Cold Bedroom. - General Discussion - Contractor Talk
Cold Bedroom.
Old 10-30-2018, 04:55 PM   #1
t.carpenter00's Avatar
Trade: excavating/ drywall/ currently remodeling
Rewards Points: 292
Cold Bedroom.
I have a client slash friend whose kids bedroom is noticeably colder than the rest of the house in the winter. It's one of the closest rooms to the furnace, and the vents have good airflow. But it's crazy cold in there. Probably 10 degrees difference, maybe more. The windows still seem to be sealed tight. And they've been caulked around.
I noticed when I was in the ceiling recently that the insulation wasn't blown very well around the rafters. There was lots of dead spaces. So I put vents in and blew insulation in there today.
Her room also has a gable roof with a bay window under it. It has vent soffits, and a ridge vent. The bay window also had vented soffit but it was walled in in the Attic. So there was no airflow. I cut some holes and open that up and the cold air was significant. But somehow I have my doubts that any of this has fixed the problem. Any thoughts?
Sent from my VS988 using Tapatalk
t.carpenter00 is offline
Old 10-30-2018, 05:34 PM   #2
TimNJ's Avatar
Rewards Points: 5,626
Re: Cold Bedroom.
Where's the cold air return in relation to this room?
Cold in the winter, so was it extra hot in the summer compared to the other rooms?
TimNJ is online now
Old 10-30-2018, 05:55 PM   #3
Mordekyle's Avatar
Rewards Points: 5,474
Re: Cold Bedroom.
I fixed some ducting to a cold laundry room a few weeks ago.
It turns out that when the hose to the washing machine broke three years ago, water got down the register and filled the duct. I poked it to let the 2-3 gallons out.
The flooring was replaced, but nobody bothered to go down in the crawlspace.
Mordekyle is online now
Old 10-30-2018, 05:59 PM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 10,238
Re: Cold Bedroom.
You got pics? Her room has a bay window? Those things are notoriously cold and poorly insulated
Morning Wood is offline
Old 10-30-2018, 06:37 PM   #5
Rewards Points: 292
Re: Cold Bedroom.
I'll get dome pictures and ask about the cold air return.
Old 10-30-2018, 06:41 PM   #6
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 342
Re: Cold Bedroom.
Teenager's room? Door closed a lot? Like Tim said, possibly return air issue. Is the door undercut?
Ask me how I know this
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
Old 10-30-2018, 06:42 PM   #7
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,757
Re: Cold Bedroom.
I suspect missing insulation in a couple areas..or more. Had the same thing with one of our upper bedrooms and I ended up opening the entire wall to redo it. It was an old house, and the blown-in cellulose in the walls had settled.
Could be that pulling the window casing reveals a bunch of gaps.
Thermal imager might help.
MarkJames is offline
Old 10-30-2018, 06:44 PM   #8
Rewards Points: 292
Re: Cold Bedroom.
So you guys thinking no air flow, huh?
Old 10-30-2018, 06:51 PM   #9
Rewards Points: 292
Re: Cold Bedroom.
This house was built in 89. I've been thinking the same thing about settlement.
Old 10-30-2018, 06:53 PM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,006
Re: Cold Bedroom.
CAR is important...if air can't get out, air can't get it.
Inner10 is offline
Old 11-04-2018, 09:17 AM   #11
builditguy's Avatar
Rewards Points: 1,932
Re: Cold Bedroom.
I would check for cold air return first. Sometimes people think having a Door with a large ha at the bottom will solve the problem. It doesnít really.
Then I would check for insulation around that bay.
If thereís no cold air return it doesnít matter how much airflow there is. imagine shutting the door, the airflow blows up the room like a balloon , and then once itís full, the air has nowhere to escape and then it just stops.
builditguy is offline
Old 11-04-2018, 10:08 AM   #12
MarkJames's Avatar
Re: Cold Bedroom.
On a cold day, feel the walls, ceiling and floor with your hand. Something is going to stand out. (Use a latex glove to keep the walls clean.) It may be old-fashioned, but it often works.
An infrared thermometer would help, as well.
Old 11-04-2018, 10:40 AM   #13
hdavis's Avatar
Rewards Points: 1,556
Re: Cold Bedroom.
Make sure supply and return air paths aren't restricted, and rebalance the system to bring the room temp up.
hdavis is offline
Old 11-04-2018, 10:45 AM   #14
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,602
Re: Cold Bedroom.
Yup. I've got a cheap one I've had for years and it comes in handy quite often.
https://www.amazon.com/d/Infrared-Th...ed+thermometer
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
The Following 2 Users Say Thank You to Robie For This Useful Post:
MarkJames (11-04-2018), SmallTownGuy (11-04-2018)
Old 11-04-2018, 05:03 PM   #15
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: Cold Bedroom.
yup. what he said.
SmallTownGuy is offline
Old 12-19-2018, 08:18 AM   #16
MarkL's Avatar
Trade: Fencer
Rewards Points: 46
Re: Cold Bedroom.
Perhaps Infrared Thermal Camera could help.
MarkL is offline
Old 12-19-2018, 08:20 AM   #17
Rewards Points: 292
Re: Cold Bedroom.
That's a good idea....
Old 12-19-2018, 08:46 AM   #18
MarkL's Avatar
Trade: Fencer
Rewards Points: 46
Re: Cold Bedroom.
There are thermal cameras in Amazon for smartphones also. https://amzn.to/2UZr8kj
MarkL is offline
Old 12-19-2018, 11:07 AM   #19
Rewards Points: 342
Re: Cold Bedroom.
I hope he's got the problem resolved by now.
Old 12-24-2018, 09:00 AM   #20
Rewards Points: 292
Re: Cold Bedroom.
I sent my HVAC guy over there. He said that the unit was actually oversized for the house, so airflow wasn't a problem. He simply suggested the guy leave the door open. Something I've told the guy several times. College professor... You know.
I haven't checked back with him yet. Probably will today.
Cold sqft to Hot water sqft knothead Pressure Washing 6 02-22-2014 01:08 AM
I hate when it starts to get cold. NYCB Concrete & Paving 15 11-13-2013 10:19 PM
Mason or cold chisel! What is the difference? sleeper Masonry 24 11-30-2012 04:51 PM
very cold outside air from cold air return ?? slawek HVAC 3 12-24-2008 09:30 AM
FDA to declare cold medicines too risky for babies, toddlers eagleandbaby Off Topic (Non Trade) 0 01-17-2008 09:36 AM
