Code On Insulated Roof Systems And Attic Space - General Discussion - Contractor Talk
Old 07-20-2020, 10:25 AM   #1
AustinDB's Avatar
Rewards Points: 22
Location-Austin, TX
Working on a NC warranty punch list on an upscale condo near 6th St in Austin. It has an insulated roof system (standing seam metal roof).
Are there any venting requirements for a conditioned attic? Is that the proper term?
AustinDB is online now
The Following 2 Users Say Thank You to AustinDB For This Useful Post:
Ohteah (07-24-2020), Wile E Coyote (07-21-2020)
Old 07-20-2020, 10:25 AM   #2
AustinDB's Avatar
Rewards Points: 22
Re: Code On Insulated Roof Systems And Attic Space
The Following User Says Thank You to AustinDB For This Useful Post:
Old 07-20-2020, 11:41 AM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 46
by your pics it appears that the attic roof is insulated, but are there any hvac vents putting conditioned air into the attic?
griz is online now
Old 07-20-2020, 12:22 PM   #4
tjbnwi's Avatar
Rewards Points: 260
No venting at all. It defeats the purpose of the space.
Most often any "conditioning" of the space is latent transfer through the ceiling.
tjbnwi is online now
Old 07-20-2020, 01:42 PM   #5
AustinDB's Avatar
Rewards Points: 22
yes the roof is the only part that is insulated. there are no vents supplying air to the attic space.
should the joists have spray foam applied as well? I don't work on many newer high end houses, but the last one had the roof and ceiling floor foamed. that was the Jackson job-no expense spared.
thx Tom, I suspected so. The 'home inspector' called out that it needs ridge and soffit venting which didn't add up. in general all of his inspection items have been on target.
Old 07-20-2020, 03:46 PM   #6
tjbnwi's Avatar
Rewards Points: 260
I’ve never seen the ceiling joists sprayed.
Old 07-20-2020, 03:51 PM   #7
tjbnwi's Avatar
Rewards Points: 260
In your climate, from what I can tell from the picture, as long as there are no vents the installation is correct.
https://www.creativeconservation.com...r-attic-system
AustinDB (07-20-2020), ScipioAfricanus (07-20-2020)
Old 07-20-2020, 04:25 PM   #8
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 8
You may have to put a supply vent up there, but NO other venting per the codes
No you would not spray the floor joists
You have a "hot roof" or what others sometimes call an encapsulated attic
https://thehtrc.com/2011/what-is-a-hot-roof - brief synopsis of what it is & why
SLSTech is online now
The Following User Says Thank You to SLSTech For This Useful Post:
XJCraver (07-21-2020)
Old 07-20-2020, 06:38 PM   #9
AustinDB's Avatar
Rewards Points: 22
the hvac does have a fresh air supply system that's tied into the air handler's return plenum. it has a controller that is set to a certain number of minutes of air/hour.
thx guys (y)
Old 07-20-2020, 08:42 PM   #10
Box Builder
Morning Wood's Avatar
Rewards Points: 6
Yeah. Hot roof. You could put unfaced batt insulation in the ceiling joists...
Morning Wood is offline
