Any Tricks To Shortening A Split Rail Fence? - General Discussion - Contractor Talk
Old 04-22-2010, 08:30 AM   #1
remster's Avatar
Trade: General Carpentry
Rewards Points: 25
Any tricks to shortening the length of a split rail and keeping the original look. I was thinking of using sawzall with long rough wood bit.
This style rail:
remster is offline
Old 04-22-2010, 08:38 AM   #2
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
Re: Any Tricks To Shortening A Split Rail Fence?
"Shortening the length", eh? Just take a few posts and rails out.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 04-22-2010, 08:43 AM   #3
remster's Avatar
Rewards Points: 25
Thats not going to work when you want the fence to end at a certain surveyed point.
remster is offline
Old 04-22-2010, 09:09 AM   #4
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 322
Chainsaw & hatchet would be the 2 tools I'd reach for. Don't understand the trick to shortening the rails.
pinwheel is online now
Old 04-22-2010, 09:17 AM   #5
mics_54's Avatar
Trade: contractor
trick to shortening a split rail fence.
#1 move post holes closer together. (don't "move" the hole. dig a new hole and fill in the old one.)
#2 cut off rails taper the ends with an adz or draw knife and install into post in new hole before you set the post and backfill.
mics_54 is offline
Old 04-23-2010, 10:33 PM   #6
Housewright & Woodwright
CARPENTERDON's Avatar
Trade: Historic Renovations-Restorations-Custom Log Homes
Rewards Points: 75
To shorten the length:
1.) Cut the rail to length
2.) Take the cut end piece and use it to mark the "wedge" on the shortened rail.
3.) Take a wide blade chisel and scribe all along the top and bottom of the outline. Then take and start the split from the end with the chisel. The pieces should split along the scribe line.
You will have a rough hewn wedge that looks like the original.
Dimensional Carpentry & Custom Woodworking - Historic Renovations, Restoration, & Custom Log Homes
All comments and statements are solely the opinion of Carpenterdon and in no way represent the thoughts of Contractor Talk, its staff, or other members.
CARPENTERDON is offline
Old 04-23-2010, 11:59 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 1,708
Best trick of all is: cut your rail before you set the post.
griz is online now
Old 04-24-2010, 07:08 AM   #8
remster's Avatar
Rewards Points: 25
Thanks thats a great tip.
remster is offline
Slit Rail Fence thezig Decks & Fencing 16 08-27-2010 04:01 PM
Chain Link Fence....top rail....braces? dodge07around Decks & Fencing 6 01-13-2010 01:32 PM
Picket Fence, Rail Mortise, Router Template Winchester Decks & Fencing 40 05-14-2009 04:27 PM
split rail fence dlcj Decks & Fencing 6 02-02-2008 01:46 PM
