Attaching 2x6 Ceiling Joists To Steel Beam, Web Blocking - General Discussion - Contractor Talk
Old 06-09-2015, 08:02 PM   #1
Tb545's Avatar
Trade: Residential
Rewards Points: 8
I am packing the web of a w8x15 with wood to install hangars for joists. Can i nail plywood to some 2x6s to get the depth to clear the flange or do i reallu need to rip down solid wood to get the depth i need. The face of web to end of flage is about 1.8 inches. Connecting with through bolts.
Tb545 is offline
Old 06-09-2015, 08:16 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,448
Re: Attaching 2x6 Ceiling Joists To Steel Beam, Web Blocking
Plans don't call this detail out?
Pretty good sized beam, no engineer or architect to ask?
griz is online now
Old 06-09-2015, 08:23 PM   #3
Tb545's Avatar
Trade: Residential
Rewards Points: 8
Well it calls out solid wood, but i was wondering what the standard of practice is because its common to pack the web of a beam to hang joists
Tb545 is offline
Old 06-09-2015, 08:25 PM   #4
Fire up the BBQ
griz's Avatar
Common construction practices are to follow plans, specs and applicable codes.
griz is online now
Old 06-09-2015, 08:57 PM   #5
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Inside web of a W8x15 should be 7 1/4" x 2"? just rip down a 2x8 and add 1/2" plywood, i run a router on the two edges to compensate for the welds
Attaching 2x6 ceiling joists to steel beam, web blocking-photo-apr-21-3-01-20-pm.jpg
festerized is offline
The Following User Says Thank You to festerized For This Useful Post:
Kowboy (06-10-2015)
Old 06-09-2015, 09:16 PM   #6
Tb545's Avatar
Trade: Residential
Rewards Points: 8
2 x 8 nominal is 1.5 inches, not 2 inches. That wont fill out the web.
Tb545 is offline
Old 06-09-2015, 09:20 PM   #7
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
That's why he said add 1/2" plywood.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
festerized (06-09-2015)
Old 06-09-2015, 09:24 PM   #8
David Festa
festerized's Avatar
every have just one of those days
Old 06-09-2015, 09:24 PM   #9
Tb545's Avatar
Trade: Residential
Rewards Points: 8
Got it. Makes sense.
Tb545 is offline
Old 06-09-2015, 09:35 PM   #10
Fire up the BBQ
griz's Avatar
In California, if you were to deviate from plans, such as using plywood rather than the called out solid lumber, the architect or engineer would have to sign off on it.
It's such a wonderful state....
griz is online now
Old 06-09-2015, 09:59 PM   #11
Tb545's Avatar
Trade: Residential
Rewards Points: 8
I agree, i just like to know generally what my answere may be before i submit an rfi.
Tb545 is offline
The Following User Says Thank You to Tb545 For This Useful Post:
griz (06-09-2015)
Old 06-09-2015, 11:24 PM   #12
kiteman's Avatar
Rewards Points: 16
I would rather put the plywood on the back, a quarter short top and bottom for the weld, and the hanger nails in the lumber.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
The Following 2 Users Say Thank You to kiteman For This Useful Post:
Kowboy (06-10-2015), slowsol (06-10-2015)
Old 06-10-2015, 06:06 PM   #13
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
We pack out beams all the time. We use 2x maferial and plywood of varying thicknesses to flush up the outside. We normally don't thru bolt. We use 3 inch self drilling steel screws for the first ply, then nail the remaining plys on. I try not to put plywood on the outside. Another thing we do often is use saddle hangers which hang off the bolted down plate on top of the beam. We have an engineer on every job, and he has no problem with our method.
muskoka guy is offline
The Following User Says Thank You to muskoka guy For This Useful Post:
Required size steel beam for this situation BCConstruction Decks & Fencing 116 04-21-2015 10:29 PM
Framing with steel article. Rich D. Decks & Fencing 6 02-02-2013 05:51 PM
steel beam spans wood framer General Discussion 12 03-07-2009 09:36 PM
Steel Beam tznuk Welding & Steel Trades 8 11-26-2008 07:20 AM
