-   General Discussion (https://www.contractortalk.com/f11/)
-   -   Any tricks to shortening a split rail fence? (https://www.contractortalk.com/f11/any-tricks-shortening-split-rail-fence-77205/)
remster 04-22-2010 08:30 AM
Any tricks to shortening the length of a split rail and keeping the original look. I was thinking of using sawzall with long rough wood bit.
This style rail:
http://www.lifetimefence.com/images/.../splitrail.jpg
Willie T 04-22-2010 08:38 AM
"Shortening the length", eh? Just take a few posts and rails out. :whistling
remster 04-22-2010 08:43 AM
Thats not going to work when you want the fence to end at a certain surveyed point.
pinwheel 04-22-2010 09:09 AM
Chainsaw & hatchet would be the 2 tools I'd reach for. Don't understand the trick to shortening the rails.
mics_54 04-22-2010 09:17 AM
trick to shortening a split rail fence.
#1 move post holes closer together. (don't "move" the hole. dig a new hole and fill in the old one.:):jester:)
#2 cut off rails taper the ends with an adz or draw knife and install into post in new hole before you set the post and backfill.
CARPENTERDON 04-23-2010 10:33 PM
To shorten the length:
1.) Cut the rail to length
2.) Take the cut end piece and use it to mark the "wedge" on the shortened rail.
3.) Take a wide blade chisel and scribe all along the top and bottom of the outline. Then take and start the split from the end with the chisel. The pieces should split along the scribe line.
You will have a rough hewn wedge that looks like the original.
griz 04-23-2010 11:59 PM
Best trick of all is: cut your rail before you set the post.
remster 04-24-2010 07:08 AM
Thanks thats a great tip.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
