Built To Last? - General Discussion - Contractor Talk
Built To Last?
Old 12-17-2009, 08:55 PM   #1
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Built To Last?
We're on a job right now and part of it is to re-do a small ensuite. Typical subdivision stuff, tile on mesh 1/4" thick. My apprentice, not knowing any better says "why not just use 1/4" cement board?"
Well, that started it, poor guy, all the way home I'm telling him about all the **** out there, and that I'm not going to be a part of it. I want to construct buildings and renos that will last a LONG time.
Buildings, at least 100yrs. Renos are somewhat controlled by the amount of money the client has to spend. But using the tile as an example, if it isn't going to last 30-40 yrs. then I'm not doing it.
It seems every day someone is coming up with some fast, easy way/material to do the job cheaper. Most of this stuff is designed to last a few years at best I think. It's an ongoing battle to convince the HO to spend the money to do a job that will last.
Ok, so how long are you building for ?
katoman is offline
Old 12-17-2009, 10:40 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,744
Re: Built To Last?
'Till I get run out of town.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
fairfaxgc (12-18-2009), Tom Struble (12-18-2009)
Old 12-18-2009, 12:25 AM   #3
Teetorbilt's Avatar
Re: Built To Last?
You might want to look into Hardie products. http://www.jameshardie.com/index.html It's what I'm using on my personal outbuildings, it also meets the Miami-Dade high velocity wind codes.
Sometimes shortcuts get you into trouble. Othertimes advancements can be overlooked. At least your apprentice seems to be on top of things and offered an opinion, sounds like you have a winner.
Albert Einstein
Teetorbilt is offline
The Following 2 Users Say Thank You to Teetorbilt For This Useful Post:
katoman (12-18-2009), Mike Finley (12-18-2009)
Old 12-18-2009, 12:44 AM   #4
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,760
Re: Built To Last?
Um, yes it sounds like you have a real problem with that apprentice, it will only get worse over time.
You better send him down here for remedial training straight away
jhark123 is offline
The Following User Says Thank You to jhark123 For This Useful Post:
Old 12-18-2009, 06:43 AM   #5
HSConstruction's Avatar
Rewards Points: 250
Re: Built To Last?
I agree with not taking "el cheapo" shortcuts but you need to be open to new products that offer equal or greater quality at reduced price or install time. Using the mesh as an example, do you know for a fact that it will fail in a few years or do you just assume this because its not how "You" do it.
HSConstruction is offline
Conventional built vs. Modular built D.A.S.Anthony General Discussion 23 07-18-2010 09:26 PM
Whats The most expensive deck you've built deck king Decks & Fencing 96 07-10-2010 08:02 PM
Log home that I built. strathd Carpentry Picture Post 12 05-12-2009 08:51 PM
Sizing built up deck beams Unforgiven Decks & Fencing 17 09-08-2008 09:03 PM
