Vct Tile Adhesive - Flooring - Contractor Talk
Vct Tile Adhesive
Old 02-01-2019, 07:38 PM   #1
Boti313's Avatar
Trade: handyman
Vct Tile Adhesive
We removed some VCT tile and planning on installing some VLT tiles do we have to remove the old adhesive residue?
Boti313 is offline
Old 02-01-2019, 08:14 PM   #2
TimNJ's Avatar
Rewards Points: 5,038
Re: Vct Tile Adhesive
What kind of adhesive is it?
What kind of subfloor?
TimNJ is offline
Old 02-01-2019, 09:26 PM   #3
Boti313's Avatar
Trade: handyman
The old one I am not sure. The tile was installed back in the late '90s. When we remove the old tile it left a black residue. On the new tile we using Armstrong s280, or Henry 430. The subfloor is cement in a basement.
Boti313 is offline
Old 02-01-2019, 09:58 PM   #4
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,248
Call Armstrong and Henry technical support. Both have excellent folks to speak to regarding what you have to work with.
I'm assuming you will get feedback to do a tight skim coat over the existing adhesive.
Here's Ardex's version.
https://www.amazon.com/Ardex-Feather.../dp/B07DPRMPB5
I tend to overkill / bomb proof my stuff.
Steve
We Fix Houses is offline
Old 02-02-2019, 09:26 AM   #5
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,401
The adhesive has asbestos in it. Skim it with Ardex and don't grind it!
rescraft is offline
Old 02-02-2019, 12:50 PM   #6
Boti313's Avatar
Trade: handyman
Thank you everyone for all your help.
In your opinion how thick the skim coat be? Keeping in mine that the floor is nice and level and only applying the skim coat to cover the adhesive.
Boti313 is offline
Old 02-03-2019, 11:34 AM   #7
rescraft's Avatar
Just enough so you can't see the black adhesive. Also fills in minor defects.
rescraft is offline
Old 02-03-2019, 12:15 PM   #8
rrk's Avatar
Rewards Points: 2,294
Unless it is tested you don't know that, especially if tile was installed in the 90s
Adhesive containing asbestos was last sold in 1984, not all had asbestos and there were some in the 90s that were black with no asbestos.
rrk is offline
EthanB (02-03-2019)
Old 02-03-2019, 12:52 PM   #9
Talking Head
EthanB's Avatar
Rewards Points: 320
I'm with RRK. Very unlikely it has asbestos if he's confident it was installed in the 90's. Nobody was holding onto inventory of the old stuff for 6+ years.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
rrk (02-03-2019)
Old 02-03-2019, 02:42 PM   #10
rrk's Avatar
After 6+ years it would have been hard as a rock in the bucket
rrk is offline
Old 02-03-2019, 06:42 PM   #11
rescraft's Avatar
Why not play it safe and do a light skim? Makes for a nice flat surface and can be sure of the new bond.
rescraft is offline
Old 02-03-2019, 06:55 PM   #12
Boti313's Avatar
Trade: handyman
Thank you everyone for the help
Boti313 is offline
Cracks in tile and backer board Mltileguy Tiling 27 06-13-2019 03:15 PM
need help estimating some tile work meselffff Tiling 15 05-08-2013 05:59 PM
Vinyl Flooring Adhesive Question josephdan General Discussion 1 03-05-2013 05:36 PM
Install Azrock Tile with Armstrong VCT Adhesive? zesty Flooring 2 07-24-2011 11:36 AM
adhesive for pool tile surround AustinDB Tiling 1 04-06-2009 06:53 AM
