650 Sq. Ft. ADU, Stick It Or SIP It? - General Discussion - Contractor Talk
Unread Today, 11:47 AM   #1
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,608
I am doing the Architectural plans for a 650 sq. ft. Accessory Dwelling Unit (ADU) and the main designer on this project wants to use SIPs for walls and roof systems. Since the ADU is so small, I think that it would be better ie. less expensive overall for the same energy efficiency to stick frame it with a truss system.
It will be slab-on-grade and it is a simple rectangle with 9' ceilings. Pretty basic stuff that I can prescriptively engineer. The SIPs construction would require a licensed engineer as the house is in a seismic design category of S. I do not have any experience with SIPs so perhaps I am wrong about stick framing being the better option. I know that each system has its pros and cons but I am looking for validation from you guys for my opinion so that I can charge prescriptive engineering fees....mmmuuuuaaaahahahah!
But seriously, I think that framing it would be less hassle and better overall.
Am I wrong in your never to be humble opinions?
Andy.
ScipioAfricanus is online now
Unread Today, 01:12 PM   #2
hdavis's Avatar
Rewards Points: 5,898
Re: 650 Sq. Ft. ADU, Stick It Or SIP It?
I'm assuming you're talking cost. What R values for walls and ceiling, what general location?
Normally I'd say stick. Long term repairs are also easier to deal with.
hdavis is online now
Unread Today, 01:58 PM   #3
Eater of sins.
Mostly I am asking about cost, yes.
R values will be around R-19 in walls and since this is southern California, the ceiling and the wall values can vary depending on the type of construction, types of windows (SHGC and U-factors), Heating/Cooling unit type, etc.
Ceilings will probably be around R-19 to R-38 depending all the above.
I am sure there are/will be difficuties with running electrical and plumbing etc. in SIP walls that I am not aware of.
Andy.
Unread Today, 03:01 PM   #4
Bull Trout's Avatar
Rewards Points: 260
Andy.
In my experience stick framing should be more cost effective at that size
Bull Trout is online now
The Following User Says Thank You to Bull Trout For This Useful Post:
ScipioAfricanus (Today)
Vinyl peel & stick Tinstaafl Flooring 38 11-06-2014 05:54 AM
Stick Frame building iowacarpenter Framing 1 06-19-2013 09:53 PM
Sealing Lick and Stick on interior wall. VinylHanger Masonry 7 06-16-2013 08:29 PM
Wet n Stick ReliableSource Drywall 2 04-09-2013 06:06 PM
Vinyl Self Stick Tiles skpjose Flooring 22 07-17-2009 07:30 PM
