Building Ada Wooden Ramps - Page 2 - General Discussion - Contractor Talk
Old 05-30-2012, 04:53 AM   #21
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Re: Building Ada Wooden Ramps
I cant seem to grasp the concept of figuring the planks.
Figuring this out isn't even really construction related. This is one of those 5th grade arithmetic problems where you say:
1. I have a ramp that's 20 feet long.
2. My boards are 5 inches wide.
3. 1 foot equals 12 inches.
4. My ramp is 240 inches long.
5. Divide that by 5.5
6. I need to make 44 planks.
7. Each uncut board is 12 feet long
8. For a 5 foot wide ramp I can get 2 planks out of each board.
The rest should be easy enough.
tedanderson is offline
The Following User Says Thank You to tedanderson For This Useful Post:
raydlr (06-09-2012)
Old 05-31-2012, 08:25 PM   #22
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 744
ada rules?, r/c construction i dont think so, commercial yes. ada guide lines r/c its my house my land my wheel chair and my 20oz soda
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
raydlr (06-09-2012)
Old 06-01-2012, 10:15 AM   #23
PA woodbutcher's Avatar
Rewards Points: 1,000
But it is the ambulance crew that has to deal with it when they have to come.
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
The Following User Says Thank You to PA woodbutcher For This Useful Post:
wally1405 (06-03-2012)
Old 06-01-2012, 11:05 AM   #24
TRADE CRAFTSMAN.
SAW.co's Avatar
Trade: general contractor
Originally Posted by raydlr View Post
Time and time again I hassel with figuring materials on building a ramp. The ramps im building have a 5x5 landing then go out x amout of feet. I cant seem to grasp the concept of figuring the planks. Ive searched for calcjlators or apps even programs to speed up the process , but no luck. Any sugestions.
The way I figure decking is to take the total square footage and multiply by 2.25 this will give you the total lineal footage, when using 2x6 decking.
Then you can divide that by any length you want to use and know exactly what to purchase including 5% for wast of corse.
works for me every time
SAW.co is offline
Old 06-01-2012, 11:14 AM   #25
SDC's Avatar
Rewards Points: 256
As far as I knew, ADA ramp in a private home are not required....good suggestion but not required
From this webpage
http://www.eeoc.gov/index.cfm
Q. Does the ADA cover private apartments and private homes?
A. The ADA generally does not cover private residences. If, however, a place of public accommodation, such as a doctor's office or day care center, is located in a private residence, those portions of the residence used for that purpose are subject to the ADA's requirements.
David Cookman
Twitter
SDC is offline
Old 06-01-2012, 10:39 PM   #26
sunkist's Avatar
Rewards Points: 744
woodbutcher its a ramp dead guy rolled to the bottom that why its 1 in 12 pitch to make sure he rolls all the way (he could go all the way!!)
sunkist is offline
Old 06-01-2012, 11:42 PM   #27
TRADE CRAFTSMAN.
SAW.co's Avatar
Ramps are not required for residential however if the customer request one the inspector will expect it to be built to ada standards at least around here. I've don a few for H/O they take up a lot of real estate.
SAW.co is offline
High Value green building program points? Matt G Green Building 11 03-02-2010 03:39 PM
Salvage value of an old commercial building CharlesD General Discussion 14 01-24-2010 10:26 PM
Pipe-dreaming inquiry - building multi-units. bob_cntrctr General Discussion 2 04-27-2009 10:41 AM
Underground in building low voltage OhioTelecom NEC Discussion 4 03-22-2009 02:22 PM
