Best Way To Fasten 2x4 To Thin Metal? - General Discussion - Contractor Talk
Old 08-23-2019, 11:04 PM   #1
Awningguy's Avatar
Trade: Awning
I need to install a 2x4 piece of wood about 12 ft long on top of a flat pan patio cover. The aluminum sheets are about .032 or maybe .036 the most. I need this wood to go thru the top thru the sheet and be able to hold a 35 lb object in place.
I was thinking about driving a few 3/8 stainless steel lag bolts thru with double washers on both sides and a nut on the bottom to tighten it.
Is there any better way to hold it down?
Awningguy is offline
Old 08-23-2019, 11:13 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 678
Re: Best Way To Fasten 2x4 To Thin Metal?
how will you install a nut on a lag bolt?
griz is offline
The Following 7 Users Say Thank You to griz For This Useful Post:
acro (08-26-2019), fjn (08-24-2019), hdavis (08-23-2019), jproffer (08-27-2019), Robie (08-24-2019), sunkist (08-29-2019), TheConstruct (08-27-2019)
Old 08-23-2019, 11:16 PM   #3
hdavis's Avatar
Rewards Points: 2,262
Glue
hdavis is online now
Old 08-23-2019, 11:21 PM   #4
Awningguy's Avatar
Trade: Awning
I meant a bolt not lag bolt
Old 08-23-2019, 11:35 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 678
use 1/4" bolts w/fender washers and put some silicone between the 2x and metal.
griz is offline
sunkist (08-26-2019)
Old 08-24-2019, 07:48 AM   #6
woodspike's Avatar
Rewards Points: 726
i`m thinking toggle bolts
counter sink the head
woodspike is offline
Old 08-24-2019, 02:00 PM   #7
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,252
a picture would help .based on what i read i would use a bunch of these screws .small head ,super easy and weather proof .https://www.screwsolutions.com/Bronz...ews_c_147.html
JFM constr is offline
Old 08-26-2019, 02:23 PM   #8
AustinDB's Avatar
Rewards Points: 1,426
is the 2x4's job only to spread the weight across the awning? If I understand the description correctly, won't water be able to gather between the 2x4 and awning? I know some PT reacts with some aluminum, keep that in mind.
If this is for hanging something (like plants on bottom of awning) I would spread the weight with apiece of aluminum on top. Even better would be to use three pieces and form an H, if necessary. Maybe light weight potting soil/styrofoam would decrease the weight
AustinDB is offline
Old 08-26-2019, 05:47 PM   #9
Awningguy's Avatar
Trade: Awning
The wood is going on TOP OF THE flat pan roof. Hanging my 35 lbs piece on top of the wood.
The awning is a flat pan and the water runs down on a pitch to the gutter. So if we put a 2x4 which is yes to hold the weight spread evenly the only place water can leak is from the screws which I plan to caulk around them when I put the bolts in. I can also maybe get some flashing stripes and lay it down right where the woood is going and also caulk around the wood . I just want to make sure that a couple of bolts thru the wood into the flat pan thin metal will be able to hold the weight and not cause an issue.
The awning has a couple of posts under so I'm really just worried about the wood holding in place and not being able to ruin the sheets?
So would it be better to have the entire 2x4 for the whole width of the flat pan roof of 14 ft. Or just put small pieces like 3 individual pieces and lay my project on top of them and line them up with a chaulk line?
Old 08-26-2019, 08:46 PM   #10
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,082
I'm very curious as to why an Awning guy needs help with this.
Mike.
_______________
Calidecks is online now
Dirtywhiteboy (08-27-2019)
Old 08-27-2019, 01:01 AM   #11
Dirtywhiteboy's Avatar
Rewards Points: 13,092
Mike.
_______________
I guess he's very new at it??
Dirtywhiteboy is offline
Old 08-27-2019, 04:54 AM   #12
skintscot's Avatar
Trade: Painter Decorator
Rewards Points: 76
That's what these forums are here for!
skintscot is offline
The Following User Says Thank You to skintscot For This Useful Post:
Mordekyle (08-27-2019)
Old 08-27-2019, 08:08 AM   #13
Awningguy's Avatar
Trade: Awning
Mike.
_______________
I make awnings. This is not part of am awning.
Old 08-27-2019, 11:25 AM   #14
Mordekyle's Avatar
Rewards Points: 5,594
We all have to learn somewhere.
A picture is worth about 3000 words in this case.
Mordekyle is online now
The Following User Says Thank You to Mordekyle For This Useful Post:
Rio (08-27-2019)
Old 08-28-2019, 12:20 PM   #15
rounde683's Avatar
Trade: Electrician
Rewards Points: 32
Liquid nails over silicone.
Removed by staff
rounde683 is offline
Old 08-28-2019, 12:36 PM   #16
Then way are you using it
Old 08-28-2019, 02:50 PM   #17
rustyjames's Avatar
Rewards Points: 1,782
PL. Premium over both of those.
rustyjames is online now
Old 08-29-2019, 02:38 PM   #18
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Lag nuts Griz Lag nuts, like most nuts they have a hard exterior with a softer center in fact we call them griz nuts here in FL because of the hard exterior and soft center.
Here in FL they come as a 2 pack but are not sold in big box stores you have to go to a real contractor supply place.
Still "Shakin" the tree boss
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
Calidecks (08-29-2019)
Old 08-29-2019, 02:43 PM   #19
GC/carpenter
Calidecks's Avatar
You can buy them by the sack right?
Mike.
_______________
Old 08-29-2019, 02:44 PM   #20
sunkist's Avatar
Rewards Points: 890
I would love to know what this 2x4 across the top of a roof is for because at the moment placeing a piece of wood flat on a roof that needs to drain sounds bad.
Can you use false wood , plastics that's the future any one who ever graduated knows that even Mrs Robinson.
sunkist is offline
Railman (08-30-2019)
