Brainstorming How To Reach These Soffits & Fascia For Painting - General Discussion - Contractor Talk
Old 09-21-2019, 01:44 PM   #1
rpmike's Avatar
Rewards Points: 4
Hey guys! Fella from the painttalk forums coming over here to ask you guys a question,
I'm working on an exterior stucco paint job and the H.O's have requested I paint all the metal soffits, fascia, and eves. No problem. I have a lift for 80% of the upper areas on the house. However, in the back yard a lift can not fit. I thought I'd be able to use my roof jacks and reach, but I'm about a foot to two feet short in some spots.
Trying to brain storm an idea to safely reach the red-lined areas in the picture, allowing me to mask the stucco and spray the soffits. Budget is somewhat fluid but ideally want to avoid getting a scaffolder to come in and construct an expensive set up.
Brainstorming how to reach these Soffits & Fascia for painting-soffit-fascia.jpg
rpmike is offline
Old 09-21-2019, 02:04 PM   #2
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 7,266
Re: Brainstorming How To Reach These Soffits & Fascia For Painting
Looking for the OSHA approved way it just want to get it done ?
NYgutterguy is online now
The Following 2 Users Say Thank You to NYgutterguy For This Useful Post:
cedarboarder (09-21-2019), rpmike (09-21-2019)
Old 09-21-2019, 02:25 PM   #3
Caleb1989's Avatar
Rewards Points: 324
Just rent or borrow some scaffolding, and plank over to your roof jacks
Caleb1989 is offline
The Following User Says Thank You to Caleb1989 For This Useful Post:
SmallTownGuy (09-21-2019)
Old 09-21-2019, 02:26 PM   #4
rpmike's Avatar
Rewards Points: 4
OSHA first, otherwise I do have a former employee and drinking buddy of mine who weighs 100lbs soaking wet and some rope if need be!
rpmike is offline
The Following 3 Users Say Thank You to rpmike For This Useful Post:
A&E Exteriors (09-22-2019), cedarboarder (09-21-2019), TheConstruct (09-21-2019)
Old 09-21-2019, 04:44 PM   #5
test
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 874
Like Caleb said. I'd use scaffold off the ground then plank on to roof.
Look for a scaffold renter. It is very cheap to rent. The first time I rented I was pissed off at myself for not doing it sooner.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
The Following 3 Users Say Thank You to cedarboarder For This Useful Post:
Seven-Delta-FortyOne (09-21-2019), SmallTownGuy (09-21-2019), TheConstruct (09-21-2019)
Old 09-21-2019, 05:25 PM   #6
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,498
or leave what you got and then borrow a pair of drywaller stilts...
SmallTownGuy is online now
Old 09-21-2019, 05:52 PM   #7
Box Builder
Morning Wood's Avatar
Rewards Points: 9,892
Like has been said or instead of the scaffold use a pump jack but then you are fixing holes in the fascia. Id also put your roof jacks up higher and then if need be put a step ladder against the house off your planks to reach the top. Not a big step ladder though, a small one and do it smartly.
Morning Wood is offline
Old 09-21-2019, 06:06 PM   #8
avenge's Avatar
Rewards Points: 720
For that little bit I would use a Pivit, stepladder and the roof jacks to hold the pivot if needed.
avenge is online now
Old 09-21-2019, 08:37 PM   #9
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 3,450
Probably not OSHA but why not a taller ladder in place of the 8' that would extend to the next roof level, and tied off.
Added angle looks like it would get you there.
Sent from my LG-LS993 using Tapatalk
TxElectrician is online now
Old 09-21-2019, 08:45 PM   #10
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 3,146
One of these ?
https://www.amazon.com/Shur-Line-550...03484311&psc=1
Idothat is online now
Old 09-21-2019, 09:35 PM   #11
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,597
Multi ladder AKA Little Giant
Use a toe board or roof jacks it keep it from sliding
Brainstorming how to reach these Soffits & Fascia for painting-6d35e0eb-adf0-4a74-aca1-9402de2b3486.jpeg
WBailey1041 is online now
The Following User Says Thank You to WBailey1041 For This Useful Post:
hdavis (09-21-2019)
Old 09-21-2019, 09:54 PM   #12
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 278
Crane basket.
Park the crane in the street, (don't forget traffic control, and encroachment permit from the city ), and boom over the house.
Piece of cake.
Yea, that's how I roll.
Figured since you got some good advice, I could throw in a BS post.
Remember when "Climate Change" was a thing??
Old 09-21-2019, 11:31 PM   #13
hdavis's Avatar
Rewards Points: 1,082
X2 on the multiladder.
From the looks of it, you could also run a 32' ladder from the ground on the left to the ridge on the right.
hdavis is online now
Old 09-22-2019, 12:29 PM   #14
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 1,560
Ladder against the side with a ladder Jack. Then a plank from the ladder jack to the roof.
EricBrancard is online now
Old 09-22-2019, 02:31 PM   #15
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,464
Find someone taller? Is it really that much of a reach? If it were me I'd rope off over the roof and lean so I'm perpendicular to the roof I'm standing on. Much shorter reach that way.
Golden view is offline
Old 09-22-2019, 05:32 PM   #16
test
Trade: Workaholic
Rewards Points: 874
The Following User Says Thank You to cedarboarder For This Useful Post:
Idothat (09-22-2019)
Old 09-22-2019, 07:21 PM   #17
Mordekyle's Avatar
Rewards Points: 5,038
Mordekyle is offline
