Anyone Cutdown A Metal Exterior Door? - General Discussion - Contractor Talk
Old 03-30-2019, 02:32 PM   #1
BLI's Avatar
Rewards Points: 12
Doing an estimate on moving the location of a front entry door and installing a new one. They currently have a wood door that’s cut down, this is an old bunglow type house and does not have a full size door. Has anyone cut down a prehung metal exterior door? I have cut down a prehung metal interior fire door once but If I remember correctly I just removed the sweep and didn’t reinstall it. Is the sweep able to be reinstalled?
BLI is offline
Old 03-30-2019, 02:56 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Re: Anyone Cutdown A Metal Exterior Door?
I have cut down a ext metal door ONCE, I will not do it again really do not recall the sweep.
Still "Shakin" the tree boss
sunkist is offline
Old 03-30-2019, 03:32 PM   #3
CPMKW's Avatar
Trade: GC PM
Rewards Points: 362
I have had to cut them down a number of times to use them on the cold room door in a basement.
Cutting the door is no problem, just used a demo blade in a skilsaw. Either put the original sweep back on or buy an aftermarket one.
I always hate cutting down the jamb. Takes more time and effort than the door.
Sent from my SM-G930W8 using Tapatalk
CPMKW is online now
The Following User Says Thank You to CPMKW For This Useful Post:
pinwheel (03-30-2019)
Old 03-30-2019, 05:56 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 486
Just like working with coil stock. Score the metal skin with a utility knife (multiple passes), bend and break it off. Then cut the wood core with your circular saw. No big deal after you've done it once or twice.
Tinstaafl is online now
fjn (04-03-2019)
Old 03-30-2019, 07:13 PM   #5
builditguy's Avatar
Rewards Points: 1,958
They make a new rubber seal for the bottom. It slips over the bottom of the door. Easiest way to go
builditguy is offline
Old 03-30-2019, 10:49 PM   #6
TimNJ's Avatar
Rewards Points: 5,700
How much of a cut?
I usually will find a way to put in a stock size, unless the opening is masonry. Then I would have it cut down on order.
If the company cuts it down they usually just put a slip on sweep on the bottom of the door.
TimNJ is offline
Old 03-31-2019, 07:19 AM   #7
woodspike's Avatar
Rewards Points: 726
i`d stay on the outside of that knife-score line ,just a tad .
and then polish it with my grinder last.or even a belt sander with an 80 grit belt .
goggle , and gloves a must on this one.
stay away from a glass door too!!
lol . years , YEARS BACK , i did this in a high rise .
without thinking i did it too close to the sliding doors .
the sparks were hitting the glass . i just didn't think about it till i was done . the glass doors looked like they were sprinkled with pepper. it was hundreds of little burn marks.
and the glass was blue....yes the whole building has blue glass sliding glass doors.......
lets just say some of the good old days weren't good..
woodspike is offline
Old 03-31-2019, 07:19 AM   #8
rblakes1's Avatar
Rewards Points: 3,630
Have your supplier price out a custom sized door. The cost difference will probably be about the labor charge for cutting the door and jamb down
-Rich
rblakes1 is offline
Old 03-31-2019, 08:14 AM   #9
General Contractor
greg24k's Avatar
Rewards Points: 8,480
I cut the top of the door, take the head off, cut the jamb's put the head back and cut the door.
greg24k is offline
Old 03-31-2019, 09:03 AM   #10
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,052
For short doors I have just used fiberglass one and have them cut. Really not much more money. They can be cut shorter and narrow if need be.
Randy Bush is online now
Old 03-31-2019, 09:18 AM   #11
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,124
If you are talking about a commercial steel door and frame, yes I've cut many down in height. They are heavy enough material that you can reinstall the end cap and weld or rivet it back in place. Would not try this with most residential grade metal doors as they are not nearly as heavy, I'd just buy a custom size door.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
fjn (04-03-2019)
Old 04-03-2019, 11:53 AM   #12
fjn's Avatar
Trade: mason
Rewards Points: 11,202
We have several Ceco door shops by us,they can fix you up with just about anything and they are very reasonable.
fjn is offline
Sealing Metal Valley Section artinall Roofing 20 11-07-2012 12:18 PM
Metal Roof - Rain Diverter artinall Roofing 3 08-12-2012 11:00 PM
shelf supports into metal studs cleveman Carpentry 17 04-17-2012 12:34 PM
sub panel ground bars and grounding metal boxes jkfox624 Electrical 6 04-18-2010 02:01 PM
Metal vs Plastic bullnose lpp Drywall 4 01-27-2009 11:44 PM
