Uneven Concrete Meets Subfloor - Flooring - Contractor Talk
Old 09-27-2012, 06:31 PM   #1
Handy Hero's Avatar
Trade: Handyman
I'm getting ready to put down some hardwood and most of the subfloor is 3/4 ply, but there is a little bit of concrete (6" X 40") that protrudes into the room in front of the fireplace. The concrete is uneven and in some places is about 1/2" higher than the subfloor. Would grinding the concrete down be the best method to get it even with the subfloor?
Handy Hero is offline
Old 09-27-2012, 06:43 PM   #2
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Re: Uneven Concrete Meets Subfloor
You could grind it but it will make a lot of dust , need to use a shop vac . Or you could chip it off with a chipping gun , a lot less dust . Couldnt you put a piece of granite or marble in front of the fire place ?
Eaglei is offline
The Following User Says Thank You to Eaglei For This Useful Post:
Old 09-27-2012, 06:45 PM   #3
Handy Hero's Avatar
Trade: Handyman
That's not a bad idea. Thanks for the advice.
Old 09-30-2012, 02:41 PM   #4
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Yes , grind the high and fill the low, rent a 7" diamond grinder with dust shroud and vacuum, possibly from Home Depot or sunbelt rentals
MIKE ANTONETTI is offline
Old 09-30-2012, 04:33 PM   #5
jhutch's Avatar
Trade: Epoxy Garage Floors, Concrete Sealing
Rewards Points: 155
I agree that a diamond grinder with vac would work well. Not sure where you can rent it though. Good luck!
John Hutchins/Amazing Garage Floors
Atlanta Epoxy Garage Floors
jhutch is offline
Old 09-30-2012, 04:38 PM   #6
Eaglei's Avatar
Not wort renting anything for that size area .
Eaglei is offline
Old 09-30-2012, 04:59 PM   #7
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Chip it down lower than the subfloor and use a self leveling product to get back to the height you need. Very minimal dust and less work than grinding
Chris
Chris Johnson is offline
proper subfloor AustinDB Tiling 35 05-26-2012 01:16 PM
Recommendation on changing concrete color with breathable product? RDBD Specialty Coatings 0 06-07-2011 08:57 AM
Concrete Meets Siding bryanscott Windows, Siding and Doors 1 09-08-2010 01:38 PM
Concrete to subfloor transition TB1 General Discussion 23 12-18-2008 05:56 AM
New plywood subfloor over concrete slab jeffaah Construction 5 10-17-2008 11:33 AM
