both of which are older methods in my area. I am trying to help a widowed friend solve some of her problems and am a little out of my purview. I hope to be able to have the city force the foundation contractor to provide the ventilation, as he should have done in the beginning, or barring that, I am open to suggestions on how to accomplish this myself.
RBDJR is offline
The Following User Says Thank You to RBDJR For This Useful Post:
rescraft (01-26-2019)
Old 01-26-2019, 09:06 AM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 535
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Radiant Floor or electric baseboard in crawl space dano1 General Discussion 7 01-06-2014 04:55 PM
Exterior plug placement jimrun Electrical 8 05-31-2012 08:53 AM
hardwood over crawl space jhcontracting Flooring 13 11-19-2011 07:27 PM
hanging crawl space insulation w/o joists gudor Insulation 16 12-13-2009 12:14 AM
insulating floor truss in crawl space AustinDB Construction 8 08-22-2008 07:54 AM
