Can Any One Id This Wall Sensor - General Discussion - Contractor Talk
Old 06-14-2012, 12:02 AM   #1
HUDSONVALLEYEXT's Avatar
Trade: EXTERIORS
Rewards Points: 250
Can any one ID this wall sensor?
its about 4 inches x 4 inches
snowflake looking design on it
there is a single yellow wire but I think theres smaller
wires inside the yellow casing
the cover will not come off and I don't want to break it
VOC's?
Moisture?
CO2?
see photos
can any one id this wall sensor-sensor1.jpg   can any one id this wall sensor-sensor2.jpg   can any one id this wall sensor-sensor3.jpg   can any one id this wall sensor-dsc08872.jpg
HUDSONVALLEYEXT is offline
Old 06-14-2012, 04:34 PM   #2
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
Re: Can Any One Id This Wall Sensor
Not sure myself, try posting this in the electrical section, maybe one of low voltage guys knows what it is. My guess would be motion at the level it is mounted but then it would only cover the door itself. Have you tried to see where the wire goes?
woodchuck2 is offline
Old 06-14-2012, 04:36 PM   #3
wooddan's Avatar
Trade: Framing and Trimwork
Rewards Points: 91
I would pop the cover off and read the back. Im sure theres a serial# or name on the back
wooddan is offline
Old 06-14-2012, 08:25 PM   #4
Hmbldr's Avatar
Trade: Residential contractor
Rewards Points: 150
The design looks more like a flower than a snowflake to me. So I was thinking along the line of an electronic air freshener.... or maybe an air sensor of some sort. Does not appear to have any 'eyes' to be a motion sensor. There appears to be a tab relaese on the left side of the face plate.
Could also be a announcer horn for alarm, etc.
In any case, it is a cheap plastic chinese cover of some sort.
Did you try lifting upwards? - may be just hanging on screws via keyholes.
Hmbldr is offline
Old 06-14-2012, 09:05 PM   #5
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Guess there's no way to follow the cable? Could be a frost stat.
www.bcconstructionllc.com
BCConstruction is offline
Old 06-14-2012, 09:31 PM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,195
I would venture a thermostat of some sort. Looks like the edge of the flower design and case are designed to let air into the box. Plus the wire going into it looks to be a cable that would hold a pair or more of wires so it must be a low current device.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 06-14-2012, 09:46 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 2,310
IMO, too high to be a stat...
The "wire" looks suspiciously like a fiber...
where does it go?....
Pop the cover...what does it say?
Building monitored by anyone & for what?
griz is online now
Old 06-14-2012, 10:04 PM   #8
Hmbldr's Avatar
Rewards Points: 150
Hmbldr is offline
Old 06-15-2012, 07:20 AM   #9
ttech's Avatar
Trade: Low Voltage Telecom Installer
It was put in by the phone company for fiber. It is simply a tube that runs from the suite to the demarcation point.
They were generally don't have the fiber in them yet because it would be expensive and unless you got FiOS, useless.
ttech is offline
The Following User Says Thank You to ttech For This Useful Post:
AustinDB (06-15-2012)
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 18 11-22-2017 08:11 PM
Painting over ancient wall paper [email protected] Painting & Finish Work 5 01-15-2011 02:33 PM
Waterproofing Exterior of Block Wall questions. hevnbnd Masonry 0 11-09-2010 08:42 PM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
Major wall frame remodel Jackpine Framing 0 09-03-2008 09:06 AM
