In Your Opinion Good Underlayment On Cement - Flooring - Contractor Talk
Old 01-28-2011, 09:27 PM   #1
nymasterfloors's Avatar
Trade: Flooring
Rewards Points: 150
I am installing a floating engineered floor in a basement. I wanted some new ideas on underlayment click lock installation thnks
nymasterfloors is offline
Old 02-03-2011, 01:36 AM   #2
Keeyter's Avatar
Trade: Home Remodels
Rewards Points: 851
Re: In Your Opinion Good Underlayment On Cement
Check the Manufacturers specs. Don't matter what any of us think, if the Manufacturer dictates a type follow it for warranty purposes. Then narrow down the brands that fit the Manufacturers specs. After that, you'll need to answer all the other questions for anyone to guide you. Moisture content, Wood Brand/Type, Above/Below Grade ..... at which point I refer you to the Manufacturers specs again.
Keeyter is offline
The Following User Says Thank You to Keeyter For This Useful Post:
pinwheel (02-03-2011)
Experimenting w/ Lightweight Concrete Mixes + Fillers jgray152 Masonry 50 10-20-2012 04:01 PM
Cement Board ? Abaco83 Tiling 16 11-30-2010 09:14 AM
need 2nd opinion on exterior stair trim issue jordanski Finish Carpentry 1 03-15-2009 04:15 AM
Roofing Cement in a tube.... TBFGhost Roofing 29 01-29-2009 04:06 AM
Good resi guy for electrical in MI Bkessler Help Wanted or Looking For Work 0 10-03-2008 07:21 PM
