Air Scrubber Duct Source? - General Discussion - Contractor Talk
Old 03-01-2019, 05:56 PM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 10,280
I'm looking for options for hooking up negative air to a blu-dri air scrubber. There are a few options for 8" x 25' collapsible wire reinforced duct. They run about $70 and up. Does anyone have a lead on anything that costs less? Seems kind of pricey for a 25' duct. I was also looking into using the poly style duct that abatement contractors use. But that stuff isn't exactly cheap either. FYI, it seems like amazon is taking over the world. Thanks, Nick.
Morning Wood is offline
Old 03-01-2019, 08:57 PM   #2
rrk's Avatar
Rewards Points: 3,442
Re: Air Scrubber Duct Source?
Unless the poly duct is going straight it is terrible, kinking and flopping around. It only seems to work straight
rrk is offline
Morning Wood (03-01-2019)
Old 03-01-2019, 09:16 PM   #3
tgeb's Avatar
Rewards Points: 432
This is a bit less expensive but I doubt it would last very long if it gets moved around a lot. $25 as opossed to $75, probably fine for a one shot job.
https://www.amazon.com/Air-Duct-Flex...-1-spons&psc=1
8" poly I found @ about $0.38/foot. But it comes with the kink issues.
https://www.deelat.com/hvac/ventilat...200mm-diameter
www.gebcon.com
tgeb is online now
The Following 2 Users Say Thank You to tgeb For This Useful Post:
rrk (03-02-2019), Stunt Carpenter (03-02-2019)
Old 03-02-2019, 07:29 AM   #4
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 156
Product is called layflat & yes you have to tape securely - one trick I heard is cutting a 5 gallon bucket in 3 & using the top two pieces as a locking collar & fitting that through your barrier or window
SLSTech is offline
The Following 2 Users Say Thank You to SLSTech For This Useful Post:
hdavis (03-02-2019), Morning Wood (03-02-2019)
Old 03-02-2019, 10:32 AM   #5
hdavis's Avatar
Rewards Points: 2,044
I'm filing that away.
hdavis is online now
Old 03-02-2019, 10:36 AM   #6
hdavis's Avatar
I'll run it on top of firring strips, then wrap with packing wrap in a few places. Just more messing around....
rrk (03-02-2019)
Old 03-02-2019, 10:40 AM   #7
Box Builder
I found some that didn’t seem too bad. I’ve got to think the lay flat moves air better than the corrugated duct. But it is disposable. The asbestos guys I just had on my job ran some lay flat over 40’ to get the negative air to work. It wasn’t straight but it seemed to work pretty well. I’ve never used it so it will be a bit of a learning curve. Tying off the end seems to be a requirement to get it to fill up. And then I’ll have to experiment with how many holes to put in the end to get it to move air but still stay expanded.
The Following User Says Thank You to Morning Wood For This Useful Post:
hdavis (03-02-2019)
Old 03-02-2019, 03:36 PM   #8
finisher65's Avatar
Trade: Drywall/carpentry
Rewards Points: 72
We've used tons of the poly tube on projects in hospitals. Roll it to where you intend to exhaust it to & tie a knot in the end. Cut holes as needed to allow for the airflow while maintaining the integrity of the tube
finisher65 is offline
Old 03-03-2019, 08:13 PM   #9
Box Builder
What mill thickness was the poly you used. Ive only got a 8 scrubber, so I went light on the stuff I got. 2 mil. Hopefully not too light. A lot of it seemed to be 4 mil.
Old 03-03-2019, 08:55 PM   #10
Dan_Watson's Avatar
Rewards Points: 2,748
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
We use this. Just cut to length and run it where you need it. If it is too long it gets a little out of hand.
Dan_Watson is offline
Old 03-04-2019, 09:18 AM   #11
finisher65's Avatar
Rewards Points: 72
Originally Posted by Morning Wood View Post
What mill thickness was the poly you used. I’ve only got a 8” scrubber, so I went light on the stuff I got. 2 mil. Hopefully not too light. A lot of it seemed to be 4 mil.
I believe we use the 4 mil stuff. Almost all of our air scrubbers have a 12" outlet
Duct design feivel_elfman HVAC 4 05-12-2018 12:53 PM
Source needed for metal duct rjwknight HVAC 0 09-20-2011 03:41 PM
questionable duct install PlumbBob^2Pants HVAC 6 12-29-2009 09:29 PM
Practical Discussion about Bus Duct ricky001 Electrical 4 08-26-2009 06:36 PM
