Cold Weather Concrete Columns And Blankets - General Discussion - Contractor Talk
Old 12-31-2012, 09:15 PM   #1
Sticks & Stones
rpberchtold's Avatar
I hope my ignorance on this matter is met with appreciation of the fact I need to do something I have never done before and am asking for help. I am a WV Commercial and Residential Contractor but have never had to pour concrete in 30 degrees before so since I have no sub to do this at this time I will be doing it myself with my small crew. We have 28 qty 9' x 16" sonotubes to pour and I realize we need a winter mix and all but my question is how and heck can I wrap these columns since they will have bracing on top and I can't cut the blankets to fit ( they will be rented.) also it will be dipping down to around 10 degrees at night so how long would I need to leave the blankets on before removal?
Thanks for your help in advance,
rpberchtold is offline
Old 12-31-2012, 09:59 PM   #2
ExtremePride's Avatar
Trade: general contractor
Rewards Points: 85
Re: Cold Weather Concrete Columns And Blankets
I don't pour much these days but can say around here our plants won't fire up if the temps are below 32 degrees. I would think that if you couldn't wrap with the blankets then maybe wrap with batt insulation where needed. Just don't compress it to much
ExtremePride is offline
Old 12-31-2012, 10:05 PM   #3
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 320
Maybe you need to tent them with plastic and add heat. Are they close enough together to tent them all together?
I can't compete with hacks.
donerightwyo is offline
Old 01-01-2013, 01:01 AM   #4
Sticks & Stones
Thanks for your suggestions, the columns will be 10'-0" OC so IF I could tent each row at a time about 40' long I think that might be the best solution as long as the heat would run all night, I just don't know how long a space heater will last before running out of fuel, something to find out. Also does anyone know how long I would need to keep them covered in the temps I mentioned if I could maintain about 55 in the tented area?
Thanks Again.
Old 01-01-2013, 11:49 AM   #5
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
If you have a good R/M supplier, you may be able to get concrete for you columns with heated aggregate and warm water (max of 140F), so the concrete comes at summer temperatures. Use Type III (high early cement) and specify 4000 psi minimum. The warmth will kick of the cement reaction to generate heat of hydration. This is far cheaper in the end than a lot of inefficient job heat and tenting.
Your temperatures are not that low and the mass of the concrete will get you more than enough strength in a few days. What is important is the temperature of the concrete and not the air temperature. There is lot down the street from me, where the probably be digging and pouring strip footings for the basement tomorrow on Jan 1 (It was -5F this morning). The clue to the time guess is that they already have a culvert and sand pile for mortar covered with blankets and being heated by a propane burner. They put off excavating as long as possible to prevent freezing, especially if there is a snow cover and do the strip footings and a course or so of block the same day.
Winter is just a state of mind if you shift seasonal gears and plan ahead.
Dick
concretemasonry is online now
Old 01-01-2013, 12:11 PM   #6
Sticks & Stones
I will check with my supplier tomorrow and see what they think about your suggestions, they are DOH State approved so I am sure they will understand my needs as far as Air and type III mix, my only concern is the time to the job on the truck ( about 35 to 40 Min) that was why I thought it may still need to be protected for a while.
That said, what do you think now?
Bob
Old 01-01-2013, 12:47 PM   #7
Kitchen Cabinets NJ
cabinetsnj's Avatar
Trade: Kitchen Cabinets
That is sound advice.
NJ Cabinet Outlet
cabinetsnj is offline
Old 01-01-2013, 02:54 PM   #8
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 166
Not sure I'm understanding this, but how much of the 9' of tube is sticking out of the ground, all of it? If so, how are you going to get the concrete into them?? If they're completely in the ground, a bale or two of straw will suffice......
jomama is online now
The Following User Says Thank You to jomama For This Useful Post:
donerightwyo (01-01-2013)
Old 01-01-2013, 06:43 PM   #9
Sticks & Stones
The Sonotubes will be the columns sitting on 3'x'3'12" reinforced footings with dowel rods to receive the sonotubes at a finished height of 9' vertical. The structure will be built on top of that foundation as it is in the flood plain.
I hope this helps.
Bob
Old 01-01-2013, 10:41 PM   #10
Air entrainment of the concrete is probably necessary (minor cost difference) in your case is not really necessary because of the use and exposure. Around here if it was for flat work, you could not a good supplier to even deliver non-entrained concrete to a job.
Without seeing the site and project, pumping (rental?) place the concrete into the tubes alternating between tubes to bring them up slowly to bring them up and set any embedded steel may be the way to go. That way, you can knock it out in a day.
Dick
