Caulk - Page 2 - General Discussion - Contractor Talk
Caulk
Old 03-22-2015, 04:43 PM   #21
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 960
Re: Caulk
Originally Posted by Xtrememtnbiker View Post
The aerosol kind? I just looked it up on Amazon because I have no idea what you're talking about and see a bunch of aerosol products. You spray it over the bead then wipe it?
Yep. Works great. I will lay my bead, spray the caulk and a bit on my finger and tool the joint. No mess and easy to smooth. I just do this with Quad and thick urethane caulk.
I use aerosol foaming window cleaner. We buy it by the case from a local supplier but it is available anywhere.
overanalyze is offline
Old 03-22-2015, 04:50 PM   #22
Board Shortener
Johnny_5's Avatar
Trade: Carpentry / Remodels
Rewards Points: 706
Re: Caulk
I use windex on silicones, just like you said. Lay the bead, spray it down, and tool it. Keeps the silicone from smearing all over anything except where the original bead is laid. Learned that from an old countertop installer.
Johnny_5 is offline
Old 03-22-2015, 05:07 PM   #23
Always Learning
Rewards Points: 960
Re: Caulk
I quit using Windex a few years ago because we work with acrylics from time to time and the ammonia can damage them long term. We got used to stocking the foaming kind. But I have done the same thing.
Old 03-22-2015, 05:16 PM   #24
avenge's Avatar
Rewards Points: 720
Re: Caulk
Being hard to work with is practically the mark of a good exterior caulk. The top urethanes - Sika, BASF, and Quad (silane), are all horrible, sticky messes to work with. That stickiness is what makes them work, and why they'll never be popular with the DIY crowd ('66, I'm not calling you part of the DIY crowd.) You have to tool them with OMS or WD40.
I'll agree they are a pain to work with but the best for exterior applications.
For interiors I used White Lightning for years but they seem to have changed. I'm still searching but I like Loctite and PPG Topgun. I've had Big Stretch fail more than once.
avenge is online now
Old 03-22-2015, 06:06 PM   #25
schaefercs's Avatar
Rewards Points: 520
Re: Caulk
I use denatured alcohol for silicone. Quick mist on the bead and spray my finger before tooling it.
schaefercs is offline
Old 03-22-2015, 08:45 PM   #26
pro
hangit's Avatar
Trade: wallpaper & fabric installation
Rewards Points: 507
Re: Caulk
950 is probably go to.
there's a couple sw near me that carry some old duron products. those duron caulks, maxflex and magnum xl, are nice to use.
those looking for big stretch, some ace stores carry it. i didn't like it.
hangit is offline
Old 03-22-2015, 09:44 PM   #27
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Re: Caulk
Thanks Andrew. What kind of supplier should I be calling? My normal lumber yard or something different?
Xtrememtnbiker is online now
Old 03-22-2015, 10:06 PM   #28
Always Learning
Rewards Points: 960
Re: Caulk
We buy our paper towels, glass cleaner, toilet paper for the shop, and other misc items from a local janitorial supply business. If all you want is the glass cleaner try Ace Hardware or the Box stores. Moonshine glass cleaner is a larger name we have used. Just not sure if its sold in your area.
Xtrememtnbiker (03-22-2015)
Old 03-23-2015, 06:58 AM   #29
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
Re: Caulk
I usually use dap for interior, as that's all that's really available here. I always use quad for exterior. I don't usually tool it unless I screw up laying it.
Your Dreams won't work unless you do.
SamM is offline
Old 03-23-2015, 08:38 AM   #30
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Re: Caulk
BASF NP-1 for everything exterior and a lot of things inside. It will stick to anything, and with a little 50/50 water and dish soap it tools in real easy with a light touch if you apply a proper bead.
1985gt is offline
The Following User Says Thank You to 1985gt For This Useful Post:
elementbldrs (03-23-2015)
Old 03-23-2015, 04:09 PM   #31
thezoo's Avatar
Rewards Points: 238
Re: Caulk
I am not impressed with Quad's durability. It gets hard after a couple of years. Superseal had a great thread on here discussing caulks. The Dap Dynaflex 230 I've used lately seems good but who knows in a year or 2. Not a fan of BigStretch. I've used some Dap 3.0 and it seems good.
