50' Boom Falls Over - Page 2 - General Discussion - Contractor Talk
50' Boom Falls Over
Old 02-07-2012, 10:56 AM   #21
sandshots's Avatar
Trade: framing/drywall
Rewards Points: 25
Re: 50' Boom Falls Over
looks like he was traveling at full extenstion and either went off the curb or tried to go over it. big NONO.
sandshots is offline
Old 02-07-2012, 11:03 AM   #22
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Originally Posted by Randy Bush View Post
It takes a lot more then a low tire to tip one over, Being a 4X4 it has a oscillation axle that automatically adjusts for the terrain. When you look and see the square curbing there I would say he drove off the sidewalk onto the street to fast with the boom that high, Any way you look at it , it was a bad deal , he is very lucky to still be alive.
A "Squishy" tire can CERTAINLY make one tip. Try driving your vehicle with a low tire and see how "unpredictable" it becomes!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 02-07-2012, 05:20 PM   #23
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,430
I'm guessing it was the curb too.
I worked out of a similar unit all year last year and had in some precarious situations but didn't even come close to tipping it, he must have really been working at it.
NYCB is offline
Old 02-07-2012, 05:36 PM   #24
TimNJ's Avatar
Rewards Points: 6,808
After taking a closer look at the video that thing is not up 50'. You figure a traffic lane at maybe 12'. So two lanes and the sidewalk. Doesn't seem like 50'.
TimNJ is offline
Old 02-07-2012, 06:01 PM   #25
Handle It!
How wide are the roads you travel?
But YES, far from 50' of extension.
Old 02-07-2012, 06:41 PM   #26
TimNJ's Avatar
I think 12' is the normal traffic lane on a highway. Most interstates are sized to accomadate 102". Considering it is a center city street and there aren't any wide shoulders in that video either.
TimNJ is offline
The Following User Says Thank You to TimNJ For This Useful Post:
MALCO.New.York (02-08-2012)
Old 02-07-2012, 07:06 PM   #27
Stunt Carpenter's Avatar
Rewards Points: 2,696
Lucky to be alive.
A few years back I was in one and the front tire found a sink hole. The only thing that keep us from hitting the ground was the side of the building we hit. Makes it hard to get back in one.
https://builddaley.com/
Stunt Carpenter is online now
Old 02-08-2012, 12:30 AM   #28
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,120
I always lanyard up when in the man lift.
But in the back of my head I'm thinking "possible human trebuchet"
mgb is offline
The Following User Says Thank You to mgb For This Useful Post:
Old 02-08-2012, 12:34 AM   #29
Fire up the BBQ
griz's Avatar
Rewards Points: 1,738
Ya, but at least you won't go very far....
griz is online now
Old 02-08-2012, 12:11 PM   #30
forsaler's Avatar
Trade: Concrete (Flat Work)
Some guys get way to used to driving them while up in the air, and get careless. Glad he wasn't hurt worse or killed. That must be one wild ride down!
forsaler is offline
Old 02-11-2012, 09:09 PM   #31
Crystal Ball Malfunction
jps614's Avatar
Trade: Construction / Remodel / Home Improvement
Rewards Points: 150
Wasn't it last year or the year before in Philly one rode over a storm grate or something and the wheel dropped, over it went and the operator got killed.
Yea, but it was one of those verizon hubs for underground cable that broke in half .
One of these...
jps614 is offline
The Following User Says Thank You to jps614 For This Useful Post:
TimNJ (02-11-2012)
Old 11-21-2012, 09:47 PM   #32
GenieBlue's Avatar
Trade: electronic controls
the counterweight on the turntable is turned over the side of the machine.
The extendable axles appear to not be extended.
The unit has safety circuits that will not let the boom elevate if the axles are not extended.
sometimes safety circuits are overridden to accommodate site conditions...
NEVER a smart move!
GenieBlue is offline
Old 11-21-2012, 11:31 PM   #33
Dirtywhiteboy's Avatar
Rewards Points: 14,524
Homies lucky to be alive
Dirtywhiteboy is offline
FRAME2FINISH (11-22-2012)
Old 11-22-2012, 12:01 AM   #34
TMDC's Avatar
Trade: masonry
Rewards Points: 61
wow, I'm glad he survived. Curious to find out what caused it to tip to avoid a situation like this.
TMDC is offline
Old 11-22-2012, 12:05 AM   #35
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,506
NEVER a smart move!
I do not believe a S-85 genie has extendable axles on it.
Randy Bush is online now
Old 11-22-2012, 06:23 AM   #36
Crocop's Avatar
Trade: Concrete and building restoration
Rewards Points: 25
Looks to me the axles weren't extended I have the same machine there is supposed to be a safety device that won't let the boom go up more than 15 ft if the axles aren't extendedl
Crocop is offline
Old 11-22-2012, 08:27 AM   #37
GenieBlue's Avatar
true crocop,
Randy, the newer S85s do not have extending axles.
The older ones, like the one that tipped over, definitely need to have the axles extended.
The newer model has a link assembly that keeps the weight of the boom over the center of the machine.
The older models needed the axles extended to provide the stability.
Old 11-22-2012, 10:05 AM   #38
Randy Bush's Avatar
true crocop,
I just looked this up on Genies site , and the unit starting with ser # 00001 could have been built either way. The with ones also acording to parts book shows lift cyls to extend with I don,t see in the picture.
Old 11-22-2012, 10:42 AM   #39
GenieBlue's Avatar
there have been a few changes on this model throughout it's evolution.
Up through serial # 3081 there were hydraulic jacks on the chassis to lift the wheels off the ground so the axles could be extended.
Serial numbers 3082 through S8008-7999 do not have the hydraulic jacks on the chassis. The axles were extended by holding the Axle Extend switch while driving the machine forward or reverse.
From serial # S8008-8000 (S80) and serial # S8508-8001 (S85) there are no extending axles on the current production machines.
Thoughts on CAT excavator boom sticking viper6383 Excavation & Site Work 7 09-14-2011 07:29 PM
Difficult delivery (boom truck) TrustedConst Framing 4 05-03-2011 05:57 PM
quality builder in klamath falls, oregon dayexco Construction 2 04-27-2011 10:52 PM
