Aluminum Brake, Tapco Rolling Cutoff Tool Warped Cuts! - General Discussion - Contractor Talk
Old 06-07-2019, 01:15 PM   #1
sxr951's Avatar
Trade: construct
Rewards Points: 36
got a great tapco 50 , 19 throat..aluminum brake,only prob is the separate tapco cutoff tool makes warped cuts! any idea whats up? run down the 10 foot section of trim coil and its wavy edges!...thanks heaps!
sxr951 is offline
Old 06-07-2019, 05:20 PM   #2
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 1,214
Re: Aluminum Brake, Tapco Rolling Cutoff Tool Warped Cuts!
Yeah. Could be a bunch of things. Itís one of those tools you have to develop a feel for. How fast to push it, how to apply pressure so it stays seated, how to support or not support the piece outside the brake thatís falling as youíre cutting, etc. make sure the rollers arenít all cracked up where it rides that rail on the brake. Make sure everything is spinning nice. Make sure whatever those things that do the cutting are called are still sharp and just practice.
A lot of times no matter what you do, youíll get some waviness on that edge. Itís not like cutting it with a razor. Either hem the edge or bury the edge.
EricBrancard is offline
The Following 2 Users Say Thank You to EricBrancard For This Useful Post:
Janssenbuild (07-01-2019), sxr951 (06-08-2019)
Old 06-07-2019, 06:14 PM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,404
If it is an adjustable one sometimes it needs to be set for the coil you are cutting. Mine I use pretty much just one steel coil, leave a nice edge. IMO much faster to just use a knife on aluminum and snap it.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
sxr951 (06-08-2019)
Old 06-08-2019, 03:15 AM   #4
sxr951's Avatar
Trade: construct
Rewards Points: 36
AHA!!!.. i may have found out why! it's 4 am.. so i wont know 4 sure till later BUT instructions say to MAKE SURE HINGE CLIP IS SNAPPED into place holding brake hinge and at 90 degrees . i over looked this simple instruction..si guess the floating hindge was floating all over up against the clamped alum trim..thanks 4 speedy replies!
{ till the morning comes, neil young}
sxr951 is offline
Old 06-08-2019, 04:07 AM   #5
sxr951's Avatar
Trade: construct
Rewards Points: 36
CORRECTION: still does it.. BUT this time i used the cutter on both brakes.. i got a pro 14 and a pro 50 19... so now it must be the cutter and its components. when i spin the cutter wheels they hit the other wheel at one point ..{ the plot thickens}
sxr951 is offline
Old 06-08-2019, 04:22 PM   #6
sxr951's Avatar
Trade: construct
Rewards Points: 36
MYSTERY SOLVED!~~~~ inspite of old roller parts..which i need to order... i wasn't pushing the cutter IN toward tracking as it moved forward, have to really push in toward the rollers to keep them seated ..i kinda thought it would just glide rt thru..lol incredible deal! pro 14 with a side winder!!!. PLUS a tapco cutoff tool!! only $ 700 bananas!... keeping the 2 pieces for my pro 50 and selling the pro 14! for $800 by it self..
sxr951 is offline
The Following User Says Thank You to sxr951 For This Useful Post:
Randy Bush (06-08-2019)
Old 06-09-2019, 02:04 PM   #7
VinylHanger's Avatar
Rewards Points: 10,830
The sidewinder and cutoff tool are a game changer when doing metal.
I went years and years with laying it out in the yard on a siding box and using my knife. It works and you get used to it.
But once I had the sidewinder and cutoff, it makes things so much easier, cleaner and faster.
Bummer, is I dont do much metal work these days.
VinylHanger is online now
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
A&E Exteriors (06-20-2019), sxr951 (06-28-2019)
Old 06-09-2019, 02:39 PM   #8
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 7,028
Think I might finally get one. Have a bunch of soffit jobs in the pipeline and we use the brake pretty often anyway. Been scoring it with the utility knife I swear since about 10 years old with my dad. Guess time to adapt make things easier.
NYgutterguy is online now
The Following User Says Thank You to NYgutterguy For This Useful Post:
VinylHanger (06-09-2019)
Old 06-11-2019, 09:02 AM   #9
AustinDB's Avatar
Rewards Points: 1,174
sold my Tapco 5 years ago before moving to Texas, I kind of missed the creativity of forming stuff out of coil stock.
the cutoff tool is an awesome addition-beats the heck out of a utility knife. the constant pressure is the key-pushing your weight down and towards the jaws while pushing kept my cuts straight.
AustinDB is online now
Old 06-15-2019, 09:58 AM   #10
builditguy's Avatar
Rewards Points: 1,440
Glad you figured it out. Never had a problem with mine.
Once I finally accepted it, and stuck with it, it's alot faster than a utility knife and does a better job.
Now I cringe if I have to use a knife to cut a piece. (sometimes they get too thin to use the tool)
builditguy is offline
Old 06-20-2019, 11:04 PM   #11
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,816
Did you buy the cutter new or used?
Ive not had that problem with mine but you should be hemming any exposed edges anyway so i think you're good
A&E Exteriors is online now
Old 06-20-2019, 11:07 PM   #12
you wont regret it
The Following User Says Thank You to A&E Exteriors For This Useful Post:
NYgutterguy (06-21-2019)
Old 06-21-2019, 11:27 AM   #13
And your back will thank you.
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 06-28-2019, 10:26 PM   #14
sxr951's Avatar
Trade: construct
Rewards Points: 36
its still has messed up cuts.. seems to be every 10 inches.. i rolled out and measured one revolution againts the bad rough edges.. also when i slowly spin the wheel i can hear it contact the ther wheel off and on. i suspect last owner dropped it. the cuts dont effect the fasci in doing and i did hem some low areas by garage doors.. i prob need a dial indicator needle to see where on wheel its out and how many thousandths ,im gonna call tapco in morning..
aluminum brake, tapco rolling cutoff tool warped cuts!-screenshot_2019-06-28-23-28-16.png   aluminum brake, tapco rolling cutoff tool warped cuts!-screenshot_2019-06-28-23-28-05.png
sxr951 is offline
Old 06-29-2019, 11:16 PM   #15
Yep...thats f'd
Old 06-30-2019, 05:01 AM   #16
builditguy's Avatar
So, when you say, "I think the last owner dropped it", indicates it's used. Probably sold it because of the issue.
You said you were going to contact Tapco. I agree with that. They may be able to refurbish it.
Even if you have to buy a new one, they are worth it.
I used to sub for a guy and he required us to use his brake and his cut off tool. After using it, I would sit it on the ground, under the brake, on the right side. He saw me doing it and freaked out. I told him, I was sitting it on the ground, not dropping it. He didn't care, he wanted the tool hung on the end. You know, where the bending handles slide in, when not in use. There is a piece of aluminum that sticks out about 4". I told him, I didn't like it. There wasn't a hook and I was afraid it would fall off. Still, he freaked out, if it wasn't hanging there.
Ok. Short story. Sometimes when I read posts, it brings back memories.
The Following User Says Thank You to builditguy For This Useful Post:
A&E Exteriors (06-30-2019)
Old 06-30-2019, 08:38 AM   #17
Randy Bush's Avatar
For what new rollers blades cost I would just buy a new one IMO. I rarely use mine on aluminum coil, mainly only when ripping steel coil.