The polyseamseal/phenoseal is really good, I used it to on a door install in cement foundation 7-8 yrs ago and it is still holding up great even on the threshold.
So far, I've mostly used dap Alex and Alex Fastdry and while they go on good and tool easily, they pull away almost as soon a dry, lol. Cheap crap....
I want to give sikaflex a try, lots of folks swear it is great
thezoo is offline
Old 03-23-2015, 06:18 PM   #32
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,669
Re: Caulk
Then you're most likely not going to get the life/performance out of it that you should. I've never seen any manufacturer's instructions indicate that tooling is unnecessary.
Though I heartily agree that quad is a PITA to tool.
Tinstaafl is offline
Old 03-23-2015, 06:39 PM   #33
Brownchickenbrowncow
elementbldrs's Avatar
Trade: General Building
Rewards Points: 1,376
Re: Caulk
Typically, but there are definitely caulks out there indicate NOT to tool.
Phil
elementbldrs is offline
Old 03-23-2015, 06:54 PM   #34
Capra aegagrus
Tinstaafl's Avatar
Re: Caulk
Self-leveling maybe, but that's another sort of animal.
Old 03-23-2015, 07:17 PM   #35
avenge's Avatar
Rewards Points: 720
Re: Caulk
I think Big Stretch is one of those that shouldn't be tooled for it to actually "stretch". I always finger my interior caulk and it's failed. Before it can stretch it has to adhere.
Pretty sure on some caulks it states not to tool.
Old 03-23-2015, 07:21 PM   #36
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Caulk
"Proper bead" is very important. Not saying you don't know what that is but I have seen many people lay a bead down and use their finger and a wet sponge till there is hardly anything left. Really does no good to do it that way.
CrpntrFrk is offline
The Following 4 Users Say Thank You to CrpntrFrk For This Useful Post:
m1911 (03-25-2015), overanalyze (03-23-2015), Spencer (03-24-2015), Xtrememtnbiker (03-23-2015)
Old 03-24-2015, 01:20 PM   #37
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
Re: Caulk
Wish I could go back and redo all the trim in my house knowing this.
I didn't leave hardly any bead and a lot of it cracked in key areas.
Lewis Carpentry
Spencer is offline
Old 03-24-2015, 03:28 PM   #38
river rider's Avatar
Trade: general contractor
Rewards Points: 458
Re: Caulk
I think 3 sided adhesion issues are very often not taken into consideration enough either. (where applicable) I.E. - use backer rod or equivalent when you should. The just fill it with goo approach really restricts the elasticity abilities of the product.
GE 3500 and 5000 were my favorite for general use. The one yard that carried it replaced it with GE max extra about a year ago, and I think the 3500 and 5000 are discontinued. ...At least there's less trips out of my way to pick it up now.
I have a loathing for alex caulks. I feel about as good using it on a project, as I would brushing my teeth with it. It's idiotic that it's the most commonly available, and it's just about the worst thing out there IMO.
I have a lot of faith in sika for critical areas.
river rider is offline
Old 03-24-2015, 04:01 PM   #39
Rewards Points: 458
Re: Caulk
The bummer is, unfortunately, at some point you probably will get your wish. To go back and re do it.
....Of course it might piss you off every night as you look at it from the dinner table for 20 years before that happens.
Old 03-24-2015, 04:04 PM   #40
Livin the dream...
Spencer's Avatar
Re: Caulk
It's already incredibly annoying. It doesn't look awful but I'm ocd.
I'm just not sure it will look right to redo it and brush over the affected areas.
Lewis Carpentry
Spencer is offline
How to Caulk a Crisp Corner instock Painting & Finish Work 35 02-21-2014 04:31 PM
Matching Grout Caulk to Sealed/Enhanced Grout clintonjeffries Flooring 3 04-25-2013 07:04 PM
Expansion joint caulk SuperiorHIP General Discussion 12 08-15-2012 07:37 AM
Whats a good caulk gun for concrete epoxy? Project_Pat Tools & Equipment 18 01-02-2012 07:42 PM
Primer Cracking over Caulk go_hercules Painting & Finish Work 11 01-19-2011 08:39 PM
