Can Anyone Help Me With This? How Is This Attached? - General Discussion - Contractor Talk
Old 02-13-2019, 02:32 PM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,902
I've cleaned out the holes, but I'm not seeing any screws or bolts.
Is this perhaps one of those where the entire cover screws on?
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 02-13-2019, 02:43 PM   #2
Caleb1989's Avatar
Rewards Points: 278
Re: Can Anyone Help Me With This? How Is This Attached?
Have you tried just yanking up on it?
Caleb1989 is online now
Old 02-13-2019, 02:44 PM   #3
Trade: Highwayman
Oh yeah.
Get Off My Lawn.
Old 02-13-2019, 02:54 PM   #4
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 11,572
Sewer? You're on your own, pal!
If there's a highway to hell and only a stairway to heaven, that pretty much tells you what the traffic patterns are expected to be.
480sparky is online now
Old 02-13-2019, 03:00 PM   #5
GC/carpenter
Calidecks's Avatar
Rewards Points: 15,354
Is too heavy to just lift without equipment imo.
Mike.
_______________
Calidecks is offline
Old 02-13-2019, 03:14 PM   #6
Trade: Highwayman
No, I think it's an 8".
Usually, there's a couple of bolts that unscrew, or else the whole lid spins.
It's got significant rust on it.
I need to block the sewer to water test the new drain lines.
If I can't get in there, I'll cut the line under the building and add a combo to stick my plug into.
Get Off My Lawn.
Calidecks (02-13-2019)
Old 02-13-2019, 03:15 PM   #7
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 710
It should just lift out.
I've run across some that get years of dirt and corrosion along the perimeter that won't budge.
We hit 'em with a sledge hammer while prying with a long bar, usually gets it to break free. When I say hit it with a sledge...I mean hit that s.o.b. not in the center but around the edges.
www.gebcon.com
tgeb is offline
The Following 2 Users Say Thank You to tgeb For This Useful Post:
dayexco (02-13-2019), Thoff93 (02-15-2019)
Old 02-13-2019, 03:38 PM   #8
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,664
To me, it looks like those indents are ready-made for a wrench of some sort to screw it out.
Andy.
ScipioAfricanus is offline
Old 02-13-2019, 03:45 PM   #9
Trade: Highwayman
I'm sitting here at the dealer getting the oil changed on my truck, so I have some time to ponder this before I head back over there.
I think I've eliminated the possibility that it bolts down, so maybe I'll just wail on it a little more.
Get Off My Lawn.
Old 02-13-2019, 04:03 PM   #10
dayexco's Avatar
Rewards Points: 86
what tom said. make sure you wire brush the lid and the seat before reinstalling so it doesn't rock
dayexco is online now
Old 02-13-2019, 04:55 PM   #11
rustyjames's Avatar
Rewards Points: 1,646
Andy.
I'm thinking the same.
rustyjames is online now
Old 02-13-2019, 05:40 PM   #12
Texas Wax's Avatar
Rewards Points: 1,550
Andy.
Yup like a spanner wrench, with lugs that fit into the notches. I'd try a hammer to a block or screw driver or even chisel in the notch and see if it turns. Even if it's just rusted in the lateral forces might loosen it some.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 02-13-2019, 07:14 PM   #13
Trade: Highwayman
Thanks guys.
Victory is mine. But I did beat up a crow bar pretty good in the process.
It ended up being a pop off. But I did turn it to loosen it, so everyone was right.
Thanks again.
Get Off My Lawn.
The Following 9 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Calidecks (02-14-2019), griz (02-13-2019), rustyjames (02-13-2019), ScipioAfricanus (02-13-2019), Texas Wax (02-14-2019), tgeb (02-13-2019), TheConstruct (02-13-2019), Tinstaafl (02-13-2019), Xtrememtnbiker (02-13-2019)
Fire break between house and attached garage PrecisionVision Carpentry 2 04-02-2015 03:13 PM
vapor barrier and laminate with pad attached bluebird5 Flooring 9 07-14-2012 07:28 PM
Below grade attached garage, concerns new home owner Construction 1 09-06-2010 08:14 AM
OSB with rigid foam board factory attached im4snow Framing 1 10-29-2008 08:22 PM
