Anyone Know This Metal Framing Info? - General Discussion - Contractor Talk
Old 12-29-2009, 05:12 PM   #1
d-rock's Avatar
Trade: carpentry/drywall/plaster
Rewards Points: 250
this is on a set of drawings i recently received to bid;
8SW18
i believe it represents an 8" C-Joist, but what is SW ? what do the letters and numbers peresent?
d-rock is offline
Old 12-29-2009, 05:47 PM   #2
mikec's Avatar
Trade: Boss
Rewards Points: 510
Re: Anyone Know This Metal Framing Info?
Check this out, I think it has the info you need.
http://files.buildsite.com/dbderived...ived310096.pdf
mikec is offline
Old 12-29-2009, 05:59 PM   #3
rustyjames's Avatar
Rewards Points: 1,834
I'm just guessing but I think SW might stand for solid web, as opposed to having the punched holes. And the 18 for the gage.
rustyjames is offline
Old 12-30-2009, 09:10 AM   #4
Carpenter
RizzoMaryland's Avatar
American Standard Wide Flanged
Example:
8SW18 = SW denotes American Standard Wide Flange. 8 is the nominal depth in inches, 18 is the weight per foot of length in pounds.
Despite contrary belief, there is no such thing as an "I" beam. They are wide flanged sections.
(Similar to cinder blocks...they stopped making those decades ago...they are now CMU (concrete masonry unit)
"An idea is salvation by imagination"
Frank LLoyd Wright
RizzoMaryland is offline
The Following 2 Users Say Thank You to RizzoMaryland For This Useful Post:
bwalley (12-31-2009), mics_54 (12-30-2009)
Old 12-30-2009, 11:10 AM   #5
mics_54's Avatar
Trade: contractor
I use the terms FIB, CMU and NFS alot to impress customers and make them ask what that is.
mics_54 is offline
Old 12-30-2009, 11:12 AM   #6
Anti-wingnut's Avatar
Rewards Points: 3,430
Sound of a bell, with clapping in the background
We have a winner.
A manufacturers number coresponding to a 8x18ga standard stud
Coming in dead last, and disqualified for specious guessing
Originally Posted by RizzoMaryland View Post
American Sstandard Wide Flanged
Example:
There are such things as an "I" beam. The inside of the flange of an "I" beam is not flat, and the flange width is much less than a comparable wide flange.
Beams are designated such as "S18x320" for a "standard" profile "I" beam 18" tall by 320 # per foot. A wide flange beam would have the written designation "W12x221" for a wide flange beam 12' tall, weighing 221# per foot. Some refer to wide flanges as "H" beams.
Of coarse the OP could have deduced that the plans probably were not calling for W8x18 24"OC
Anti-wingnut is offline
Old 12-30-2009, 05:35 PM   #7
Carpenter
We have a winner.
Your arrogance and narrow mindedness precede you.
There are NO SUCH THINGS AS "I" BEAMS. Your jobsite lingo and terminology are inaccurate and improper. The "I" beam you are referring to with a curved flange is an American Standard. A wide flange beam has a flat flange.
""H" beams"" and other similar terms used on a jobsite portray the lack of proper education on the materials. Now would you like to debate angles, legs and channels? Or square, round, and rectangular bars?
Frank LLoyd Wright
Old 12-30-2009, 09:08 PM   #8
The cyber spanking you are attempting to give me looses strength coming from someone who doesn't know the basic terminological difference between a 8sw18 steel stud, and a S8X18 American standard beam, colloquially referred to as an "I" beam by generations of Ironworkers.
I bet everyone thinks you are real smart when a freight car of structural iron shows up at your job, instead of a pickup load a steel studs
Old 12-30-2009, 09:30 PM   #9
Project Superintendent
mudpad's Avatar
Rewards Points: 2,000
So what are you bidding D-rock? Metal stud framing or structural steel? I think I know the answer.
mudpad is offline
Old 12-31-2009, 09:10 AM   #10
Carpenter
My mistake is that I should have read some of your previous posts prior to responding to you. The majority of them illustrate the cynicism that you demonstrate in this thread.
Please continue to provide useful knowledge and leave the BS for the uneducated that you learn your terminology from.
Frank LLoyd Wright
Old 12-31-2009, 09:32 AM   #11
Cry me a river. The basic fact is that when the OP asked a metal framing detail question, you wrongly specified a heavy piece of structural steel.
This is all BS babble, and all you can do is tell me I'm stupid because I realize that many refer to standard- and wide-flanged beams as "I" and "H"? You're the one who made the mistake, and continue to compound your mistake. You did not know the standard North American structural steel reference terminology. Big deal that you don't ever say "I" beam. I still don't see you getting a Nobel Prize in Construction anytime soon.
Old 12-31-2009, 09:41 AM   #12
d-rock's Avatar
Rewards Points: 250
thank you sir
d-rock is offline
Old 12-31-2009, 09:44 AM   #13
Pompass Ass
bwalley's Avatar
Rewards Points: 1,000
Example:
I used to try explaining to people they were not cinder blocks, and they were concrete blocks, some people even call them cement blocks.
bwalley is offline
Old 12-31-2009, 09:47 AM   #14
d-rock's Avatar
Rewards Points: 250
metal (steel) structural stud framing. Usually it's not indicated this way. it'll just have a detail section and show 16ga. 8" CRM, which is standard 16ga 8" c-joist. in this drawing, the prefix they gave was foreign to me. I had an idea of what it was, but I wasn't certain.
d-rock is offline
Old 12-31-2009, 10:05 AM   #15
Pompass Ass
bwalley's Avatar
8SW18
This is one reason why licensing is a good idea.
Obviously you don't understand what you are bidding on, how can you competently do the work?
bwalley is offline
Old 12-31-2009, 10:13 AM   #16
That is complete BS. The detail shown on the OP's plan was an obscure MS reference, one that many may not be familar with.
Old 12-31-2009, 10:20 AM   #17
Pompass Ass
bwalley's Avatar
That is a very common way to describe steel, it is not an obscure reference.
When I took the exam for my state of Florida contractors license, there were questions on steel like this and we had to work out the weights, heights etc. on them, the reason we are tested on this, is to prove to the state we know what we are doing.
bwalley is offline
Old 12-31-2009, 10:24 AM   #18
You're refering to 8SW18 as being a common metal stud designation? It must be a regional thing
Old 12-31-2009, 10:30 AM   #19
Pompass Ass
bwalley's Avatar
No that is not a steel stud.
It is a wide flange steel beam or cloumn, depending on its location.
have you ever worked with steel studs that weigh 18 lbs per lineal foot?
bwalley is offline
Old 12-31-2009, 10:55 AM   #20
I have worked all over the western US and never seen a steel beam referred to as 8SW18 on plans. They have always been referred to as W8X18 (sizes are merely for example).
I goggled (W8X18 steel beam) and got a ton of structural steel hits. I goggled (8SW18 steel beam) and got a single steel framing system hit.
Framing with metal studs Rich Construction 41 05-26-2013 01:13 AM
Atlanta,Ga commercial drywall and metal framing fman Help Wanted or Looking For Work 35 05-30-2011 08:47 AM
sub panel ground bars and grounding metal boxes jkfox624 Electrical 6 04-18-2010 02:01 PM
Price4 interior walls metal framing batukspec General Discussion 18 08-22-2008 05:30 PM
what is the going rate in metro atlanta for metal framing and droping ceiling moniquetrinh Commercial Construction 7 10-11-2007 03:28 PM
