Concrete Pros I Need Help - General Discussion - Contractor Talk
Old 06-22-2010, 05:33 AM   #1
macbe's Avatar
Trade: replacement window&door installer
Rewards Points: 81
poured a porch at home,it went south on me have spots that flaked or blistered worked it to hard. is there a remedy for those areas.besides a jackhammer.realy need some suggestion.wife'y is about to hang me.thanks guys. they are about 2x4 or 6" long
macbe is offline
Old 06-22-2010, 09:02 AM   #2
Vision Custom's Avatar
Trade: Remodeler/builder
Rewards Points: 75
Re: Concrete Pros I Need Help
Whitecap sells a product we've used a couple times on spalled slabs to provide a new finish. It can be troweled as thin as 1/8 inch, and stands up to traffic. I can't remember the name of it offhand, but it is great. Comes in a 30- 35 lb bag, portland based, just add water. sets kinda quickly.
Mabye someone can help me out on the name of it...
Don
http://rioranchosremodeler.com/
Vision Custom is offline
Old 06-22-2010, 09:16 AM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,858
That is why you stamp things. You can do a half-assed job finishing it, throw the stamps on and it looks like a million bucks.
The over-lay stuff sucks but, may be an option.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 06-22-2010, 09:39 AM   #4
genecarp's Avatar
Rewards Points: 2,000
Skimstone would cover up the bad area and make the job look good, GMOD
genecarp is offline
Old 06-22-2010, 12:37 PM   #5
Rebecca's Avatar
Trade: Concrete
Were you referring to Ardex?
Rebecca is offline
Old 06-22-2010, 02:59 PM   #6
tgeb's Avatar
Rewards Points: 1,056
Top-N-Bond comes to mind.
www.gebcon.com
tgeb is offline
Old 06-22-2010, 05:10 PM   #7
Rewards Points: 75
Yep, thats the stuff. The concrete patch formula. Thanks!
Don
Old 06-22-2010, 07:16 PM   #8
macbe's Avatar
Rewards Points: 81
thanks, i don't haveroom to build it up to much because the doorsill sits on the concrete.if i patch it, has to blend with lite gray finish.tested some quickset but it stays dark gray,tha would look worse then it does.
macbe is offline
Old 06-22-2010, 10:07 PM   #9
SK Remodeling's Avatar
Trade: residential remodeling contractor
Rewards Points: 244
So paint it
SK Remodeling is offline
Old 06-22-2010, 10:33 PM   #10
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 170
Not sure what your climate is like, which does make a huge difference in the performance of some of these products, but there's no way I'd try patching spots in MY climate. (notice how you can look near my screen name and see where MY climate is?? Ingenious, isn't it )
Which is exactly why you're getting good suggestions here to use a micro-topping over the entire surface.
jomama is offline
Old 06-24-2010, 09:37 PM   #11
macbe's Avatar
Rewards Points: 81
if i wanted to paint it i wouldn't have asked for help from the pro's. but thanks for the suggestion..........
macbe is offline
Old 06-25-2010, 12:53 PM   #12
Rewards Points: 244
So...don't paint it!
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 47 06-03-2014 10:17 PM
Pro's and Cons of concrete surrounding pool. Harvey Ramer Pool Construction & Enclosures 7 10-08-2010 02:00 PM
Concrete with Fly Ash vs. Concrete without? cdkyle Concrete & Paving 19 07-28-2010 09:57 PM
Tire line in concrete after finishing. aydin_eng Flooring 34 03-09-2010 10:03 PM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
