3-4-5 Squaring Method - General Discussion - Contractor Talk
Old 01-18-2012, 07:05 PM   #1
DanTheMan6937's Avatar
Trade: topcoat paving
Question
what is 3-4-5 squaring method
DanTheMan6937 is offline
Old 01-18-2012, 07:11 PM   #2
rselectric1's Avatar
Rewards Points: 896
Re: 3-4-5 Squaring Method
Do a google search for the Pythagorean theorem. It's the same thing. It makes perfect right angles.
rselectric1 is offline
Old 01-18-2012, 07:11 PM   #3
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
Pythagorean theorem a2+b2=c2
JustaFramer is offline
Old 01-18-2012, 07:12 PM   #4
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
Pathagorean therum- a squared plus b squared is equal to the square root of the sum
3x3=9
4x4=16
9+16=25
Square root of 25 is 5
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
Old 01-18-2012, 07:14 PM   #5
Holder of hands
skcolo's Avatar
Trade: Custom builder/remodeler
Imagine a triangle. At the corner, measure 3 ft in one direction, then 4 feet from the corner at the 90 degree direction, then the two furthest points should be exactly 5 ft apart, which would mean the corner is square.
skcolo is offline
Old 01-18-2012, 07:15 PM   #6
TimberlineMD's Avatar
Rewards Points: 738
Quoting from 'Swansons Little Blue Book"...
"To lay out a 90 degree corner, measure out 3' on one side and 4' on the other and adjust until the diagonal is exactly 5', or use 6', 8', then 10' will be the diagonal."
TimberlineMD is offline
Old 01-18-2012, 07:16 PM   #7
jb4211's Avatar
Rewards Points: 2,306
Jon
jb4211 is offline
The Following 4 Users Say Thank You to jb4211 For This Useful Post:
Brutus (01-18-2012), Mud Master (01-18-2012), Willie T (01-18-2012), WNYcarpenter (01-18-2012)
Old 01-18-2012, 07:19 PM   #8
Gen. Contractor
It doesn't have to be 3,4,5
It can be 12,12,16.97
The formula is usually expressed 3,4,5 becouse there whole numbers.
The Following 2 Users Say Thank You to Ninjaframer For This Useful Post:
SC sawdaddy (01-18-2012), Willie T (01-18-2012)
Old 01-18-2012, 07:22 PM   #9
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 186
6-8-10 is my personal fav!
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Brutus (01-18-2012)
Old 01-18-2012, 07:26 PM   #10
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
I'll bite...
Crudely....with a right triangle you have have a 90* corner with two legs, and a hypotenuse that connects those legs. Leg A=3', leg B=4' and the hypotenuse(C=5').
If you're framing a form with an inside corner you would measure 3' on one side and 4' one the other. Pull your measurements from the exact same point at the inside corner. If your corner is square, when you measure between the two points you just marked the measurement is 5'. Always use the same edge or your tape when measuring.
If your form is out of square you adjust the squareness until the hypotenuse=5'......
That's the basic principal.
Edit: what they said...thought I might be the only one to answer this one
WNYcarpenter is offline
The Following User Says Thank You to WNYcarpenter For This Useful Post:
Old 01-18-2012, 07:28 PM   #11
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Understanding the mathematical concept is one thing. Being able to apply it in the real world takes time.
Try to make the triangle as big as you can. To do that you just need to multiply the two legs by a common number. If you use 3 as your number then you have a 9 - 12 - 15 triangle.
If you have a construction calculator you can use the same principle with any length sides. Just by entering your two legs as rise and run. Then hit the diagonal button. This way you can check large forms from corner to corner, as an example.
Gus Dering is offline
Old 01-18-2012, 07:31 PM   #12
Hmbldr's Avatar
Trade: Residential contractor
Rewards Points: 150
But the point is... the 345 squaring method is easy because it requires no calculation. Also easy because it is expandable, 6-8-10, 9-12-15, etc. If you're going to bother doing calculations, then you would go to the exact dimensions of your box and figure exact diagonals.
Hmbldr is offline
Old 01-18-2012, 07:34 PM   #13
Lets work with offsets and batter boards. Call in the total station.
Old 01-18-2012, 07:35 PM   #14
Gen. Contractor
12,12,16.97 is significant to framers. You can also look at the brace table on a framing square, It gives diagonals to many rise/runs.
The Following User Says Thank You to Ninjaframer For This Useful Post:
knucklehead (01-18-2012)
Old 01-18-2012, 07:42 PM   #15
Hmbldr's Avatar
Rewards Points: 150
Ninja, I agree and understand. Just relating back to the OP original question.
Hmbldr is offline
Old 01-18-2012, 07:44 PM   #16
Gen. Contractor
For sure
Old 01-18-2012, 07:47 PM   #17
Holder of hands
skcolo's Avatar
Actually, the real answer to the 345 method is when a framer has three beers, checks out four girls, then steps back five feet and eyeballs the chalk lines and says, "good enough".
skcolo is offline
The Following 4 Users Say Thank You to skcolo For This Useful Post:
A&E Exteriors (01-18-2012), dprimc (01-27-2012), Framer53 (01-19-2012), wazez (01-19-2012)
Old 01-18-2012, 07:54 PM   #18
wannabe
Trade: carpentry
O.P......This method is only as accurate as the material you're using is straight. A bow in lumber will throw everything off.
Old 01-18-2012, 07:55 PM   #19
Gen. Contractor
The op hasn't had any questions so we must have answered pretty well.
Old 01-18-2012, 08:10 PM   #20
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
I was at church the other day, and there was a new pastor they were introducing. He was also a mathematics teacher and had traveled a lot.
I have heard and read a bit about the Pythagoreans. I think there may be some reference to them in the bible as well. Anyway, some think the theorum is based on the teachings of one man. I figured the Pythagoreans were a group of people from a region, like Pythagorea. See Sparta-Spartans, Athens-Athenians, etc.
So I asked the guy what he knew about it, if it was one man, a region, etc. and he said it was a region and specifically probably one person, but they had built a whole religion around the use of the numbers.
I'm not sure there wouldn't be some connection to the free masons. Once you master this knowledge, it would be very powerful. Just think of the respect given to someone today who can master all the information on a framing square.
cleveman is offline
Patent for: Apparatus and method for long-term storage of antimatter wallmaxx Off Topic (Non Trade) 3 05-09-2010 09:06 PM
What is the most Accurate method to measure for siding? SidingWindows Windows, Siding and Doors 20 03-21-2010 09:06 PM
What is the proper method of Advertising? Jmfocus Marketing & Sales 9 07-04-2009 12:07 PM
Tip on Squaring Tom R Carpentry 82 05-25-2009 01:24 AM
3-4-5 Method of Squaring renkom Framing 19 12-05-2008 02:07 AM
