Vinyl Flooring Stair Detail - Flooring - Contractor Talk
Old 09-26-2019, 06:35 AM   #1
builditguy's Avatar
Rewards Points: 2,172
A customer contacted me about their flooring. They have hired a flooring company to install new vinyl flooring in the first floor of the house and the stairs.
Yesterday, they contacted me, asking for help with the bottom step. The flooring contractor said they can't do a radius and suggested they hire a carpenter to remove the step and turn it into an octagon shape, so they could install the vinyl flooring over the octagon shape.
First I said, they should have thought about this, when they bid the job, not when got the flooring to the step.
But, I don't install flooring, so I don't know what kinds of mouldings are available. It would seem there should be a flexible moulding to run around the radius of the step.
I can modify the bottom step, to make it an octagon, but it won't look right.
Any suggestions?
I will post the pictures she sent me.
builditguy is offline
Old 09-26-2019, 06:38 AM   #2
builditguy's Avatar
Re: Vinyl Flooring Stair Detail
Old 09-26-2019, 06:39 AM   #3
builditguy's Avatar
The first picture is what they drew on the floor, showing what they wanted done. As you can see, they made it quite a ways, before letting her know, there was an issue.
Old 09-26-2019, 08:22 AM   #4
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 40
I can't imagine any manufacturer would make a moulding to fit what you have. The octagon makes sense so they can miter the nosings. ,As to why they waited so long, I would bet the installer never seen the project before they showed up to lay the flooring. I sub through a floor store & the salespeople have no clue on what it takes to install the product theyre selling. That vinyl plank lays fast, so I'd bet they didn't even realize they had a problem till they got there.
pinwheel is online now
The Following 2 Users Say Thank You to pinwheel For This Useful Post:
spazman (09-26-2019), tang (09-26-2019)
Old 09-26-2019, 10:12 AM   #5
builditguy's Avatar
They’ve been working on it over a week.
Thanks for the reply
Old 09-26-2019, 10:18 AM   #6
pinwheel's Avatar
Rewards Points: 40
Then I have no explanation why the chuckleheads couldn't have showed you what they needed done before they had all the finished flooring laid around the area you need to correct.
Are they independent floor guys who bid & supplied materials for the project, or sub for a floor store?
The Following User Says Thank You to pinwheel For This Useful Post:
Frank Castle (09-27-2019)
Old 09-26-2019, 10:41 AM   #7
builditguy's Avatar
They work for the flooring store.
I’m getting more of the story now. Supposedly the manager was aware of it. Before he sent them out, he went on vacation.
Just a lapse in communication.
The Following User Says Thank You to builditguy For This Useful Post:
pinwheel (09-26-2019)
Old 09-26-2019, 10:43 AM   #8
builditguy's Avatar
Of course they worked there a week, before mentioning it to the homeowner.
SmallTownGuy (09-26-2019)
Old 09-26-2019, 10:47 AM   #9
MarkJames's Avatar
Rewards Points: 20,299
Yikes.
How about closing off the first step instead, and making a platform for plants and knickknacks?
MarkJames is offline
Old 09-26-2019, 10:57 AM   #10
builditguy's Avatar
I like that idea.
Old 09-27-2019, 05:14 AM   #11
builditguy's Avatar
After thinking about it, I think I'm going to suggest removing the radius. The flooring contractor can remove the flooring, in that area. Only about 4' to the wall.
I can cut off the radius, then they can have a square corner on the stairs. I don't think it's really important to keep the integrity of the architectural detail. The stairs, may the original, may not be. The stairs were moved to that location, about 50 years ago.
As for the corner. I'm thinking a small shaved corner will work, for that top corner of the step. That way, there isn't a 90 degree corner, to catch a leg.
Old 09-27-2019, 06:46 AM   #12
General Contractor
greg24k's Avatar
Rewards Points: 8,958
As it was said, they should have thought about this before.
Tell them to cut a s^*t load of small pieces of nosing and wrap around the radius and have a s^*t load of seams Next time they will think ahead.
greg24k is offline
Old 09-27-2019, 07:15 AM   #13
MarkJames's Avatar
You think they're going to fill in the floor after you remove the radius? I wouldn't bet on that. Or are you talking about the top only?
Old 09-27-2019, 07:46 AM   #14
pinwheel's Avatar
Rewards Points: 40
I'm betting that's click lock vinyl plank. Filling that back in will take 15 minutes tops. Not a big deal.
Old 09-27-2019, 02:07 PM   #15
builditguy's Avatar
Yes. click together vinyl. Should be easy.
Apparently, this is no longer an issue, I need to solve. Her daughter found a "wrap around" trim piece on pintrest. They are going to go to Lowe's and Home Depot, to try and find it. Problem solved.
Bahahahahhahhaaa. At least I'm out of the loop, for now. She didn't like my idea anyway.
Old 10-11-2019, 11:23 AM   #16
AustinDB's Avatar
Rewards Points: 754
her solution works, I suppose. My solution would have been to square that off of try a heat gun to bend the nosing.
AustinDB is online now
