Builder - General Discussion - Contractor Talk
Builder
Old 11-26-2012, 02:29 PM   #1
WELCHCONST1's Avatar
Trade: HOME BUILDER, REMODLER, HVAC CONTRACTOR
Builder
Ive got a 1500 sq. Ft. Ceiling on a 7/12 pitch shed style.
Engineered trusses 2.5' between ceiling and decking, batt
style insulation in between. Trusses are cleated and engineered for the span.
I'm wanting to go over the existing sheetrock with a foam backed board, maybe osb? After this is installed wanting to go with a tongue and groove aspen.
Question is can the celing still breathe with the foam core?
Then there's the weight question, in which i'll get back to my truss builder for my load calcutions..
My thinking is with the drought were in the t&g will expand and contract alot better than sheetrock.. And will look great!
WELCHCONST1 is offline
Old 11-26-2012, 02:32 PM   #2
Custom Builder
Chris@Sunrise's Avatar
Rewards Points: 502
Re: Builder
Why foam
Chris@Sunrise is offline
Old 11-26-2012, 07:16 PM   #3
Box Builder
Morning Wood's Avatar
Rewards Points: 10,346
Re: Builder
Not the way I'd do it. But, you can do that. Figure out what type of foam you are using and check it's vapor permeability with osb glued to it. There are guidelines for your climate zone.
Morning Wood is offline
Miscommunication between builder and HO shelf guy General Discussion 8 03-28-2012 09:42 PM
Builder cut out breaker panel in foreclosed home? BACKWOODS NEC Discussion 16 08-30-2010 09:45 PM
Ask the Builder Hoof Hearted General Discussion 85 10-20-2009 09:51 PM
Custom Home Builder vs. Spec and Tract Builder renet General Discussion 4 11-16-2008 01:51 AM
