CO2 & Gas Space Heaters - General Discussion - Contractor Talk
Old 01-21-2019, 11:27 PM   #1
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
Today I read this post reply...
"Tarp/Tent, big arse torpedo heaters. Heat for an hour before starting, heat the brick sand water and let em run dry after you're done"
...and it made me think about the dangers of carbon monoxide poisoning. Do any of you carry an extra carbon monoxide detector when tenting and heating small spaces? What about a warning on the outside of tents/rooms warning against the danger of carbon monoxide poisoning (thinking kids, lookiloos).
P42003 is offline
Old 01-21-2019, 11:44 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 92
Re: CO2 & Gas Space Heaters
This is not an answer to your question, but Carbon Monoxide, the product of combustion, is CO.
Carbon Dioxide, is CO2. It's the bubbles in the soda water that you mix with gin. CO2 is naturally occurring in atmospheric air.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Harber (01-22-2019), P42003 (01-22-2019)
Old 01-22-2019, 12:30 AM   #3
Business Owner
P42003's Avatar
Rewards Points: 158
Oh boy, egg on my face! And to think I pride myself on this type stuff. Probably will die of dihydrogen monoxide poisoning dreaming about it.
P42003 is offline
Old 01-22-2019, 12:35 AM   #4
Business Owner
P42003's Avatar
Rewards Points: 158
Yep... effervescence
P42003 is offline
Old 01-22-2019, 12:57 AM   #5
diplomat
Golden view's Avatar
Rewards Points: 1,550
CO2 and water are the main products of combustion. CO is produced when things aren't burning right. Modern engines produce almost zero CO.
CO2 only kills you if it displaces too much oxygen. A small amount of CO will kill you.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
Inner10 (01-22-2019), P42003 (01-22-2019)
Old 01-22-2019, 07:45 AM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Just no...
Inner10 is offline
Old 01-22-2019, 08:01 AM   #7
Harber's Avatar
Trade: painting
Rewards Points: 160
Originally Posted by Inner10 View Post
Just no...
What's not right there? I mean, combustion produces both, but other than that, he is right.
Harber is offline
Old 01-22-2019, 08:08 AM   #8
Inner10's Avatar
It's not a product of combustion, it's a product of incomplete combustion.
Inner10 is offline
Old 01-22-2019, 09:05 AM   #9
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 5,934
I bet your wife loves hanging out with you.
Big Johnson is offline
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
P42003 (01-22-2019), Seven-Delta-FortyOne (01-22-2019)
Old 01-22-2019, 09:51 AM   #10
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 44
So back to the question , do any use any type of monitoring. One of the reasons years ago I stopped using a torpedo or tank mounted heater in my work trailer. Got to the point I could not even stand to be around one. I instead put a Rv furnace in mine where it is vented to the outside. Much safer situation. I think if I was don't work that needed tented I work rig up a heater that vented to the outside.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
P42003 (01-22-2019)
Old 01-22-2019, 09:59 AM   #11
diplomat
Some, like Mr Heater, include an oxygen depletion sensor. So it won't help for CO poisoning, but the assumption is that they aren't making enough CO to matter. When the CO2 is high, then the O2 depletion sensor would detect it.
I've never seen anyone use another type of monitor. Many of these guys seem to be down a syllable or two.
P42003 (01-22-2019), Randy Bush (01-22-2019)
Old 01-22-2019, 10:07 AM   #12
hdavis's Avatar
Rewards Points: 4,636
Never seen one used.
hdavis is online now
Old 01-22-2019, 10:44 AM   #13
Randy Bush's Avatar
Rewards Points: 44
Is that like saying some are a brick short of a full load?
Golden view (01-22-2019)
Weird foundation - Concrete Slab over really shallow crawl space Mr_Stop General Discussion 14 10-19-2017 07:49 PM
Exterior plug placement jimrun Electrical 8 05-31-2012 08:53 AM
Siding repair in narrow space frroden Windows, Siding and Doors 3 11-23-2010 10:58 PM
Electric Space Heaters davidanbess Electrical 10 11-03-2010 07:25 PM
insulating floor truss in crawl space AustinDB Construction 8 08-22-2008 07:54 AM
