Any Of You NorCal/PNW Guys Remember...... - General Discussion - Contractor Talk
Old 08-09-2019, 08:41 PM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 778
.....Gorilla Hair? Or that's what some called it.
It was a shredded redwood bark insulation. I assume treated with Borate, but I don't know.
Probably my second or third construction job, when I was about 14 or 15, was pulling that stuff out of the attic of a middle school.
Old 08-09-2019, 08:55 PM   #2
VinylHanger's Avatar
Rewards Points: 11,494
Re: Any Of You NorCal/PNW Guys Remember......
Never seen it. It doesnt sound very fire safe. Though bark is a bit fire resistant. Does the borate make it fire proof?
VinylHanger is offline
Old 08-09-2019, 09:28 PM   #3
Trade: Highwayman
Rewards Points: 778
That's probably why it's no longer in use, however, it's nearly impossible to ignite redwood bark.
And yes, Borate makes it fireproof and rodent proof.
There is, or was, some pretty cool cotton denim batt insulation, It was made mostly from recycled jeans.
It was treated with Borate, too.
It was the most comfortable insulation I've ever felt. Unfortunately, it was about 3 times cost of fiberglass.
Old 08-09-2019, 09:39 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 380
Yes, i recall seeing it.
Never used it, just removed it.
griz is online now
Seven-Delta-FortyOne (08-09-2019)
Old 08-09-2019, 11:58 PM   #5
hdavis's Avatar
Rewards Points: 1,556
Sawdust is common up here, especially cedar sawdust, but mostly in the walls.
Shredded bark would work in an attic, but I'm not sure it would be better than the old pants, petticoats, corsets, and newspapers people used.
IIRC, redwood bark is fire resistant, which helps the trees live through forest fires.
hdavis is offline
