Adjusting Garage Door Horizontally - General Discussion - Contractor Talk
Old 12-11-2017, 01:16 PM   #1
matthew111's Avatar
Trade: handyman
Rewards Points: 92
Awile ago I had a company replace the motor and a spring on my garage door. Ever since then when I am outside the garage at night I can see light coming through the sides and notices there is a slight gap on the sides, before this it fit tight with no gap. Since air leaks through those gaps and I use it as a heated shop it is a problem. I used to have a something hanging above the garage that would swing in the wind and hit the upper center area of the garage door and damaged the paint a bit. I removed this awile ago too. I am wondering if it is possible the company thought the garage door was rubbing and adjusted it horizontally to give it more room, and what is involved in moving it back if thats the case?
matthew111 is offline
Old 12-11-2017, 01:28 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,355
Re: Adjusting Garage Door Horizontally
More likely it's just worn weatherstripping that you hadn't noticed previously. That does need to be replaced every so often for a really good seal.
A handyman should be able to deal with that easily.
Tinstaafl is online now
Old 12-11-2017, 01:29 PM   #3
tjbnwi's Avatar
Rewards Points: 3,540
Use these on the top and sides. I'm surprised the door company did not install them.
https://www.homedepot.com/p/Frost-Ki...-GR9/100185922
tjbnwi is offline
Old 12-11-2017, 01:49 PM   #4
matthew111's Avatar
Trade: handyman
Rewards Points: 92
It did not use to have any weather stripping on the sides before but it fit tightly anyway. I did install some weather stipping on the sides that helps some but I would like to have it the way it used to be. I don't know much about garage doors, is it even possible to adjust them horizontally?
Old 12-11-2017, 02:44 PM   #5
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,194
They move horizontally a bit on the roller axels, what might have happened if they only replaced one spring is that its not rated the same as the one they left and it is jarring the door a little and when it hits the ground it levels out.
Try and stop the door before it hits the ground and see if it is level. If not then replace both springs
Anderson is offline
Old 12-11-2017, 03:23 PM   #6
matthew111's Avatar
Trade: handyman
Rewards Points: 92
The gap is on both sides. If it was the spring would it be like that or just on one side?
Old 12-11-2017, 03:52 PM   #7
Anderson's Avatar
How can you have a gap on both sides that was not there before?
I don't think they shrunk your door
Anderson is offline
The Following 2 Users Say Thank You to Anderson For This Useful Post:
rblakes1 (12-12-2017), VinylHanger (12-12-2017)
Old 12-11-2017, 09:04 PM   #8
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
Check the side-rail brackets, they are often slotted for adjustment. Maybe they moved them when installing the spring. Or bent them accidently.
I recently fixed an air/light gap by loosening a few bolts that hold the side brackets onto the track/rails on and drew the rail in tighter to the door edge and seal.
kirkdc is offline
Old 12-11-2017, 11:49 PM   #9
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
Check your manual, I've adjusted a few for customers and its really easy. Its been a while but last one used two buttons on the motor to incrementally adjust the stop points. My old house was a bit more crude and you had to move the end point switches but it was probably from the mid to late 80's.
SuperiorHIP is offline
Old 12-12-2017, 05:17 PM   #10
rblakes1's Avatar
Rewards Points: 3,140
It's getting cold out, the door must have shrunk
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
Old 12-12-2017, 11:15 PM   #11
Wow, it would have been great if I would have read the issue a little more carefully.
Old 12-13-2017, 10:39 AM   #12
Mordekyle's Avatar
Rewards Points: 4,722
I've seen these doubled up to cover seams at the edges of the door. It's an inexpensive option if needed.
Mordekyle is online now
Old 12-13-2017, 05:27 PM   #13
ComRemodel's Avatar
Trade: electrical
Rewards Points: 164
So you just paid somebody to repair and adjust your door so it works properly and now you want to screw with it? Maybe it was rubbing in some places putting extra strain on your motor. Garage doors should not fit tightly against the jambs because inevitably things tighten up. The PROPER way to handle this is to install weather stripping as suggested. The flexible rubber allows the door to move while maintaining a good seal. I have never seen a garage door in a conditioned space without weather stripping.
-Hal
ComRemodel is offline
The Following User Says Thank You to ComRemodel For This Useful Post:
heavy_d (12-14-2017)
Ballpark cost for garage addition? Moze Construction 7 01-10-2015 03:21 PM
Garage conversion thoughts MarkJames Remodeling 6 02-24-2013 09:17 AM
Garage Floor Epoxy We Fix Houses Painting & Finish Work 9 12-31-2012 11:37 AM
Fire Rating of garage walls, exterior siding Richard_N_S General Discussion 9 12-12-2012 09:58 PM
Below grade attached garage, concerns new home owner Construction 1 09-06-2010 08:14 AM
