Can I Sister Next To And Leave Fire Damaged Framing? - General Discussion - Contractor Talk
Old 06-29-2015, 06:17 PM   #1
67Mustang's Avatar
Trade: General Building
Rewards Points: 58
I have a workshop that suffered a fire. Getting ready to begin repairs and curious if fire damaged boards can be left and new wood sistered in as needed? This would be for some rafters / 2x4 wall framing etc. Would remove as much as practical but I'm sure you know there are times when it is way easier to leave the old stuff and sister in new material next to the old.
Wondering if a fire damaged board will continue to degrade somehow? Thanks for any help.
67Mustang is offline
Old 06-29-2015, 06:52 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,355
Re: Can I Sister Next To And Leave Fire Damaged Framing?
Won't hurt anything to leave the old stuff there, but you'll never get rid of the smell.
Tinstaafl is offline
fjn (06-30-2015)
Old 06-29-2015, 07:25 PM   #3
VinylHanger's Avatar
Rewards Points: 10,314
Spray the livin' Wizz out of it with kilz or similar. Actually several light coats is better, but livin' whizz is such fun to type.
Might still have some odor on a hot day, but it should make it tolerable.
VinylHanger is offline
Old 06-29-2015, 07:29 PM   #4
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
When in doubt rip it out. Burnt or chard wood needs to be replaced and in some cases severe smoke damage.
Rip it out as much as you can without compromising the structure then spray everything
festerized is offline
Old 06-29-2015, 08:26 PM   #5
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,960
When I was taking my contractor course. Painting it silver was the method they were using to seal the smoke smell.
Not sure why.
B.D.R. is offline
Old 06-29-2015, 09:51 PM   #6
67Mustang's Avatar
Rewards Points: 58
Thanks for the replies. Will remove as much of the burnt wood as possible. Cover the rest with Kilz or similar.
Old 06-29-2015, 10:22 PM   #7
aptpupil's Avatar
Rewards Points: 1,894
Kilz better than bin?
aptpupil is offline
Old 06-29-2015, 10:44 PM   #8
FrankSmith's Avatar
Rewards Points: 5,124
Not sure why.
Silver paint possesses some borderline supernatural qualities.
FrankSmith is offline
The Following 2 Users Say Thank You to FrankSmith For This Useful Post:
B.D.R. (06-30-2015), Kowboy (06-30-2015)
Old 06-29-2015, 11:14 PM   #9
Texan
j_sims's Avatar
Rewards Points: 68
Not sure why.
The aluminum flakes in the paint wrap around it like Reynolds Wrap
Make sure it's a shellac based primer
TEXAS Born, TEXAS Bred, When I Die, I'll be TEXAS Dead
j_sims is offline
The Following 2 Users Say Thank You to j_sims For This Useful Post:
hdavis (07-02-2015), Rio (07-01-2015)
Old 06-29-2015, 11:17 PM   #10
aptpupil's Avatar
That's what I thought. Bin better than kilz for odor.
aptpupil is offline
Old 06-30-2015, 07:42 AM   #11
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 12,348
BIN better than Kilz for everything.
For what it's worth, I worked out of a shop/barn that had sustained a pretty massive fire. Sistered everything. Didn't do anything in the ways of sealing. I never noticed much of an offensive odor.
Easy Gibson is offline
The Following User Says Thank You to Easy Gibson For This Useful Post:
illbuildit.dd (07-01-2015)
Old 06-30-2015, 11:41 AM   #12
Capra aegagrus
Tinstaafl's Avatar
Yeah, but you live in Jersey.
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
hdavis (07-01-2015), jproffer (07-01-2015), Sir Mixalot (06-30-2015)
Old 06-30-2015, 06:57 PM   #13
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,429
Bin is better. But Kilz Original is a close second. It does everything you need and is half the price.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 53,000 Subscribers and over 9,500,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
hdavis (07-02-2015)
Old 06-30-2015, 07:02 PM   #14
Yep! Just make sure it's an oil base stain blocking primer. I like to get it tinted the color of the undamaged wood so it blends in better. But I'm a little OCD...
Latex primers won't cut it.
-Paul
TextureMaster.com
Old 07-01-2015, 11:10 AM   #15
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
If the space is enclosed, you could rent a heavy duty ozone generator and let it run for 24 - 36 hours with all doors and windows closed. That will eliminate nearly all of the smell permanently. Then cover with bin and you should never have a problem with any smoke smell.
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
The Following User Says Thank You to CompleteW&D For This Useful Post:
SmallTownGuy (07-01-2015)
Old 07-01-2015, 11:13 AM   #16
67Mustang's Avatar
Rewards Points: 58
Will look into using an ozone generator. That is some great advice and something I would never have thought of. Thanks
The Following User Says Thank You to 67Mustang For This Useful Post:
CompleteW&D (07-01-2015)
Old 07-01-2015, 11:29 AM   #17
You're welcome... Ozone is used all the time in not only fire restoration businesses, but anywhere odors need to be reduced or eliminated. Car dealers use them in cars traded in that were owned by a smoker.
In fact, ozone has a LOT of uses other than odor reduction. Things like pool/hot tub sanitation rather than chlorine, commercial laundries, water treatment etc. The nice thing about ozone over corrosive chemicals, is ozone (O-3) is a very unstable molecule. It actively seeks other molecules to combine with. If it can't "find" any, it will go back to it's more stable form of O-2. So, it dissipates fairly quickly.
The down side to ozone, is in the atmosphere, it can combine with floro-carbons and other gases to make some fairly nasty "stuff" hence "ozone alerts" on really hot and hazy days.
- John Williams
The Following 2 Users Say Thank You to CompleteW&D For This Useful Post:
66 Shelby (07-02-2015), Rio (07-01-2015)
Old 07-01-2015, 06:04 PM   #18
B.D.R.'s Avatar
When my sailboat caught fire, and the interior was heavily smoke damaged.
The company doing the repairs put an ozonator on board for a couple of days. The boat was sealed up and could not be entered.
I was dubious but there is no smell of smoke 10 yrs later.
Worked well.
B.D.R. is offline
The Following 3 Users Say Thank You to B.D.R. For This Useful Post:
CompleteW&D (07-01-2015), dom-mas (07-01-2015), Rio (07-01-2015)
Old 07-01-2015, 06:18 PM   #19
EXACTLY..... ozone is the BEST at eliminating smoke or other organic odors.... pet pee, organic decay (mold/mildew), smoke (either fire related or cigar/cigarette) etc.
- John Williams
Old 07-01-2015, 09:30 PM   #20
Chad McDade's Avatar
Trade: Carpenter/GC
Rewards Points: 344
Ozone works wonders. The company I worked for when I did insurance resto work had a couple big (16'x16') ozone chambers - they would take clothes that had been in a house fire and reeked of smoke so bad your eyes would water, stick them in the chamber, crank it up and when it was done those clothes didn't have a drop of smoke odor.
__________________________________________________ ____________________________________________
“When the only tool you have is a hammer, you tend to see every problem as a nail.” - Abraham Maslow
Chad McDade is offline
21 photos that will leave you speechless Calidecks Off Topic (Non Trade) 2 11-10-2014 07:42 AM
Leave the wormdrive thread alone jlsconstruction Off Topic (Non Trade) 66 12-31-2013 12:37 AM
Basement framing techniques. C2projects Framing 51 11-23-2013 04:28 PM
Have a unique framing technique? Kent Whitten Framing 62 06-25-2007 08:25 AM
Can I just leave primer alone? metomeya Painting & Finish Work 6 05-20-2006 11:59 PM
