Cheapest Option For Unfinished "fire-rated" Ceiling? - General Discussion - Contractor Talk
Old 12-16-2019, 09:50 PM   #1
acro's Avatar
Trade: Electrical
Rewards Points: 661
This might be a little unconventional, but...
So, a buddy just lost his work shop(auto) to a fire. Cause is yet to be determined, but it got me thinking about my own shop.
I have a 125k btu radiant tube heater in my shop - similar to what he had. Above my reflectors, I have OSB. I am not able to lower my heater tubes, so that's not an option.
I would like to install some sort of barrier to protect the OSB from direct flame in the event of a tube failure of the heater. Not really looking for a complete coverage of the ceiling, just the areas above the tubes.
So, is that best accomplished with fire resistant drywall? Or is there some other type of board available at a reasonable cost? Ceiling height is 14'6", so weight is a factor also.
I have also thought about spacing sheet metal off of the OSB about an inch with ceramic board under the screws - but mostly open air space. Not sure what to do about heat transfer from the screws themselves in the event of a fire.
Let me have it.
Thanks
acro is offline
Old 12-16-2019, 09:52 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 6,121
Re: Cheapest Option For Unfinished "fire-rated" Ceiling?
5/8 drywall and a single layer of tape on the joints and screws.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 12-16-2019, 10:00 PM   #3
Radical Basement Dweller
Robie's Avatar
Rewards Points: 886
I have a piece of cement board above my barrel stove, attached to the floor joists.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 12-16-2019, 10:06 PM   #4
acro's Avatar
Trade: Electrical
Rewards Points: 661
Ive got blown in cellulose above the OSB
acro is offline
Old 12-16-2019, 10:21 PM   #5
LRG WoodCrafting
Leo G's Avatar
All of the OSB in the shop should be covered at a minimum of 1/2" drywall and fire taped.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 12-17-2019, 03:04 PM   #6
test
cedarboarder's Avatar
Trade: General
Rewards Points: 809
like Leo said 5/8 fire rated drywall
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 12-17-2019, 06:27 PM   #7
Designer/Contractor
Rio's Avatar
Rewards Points: 834
As mentioned, 5/8" type 'X' gyp. board.
As an aside cement board isn't rated as a fire retardant material. It's considered similar to a frying pan, will transmit the heat through it. When we've used it as part of a fire rated assembly we've had to put the 5/8"type 'X' behind it to get any fire rating.
Rio is online now
The Following 2 Users Say Thank You to Rio For This Useful Post:
Robie (12-17-2019), ScipioAfricanus (12-17-2019)
Old 12-17-2019, 06:35 PM   #8
Robie's Avatar
Rewards Points: 886
Good to know.
I have it on 2 sides of the barrel also. The back is probably 12" away. I've never felt any heat on the back even after the stove has been going all day.
Robie is online now
Rio (12-18-2019)
Old 12-17-2019, 06:53 PM   #9
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Years ago the city made me double the 5/8 rock
Still "Shakin" the tree boss
sunkist is offline
Old 12-17-2019, 07:18 PM   #10
LRG WoodCrafting
Leo G's Avatar
That would be a fire wall. Usually an attached garage on a house.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 12-17-2019, 07:28 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 1,112
what the op is describing & asking for is NOT a fire rated assembly but rather just a heat shield.
HUGE difference between the two.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
Old 12-17-2019, 08:23 PM   #12
TimNJ's Avatar
Rewards Points: 6,280
I would get metal and space it away from the OSB about 2" for good airflow behind it.
Just don't use thin galv. sheet metal
TimNJ is offline
Old 12-17-2019, 08:54 PM   #13
acro's Avatar
Trade: Electrical
Rewards Points: 661
True, Griz.
My buddy's fire and the fact that I just replaced two separate heater tubes at work, got me thinking.
The tube failures at work are probably very much related to nearly 100% operation in cold weather for 10+ years. Possibly partial obstructions(birds nests) in the exhaust too. But, seeing the tubes split open and fire coming out of it makes a person wonder. Incidentally, the split in the pipe has to be significant for the flames to get wider than the reflector.
I am not concerned enough to change heat sources, just to try to make my installation a little more bullet proof.
The weight of the 5/8 drywall is enough to make it among my last choices. And doing the whole ceiling is not really in my scope.
acro is offline
Old 12-17-2019, 10:44 PM   #14
rustyjames's Avatar
Rewards Points: 1,810
Sheet metal spaced at least an inch away from the OSB would definitely help deflect a lot the heat.
rustyjames is online now
Old 12-18-2019, 05:26 PM   #15
test
Trade: General
Rewards Points: 809
Originally Posted by acro View Post
True, Griz.
they sell ultra lightweight 5/8s and 1/2 drywall,
