I am having issues with the grass in my front yard. Back grows really well but the front not much. Not sure if it’s a watering issue or soil compaction.
I installed sprinklers last year and the front and back are on different zones. Both get fertilized the same and get seeded every spring.
Plant St. Augustine. It will self heal and you'll never need to seed again. Just a patch will spread through your yard and cause that other grass to go obsolete. It's beautiful as well.
Those nice green spots on your front lawn is what I'm used to seeing if a dog pooped in the snow over winter. If that's what it is, you're light on nitrogen and potassium in the adjacent area.
The line of green I see really seems to point out you probably have a soil issue. pH, drainage, something. It can be as simple as only a little top soil in some areas, and more in others.
Does that happen during dry spells or wet spells, or it doesn't seem to matter?
Besides grubs Griz mentioned, if you have too much thatch, you can get things like pill bugs.
I built the house so I know the soil was the same front and back. Might be thinner up front. No dogs on the grass there except the odd dog for walks. It seems to be both hot and dry spells. Haven’t had much extended heat this year as we have been getting a ton of rain
A thin layer of compost no more than a half inch in the fall. Make sure to get a manure based compost not bio solid. Guaranteed it will do much better. Don’t use topsoil. Soil could be a little thin in that area & compost will add needed nutrients & loosen the compacted soil. It’s not a spot that a dog uses is it? Switch to an organic fertilizer as chemicals will burn
If it’s grubs blades should pull up real easy (root damage). There is also a fungus called brown patch. Best way to check water put shallow tuna fish cans in that area & let cycle until it has 1 inch of water. A deep watering establishes roots a shallow watering only keeps roots on top not deep enough leading to weak grass
May be best to start with the basics to see what you have, and take it from there.
Grab a round pointed spade and stick it in at various places, and lever it forward so you can see the top 4-6 inches of soil. You'll be able to feel if you have compaction , and you'll be able to see any layers.
Since this was installed, you may have a compacted layer under the installed grass. If a previous lawn was killed off before install, you may have a layer of old dead roots. Either if those would interfere with your new grass growth, and if you have both it's a major barrier to new grass growth.
A plug aerator is the answer for either of those problems. If you have a soil with a lot of clay, top dressing in the fall like king carpenter mentioned and plug aerating works really well.
I don’t think aerating is necessary. Organic compost will amend the soil & loosen it. Don’t use bio solid make sure it is organic manure based & go to a reputable supplier not box store. Soil may be more compacted in front, trucks parked during build, deliveries etc. compost will greatly improve. Try to pull on runners if they break away easy could be grubs. Don’t forget tuna can test on water. I think your soil is just more compacted there & will improve with compost. Maybe do it fall & spring. Compost will have a little odor to it but will fade in a couple days
You said soil was same front & back. If you brought soil in or not it’s probably compacted there from parking. I wouldn’t expect immediate results but it will get better. All the rain your getting don’t help. Send some of it to south Tx. as it’s been in the 100s & 105 forecast today
This was a new community when we built 6years ago. We where the last house in the community so I know the lot was used for a lot of material/equipment staging.
The entire lot had new topsoil trucked in a week before we moved in and then we installed the sod Nov 1.
Do I need to wait till the fall to top dress or will top dressing now help?
Some places top dressing us done in the fall, some places it's spring and fall. Usually right before grass is either going into or coming out of dormancy. I wouldn't do it now.
If you stuck a shovel in and you find you have compaction, absolutely aerate it now so it has some time to recover. With a really short growing season like you have, you don't want to be fighting a bunch of weeds in the spring.
Any kind of aeration now would be fine, even poking a bunch of holes with a spading fork if it needs it.
Wait until fall to add compost as you want it to be cool. Make sure you get manure based compost not topsoil as it will bring in weed seeds. Half an inch at the most. You definitely have compaction if Equiptment & material was there. As Hdavis mentioned a pitchfork poking holes around will help but I wouldn’t do more than that. The compost will take care of it but have patience. Lawn more is your best defense against weeds as your grass looks strong & will choke them out. For now you can cut some 4”x4” plugs from the back & put in bad spots stomp them to get contact w/ground & they will fill in. I don’t think it’s that bad unless your shooting for the blue ribbon yard of the month. Joking but just give it some time & use organic fertilizer. Also pre emergents are a waste of money as well. Find a good organic based nursery & always look for the oldest person there for advise
Yea Mike bluegrass spreads readily through underground rhizomes. Plugging it should do well
Related Threads
3.5M posts
151.6K members
Since 2003
