Vapor Barrier Behind Hardi Backer? - Flooring - Contractor Talk
Old 06-11-2015, 02:59 PM   #1
Isaacsycamore's Avatar
Trade: Flooring Contractor
Rewards Points: 26
I'm doing a repair in a shower for a customer. The previous installer used a vapor barrier behind the Hardiebacker instead of a waterproof membrane behind the tile. If you screw the hardibacker to the studs won't that cause a leak around the screws? I've always used a membrane.
Isaacsycamore is offline
Old 06-11-2015, 03:03 PM   #2
ccoffer's Avatar
Rewards Points: 1,140
Re: Vapor Barrier Behind Hardi Backer?
It's a shower, not a swimming pool. Aquabar is the best thing to use because it gives the condensation a place to hang out instead of it running like it does on plastic. It's tried and true, but building a dry shower is better for several reasons.
ccoffer is offline
Old 06-11-2015, 03:18 PM   #3
Rewards Points: 26
Only asking because when I pulled the bottom row of tile the hardibacker was saturated.
Old 06-11-2015, 09:37 PM   #4
ccoffer's Avatar
I'm guessing they used polyethylene. Is it a real shower or is it a receptor? Not that it matters. A dry shower is the better method.
ccoffer is offline
Old 06-11-2015, 09:40 PM   #5
ccoffer's Avatar
Was it done with glue or thinset? If it was done with the glue from the red bucket, the failure at the bottom is totally normal.
ccoffer is offline
Old 06-11-2015, 10:09 PM   #6
Rewards Points: 26
It was set with thinset. The pan I was told is a tile redi shower pan. The pan is also springing when you step on it. Seems to have let go from the adhesive they used to set it with.
Old 06-12-2015, 10:50 PM   #7
Box Builder
Morning Wood's Avatar
Rewards Points: 9,876
Sounds gross.
Morning Wood is offline
Old 06-13-2015, 01:10 AM   #8
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Sounds like someone stepped on it when the mud under the pan was setting.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Isaacsycamore (06-13-2015)
Old 06-13-2015, 04:54 AM   #9
Big Shoe's Avatar
Rewards Points: 2,010
Hung hundreds of showers if not thousands. Never once saw a vapor barrier. There was talk of 30lb. behind cement board 10yrs. back , but never saw that either. (Maybe a couple times.)
Hung Hardie backer once............but never again.
Expect the Unexpected
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
Old 06-13-2015, 08:17 AM   #10
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
I turned down two shower installs the past week, one friend, one friend of friend, time involved/ vs. profit is too low for taking time from other projects.
I used to use visqueen and felt paper years back, then switched to redguard, I've got about 20 gallons of waterproofer on hand.
Something is better than nothing, wet hardibacker does not damage it like drywall, mud beds get wet as well, I call that functional.
MIKE ANTONETTI is offline
Old 06-13-2015, 09:57 AM   #11
avenge's Avatar
Rewards Points: 706
I used 6mil plastic behind all cement backer before membranes became readily available, that's the method that was supposed to be used.
avenge is online now
Old 06-13-2015, 12:36 PM   #12
Rewards Points: 26
Wouldn't the vapor barrier need to drain into the pan and not stop at the subfloor like they have it? Could be a dumb question but like I said I've always used a membrane.
Old 06-13-2015, 12:42 PM   #13
Rewards Points: 26
I forgot to mention this shower was installed less than a year ago.
Old 06-13-2015, 12:53 PM   #14
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
We're doing a shower now where they insisted on vapor barrier. Used 6mil I had laying around. It's weird because they act like they know everything there is to know about showers and construction. Weirdos
illbuildit.dd is offline
Old 06-13-2015, 12:55 PM   #15
Rewards Points: 26
Don't you just love those kind of customers?
Old 06-13-2015, 01:00 PM   #16
House surgeon
These guys are the worst I've had in my whole career. No joke. And they had the nerve to ask me to remodel another room in the house. Not just no but NOOOO THANK YOU
Old 06-13-2015, 06:05 PM   #17
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 114
Yes the plastic is in the wrong spot though some code officials insist on it - also a membrane or fluid applied should still be used making sure moisture goes back into the pan
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Old 06-13-2015, 07:18 PM   #18
Rewards Points: 26
That's what I thought. Thanks
Old 06-14-2015, 01:28 PM   #19
ccoffer's Avatar
WTF? Where should it be? On the roof? The method is as old as tile. You put paper or plastic over the studs and then make sure the bottom laps over the pan liner. It's pretty rudimentary stuff. This is described literally in detail in that mysterious thing called the TCA handbook and has been since before most of us were born.
ccoffer is offline
The Following 6 Users Say Thank You to ccoffer For This Useful Post:
Big Shoe (06-15-2015), BlueRidgeGreen (06-14-2015), charimon (06-14-2015), EthanB (06-14-2015), Isaacsycamore (06-14-2015), PrecisionFloors (06-14-2015)
Old 06-14-2015, 02:17 PM   #20
Rewards Points: 26
Unfortunately my handbook walked off and my new one hasn't arrived yet. I appreciate all the feed back guys.
When do you put screws in hardi backer? DuFast Tiling 13 02-16-2012 10:14 PM
Hardi Board Tile Backer wwkbob Flooring 8 03-15-2011 09:21 AM
coiled roofing nailer for hardi backer Mike Finley Tools & Equipment 40 03-03-2010 09:26 AM
Hardi panel Siding for tile backer? Slowtrawl Flooring 3 01-13-2010 02:24 PM
Moisture board, denshiel, hardi backer AARC Drywall Drywall 11 06-12-2008 11:11 PM
